HP Elitebook 745 G5 Security Device problem
  • Robien
    • Mar 2014
    • 25
    after i used rcunlocker to clear password from main bios i got this error
    i tried many bios but same problem
  • hoaca388
    Badcaps
    • Jan 2022
    • 11708
    Re: HP Elitebook 745 G5 Security Device problem
    HP EliteBook 745 G5 Notebook PC
    • volinakis
      • Jan 2021
      • 2728
      • N/A
      put back original bin into main bios and use RCUnlocker to the 2nd chipset which should be EC_ROM. At 1st boot reset security settings.
      • Robien
        • Mar 2014
        • 25
        same problem
        • Robien
          • Mar 2014
          • 25
          i will try that
          • hoaca388
            Badcaps
            • Jan 2022
            • 11708
            same problem
            Did you flash both files I posted ? Try returning the original files.
            • Robien
              • Mar 2014
              • 25
              i flashed both files that you post , when i return the original got the same message
              • Robien
                • Mar 2014
                • 25
                same problem after clearing 2nd chip and keep main
                • Robien
                  • Mar 2014
                  • 25
                  any solution
                  • hoaca388
                    Badcaps
                    • Jan 2022
                    • 11708
                    any solution
                    This serial number is your ? : 5CG9035MRY
                    • Robien
                      • Mar 2014
                      • 25
                      yes its
                      • hoaca388
                        Badcaps
                        • Jan 2022
                        • 11708
                        yes its
                        Try again and see result.If it works try to enter bios settings on first boot.
                        • volinakis
                          • Jan 2021
                          • 2728
                          • N/A
                          He's not resetting security at 1st start, this happened to me when I did unlock an HP and missed to enter in bios to reset security and laptop did boot from ssd. I had to put back both original bin files, start the laptop, let it boot, then reflash EC_ROM and reset security settings to default.
                          So, try this: put back original files, power on the laptop and see if security message is displayed. Then modify EC_ROM with RCUnlocker and reset security to defaults, it's at the end of security tab. Remove ssd to be sure laptop is not booting.
                          • Robien
                            • Mar 2014
                            • 25
                            Clear main bios VSS region and later add SN etc back in bios.
                            thanks to RethoricalCheese
                            problem solved after Clear main bios VSS region
                            mpm unlocked
                            write back data
                            it works
                            • jaaa1976
                              HP EliteDesk 800 G4 Mini PC -There is a problem with the security device on the unit
                              by jaaa1976
                              Hi everybody !
                              I bought this pc from ebay with error - There is a problem with the security device on the unit
                              please fix my bios.
                              Model: HP Elitedesk 800 G4 mini PC (65w)
                              serial no. 8CC93326J4
                              PRODUCT NO. 4KW04ET#ABU
                              32- 16mb bios attached
                              Thank you so much...
                              12-19-2024, 06:48 PM
                            • filewalker
                              HP Elitebook 840 G5 Endpoint Security Controller Problem
                              by filewalker
                              I have recently bought a Laptop that has a Endpoint Security Controller Problem. According to the seller it has just appeared all of the sudden.
                              Things I have tried so far:
                              • Restore the security settings to defaults and restart the laptop
                              • Disable all the security options
                              • Clear the NvramActiveRegn areas (replace with FF) Hex Area 37000-38FF0
                              Also I have checked the DMI Information which seems right according to the stickers on the mainboard.
                              Is there anything else I can try?...
                              10-27-2022, 02:52 AM
                            • lekvilius
                              HP 640 G4 BIOS Security Device Problem
                              by lekvilius
                              Hello!, i've got Hp 640 g4 that recently had bios reflash by someone else due to having password and now when you turn it on after 30 seconds of black screen it posts with message: security device problem. I don't have original bios to flashback and just remove password. Does anyone know how to solve this bios problem? Also serial is different in bios than it is on the bottom cover so maybe that's the problem?...
                              03-28-2022, 04:49 PM
                            • kolebbk
                              HP EliteDesk 705 G5 SFF (AMD) - Endpoint security controller problem
                              by kolebbk
                              Hi, I have a problem with my HP EliteDesk 705 G5 Small Form Factor computer on amd . Standard corrupted bios probably corrupted during the update. I have uploaded a clean dump from the manufacturer's website with the latest version but when I turn it on a message appears :
                              HP Endpoint Security Controller problem
                              there is a problem with the hp endpoint security controller on the unit
                              I tried restoring the bios security to factory defaults after the first switch-on because this helps with intel-based laptops. Here unfortunately this did not help. Does anyone have...
                              09-04-2024, 12:44 AM
                            • woji
                              HP EliteBook 840 G1 - memory and MB problem?
                              by woji
                              Hello, can I ask for help with my problem? I have an HP EliteBook 840 G1 laptop and I have this problem - when I turn on the laptop, it usually starts up to 5-6 times ... the keyboard, power button, LEDs always light up, the fan spins and after 1 second the laptop turns off. After several attempts, the laptop turns on and starts to start, but then CapsLock and NumLock start flashing - 3 times and the fan spins at full speed. According to the manual, this is a RAM error - but I have already tried about 10 working modules and always the same error. Has anyone solved a similar or the same problem?...
                              07-08-2025, 02:19 AM
