Lenovo T14 gen1 no power up
  • viking6791
    • Aug 2018
    • 42
    • My Desk
    Hi, I have one Lenovo T14 gen1, when I press the power button, the device does not turn on.
    If you remove the battery and the bios one and start the laptop, it starts without any problem.
    Could this be an Intel ME region problem?
    I am attaching the original bios.
    Thanks in advance for any advice!
  • hardware1
    • Sep 2021
    • 2948
    • N/A
    Re: Lenovo T14 gen1 no power up
    It's better to write your device serial number, to create a new bios file.
    Also try this file first, i just clean ME in it.
    all donations are welcome,
    • viking6791
      • Aug 2018
      • 42
      • My Desk
      I tried your file but I have the same issue, the machine not start until bios battery is removed.
      I have this type number : 20S0-000NMZ and this is SN: PF-2A4RT7, can you help me to build a new bios file?
      Thanks for help!
      • exe557
        • Jan 2021
        • 24
        Is the power button working when you have started the unit after removing the cmos battery+ main battery?
        • hardware1
          • Sep 2021
          • 2948
          • N/A
          Here's your new file, try it and give me the results.
          • viking6791
            • Aug 2018
            • 42
            • My Desk
            Yes it works!
            • hardware1
              • Sep 2021
              • 2948
              • N/A
              Yes it works!
              You're welcome, glad to know that.
              • viking6791
                • Aug 2018
                • 42
                • My Desk
                It's ok now, laptop works fine.
                I will put it to the test to make sure there is no hidden defect!
                Thanks again for help!
                • webhost
                  • Aug 2019
                  • 86
                  • Belgium
                  thank You So much , its work perfectly .
                  • shashtol
                    • Jun 2024
                    • 4
                    • poland
                    Hi, I have one Lenovo T14 gen1, Intel i5 10th. when I press the power button, screen matrix does not turn on, the processor works, the fan turns on for a second, as does the keyboard backlight.
                    Product: 20S1-S7MY00
                    SN: PF-24Y2CH
                    BIOS LENOVO 1.28 (N2XET38W)
                    Version: N2XUJ20W
                      SMDFlea commented
                      Editing a comment
                      Thread merged.
                  • Markus1741
                    • Sep 2020
                    • 947
                    • N/A
                    SN: PF-24Y2CH
                    Version: N2XUJ20W
                    Try ...
                    • shashtol
                      • Jun 2024
                      • 4
                      • poland
                      Originally posted by Markus1741
                      Try ...
                      Unfortunately it does not work
                      • keepread
                        • Oct 2024
                        • 31
                        Have a T14 gen1 that threw up a battery error. The user then googled the reset button trick and applied it about 5 times. That did not restore the operation. Instead, the laptop stopped powering on completely. I bought them a brand-new battery but still nothing at all: no indicator LED near the USBC socket, no LED on the power button, no start.
                        I can see that the laptop draws 0.4Wt power from either the portrable PSU or the docking station PSU. No lights on the docking station either.
                        Here's what I tried:
                        Disconnect PS, hold the power button for 1 minute.
                        Disconnect the battery and CMOS battery for 1 minute.
                        Hold the reset button for 20 sec.
                        All permutations of the above. Still no start, no light.
                        Any suggestions?
                        • to5it0
                          Need Clean BIOS/EC Bin File for Lenovo ThinkPad Yoga 11e 2H1703-27220F Rev. A Marked as U2501 on the motherboard.
                          by to5it0
                          Need Clean BIOS/EC Bin File for Lenovo ThinkPad Yoga 11e - Stuck with 0275 Error CMS
                          I am attempting a repair on a Lenovo ThinkPad Yoga 11e that is currently stuck at boot with the error: "0275 error CMS" even after setup new bios battery and will not allow me to enter the BIOS/Setup.
                          This is a critical issue that I believe requires flashing the BIOS chip directly using a programmer (e.g., CH341A/RT809H), as standard software updates or resets are not possible.
                          I have opened the laptop and identified the main BIOS chip...
                          10-24-2025, 01:35 AM
                        • Forest79
                          by Forest79
                          However, the chip (a Macronix MX25L25673GMI-08G) has a size of 32 MB, and the BIOS file from the Lenovo website (extracted with UEFITool) has a little more than 16 MB. Thus, the software my acquaintance used (SiberiaProg v1.45, with a CH341A Programmer)...
                          07-23-2023, 07:39 AM
                        • survivalbloke
                          Unable to extract bios file from Lenovo bios exectuable
                          by survivalbloke
                          I'm trying to extract a flashable bios file(ch341a) from the lenovo bios executable download. I have tried the instructions from this site https://starkeblog.com/lenovo/uefi/2...pdate-exe.html, which are not working. According to those instructions, after issuing the command
                          Code:
                          "innoextract 7wcn38ww.exe"
                          it should create an \app folder, inside which, I should find a newly created "7wcn38ww.exe" file. I should then be able to extract that using 7zip and find my .FD file.
                          The trouble I'm having is that I'm not getting the newly...
                          06-12-2024, 07:55 AM
                        • maanee11
                          Help to get Lenovo BIOS bin file for Thinkpad T560
                          by maanee11
                          Hello Everyone,
                          I have Thinkpad T560 Which has corrupted BIOS. I have acquired Ch341A SPI flasher to program the BIOS externally. I see that to program the BIOS, i need a bin file for the BIOS. I was able to extract the .exe file of BIOS from Lenovo given here in this link:
                          https://pcsupport.lenovo.com/au/en/p...me=BIOS%2FUEFI
                          In the extracted files, I see that BIOS containing file has extension .FL1 and I need to extract or convert it...
                          05-15-2022, 11:59 AM
                        • mafioso3
                          lenovo x13 yoga gen1 EC bios file from (npce388)
                          by mafioso3
                          hello
                          i'm looking for lenovo x13 yoga gen1 EC bios file from (npce388)
                          i have already downloaded the bios file from lenovo website ,but after decompressing the EXE file,i only got FL1,no way to extract EC from it.
                          could someone please upload a unlocked npce388 EC file?
                          thanks in advance
                          SOLVED
                          03-13-2023, 02:20 AM
