HP EliteBook 830 G8 bios password
  • J4ckBurton
    • Nov 2022
    • 3
    • Puebla
    Hi guys,
    could you please help me to remove password from my HP elitebook 830 g8?
    HP EliteBook
    830 G8
    SN#5CG1426T57
  • hardware1
    • Sep 2021
    • 2936
    • N/A
    Re: HP EliteBook 830 G8 bios password
    Originally posted by J4ckBurton
    Hi guys,
    HP EliteBook
    830 G8
    SN#5CG1426T57
    Upload your EC file, and someone will help you.
    all donations are welcome,
    • J4ckBurton
      • Nov 2022
      • 3
      • Puebla
      thank you for your reply.
      How can i do it?
      thanks
      • hardware1
        • Sep 2021
        • 2936
        • N/A
        How can i do it?
        thanks
        If you are not familiar with taking a backup bios from your device, you can read this tread.
        https://www.badcaps.net/forum/showpo...40&postcount=2
        If you can do a backup but you can't upload it, you can follow the images.
        • Akintunde
          • Mar 2017
          • 154
          • Nigeria
          Good Day Everyone, Please I have HP EliteBook 830 G8 that i want to disable the computrace. My question now is that, which one should i upload . Main bios or Ec file?.
          • hoaca388
            Badcaps
            • Jan 2022
            • 11794
            Both.
            • Tosebeee
              • Aug 2023
              • 10
              • Nigeria
              HI I NEED MY BIOS FIXED, CAN SOMEONE HELP ME ? TURNS ON AND OFF IMMIDIATELY NOT TURNING UP AGAIN DC LIGHT BLINKING FOR SECONCE AND STOP
              HP 830 G8
              SN 5CG30342DH
              HERE IS MY BACK UP
              • hoaca388
                Badcaps
                • Jan 2022
                • 11794
                HP 830 G8
                SN 5CG30342DH
                HERE IS MY BACK UP
                HP EliteBook 830 G8 Notebook PC IDS Base Model
                SN 5CG30342DH​
                • Tosebeee
                  Tosebeee commented
                  Editing a comment
                  Good day sir , after programming with the new bios., the system post and restart continuously after showing hp pls hep me fix the file I will be grateful sir
              • Tosebeee
                • Aug 2023
                • 10
                • Nigeria
                Thanks I will update you sir
                • Tosebeee
                  • Aug 2023
                  • 10
                  • Nigeria
                  SN 5CG30342DH​
                  pls help me on this bios
                  • hoaca388
                    Badcaps
                    • Jan 2022
                    • 11794
                    If not work , you should look for hardware problems.
                    • Tosebeee
                      • Aug 2023
                      • 10
                      • Nigeria
                      Thanks for the reply sir i appreciate you always I will update you sir
                      • volinakis
                        • Jan 2021
                        • 2734
                        • N/A
                        Hi, I need help with bios for HP EliteBook 830 G8, s/n: 5CG1265KKN. It does not start, checking with UEFITool it has a lot of errors, ME Region doesn't exist anymore. I did try with bios from #11, it starts after long time, ME is in Recovery Mode, it shows a message at startup that ME is corrupted, tried with CSME System Tool v15.0 to update ME Firmware but it shows FW Update is disabled and use MEBX to enable FW Update. Also tried to enable Intel PTT with FIT 15.0 but same error, can't enter in MEBX - tried with Ctrl-P and F6.
                        Thanks in advance!
                        • qayyum786
                          • Aug 2018
                          • 1933
                          • INDIA
                          Thanks in advance!
                          Try
                          • iori1881
                            • Sep 2023
                            • 54
                            • United Kingdom
                            hello
                            i need to unlock bios password for my elitebook 830 g8
                            S/N: 5CG225297G
                            THANK YOU
                            • alfredposadas09
                              • Aug 2020
                              • 343
                              • Philippines
                              Originally posted by iori1881
                              hello
                              S/N: 5CG225297G
                              THANK YOU
                              HERE IS YOUR UNLOCKED FILE
                              • iori1881
                                • Sep 2023
                                • 54
                                • United Kingdom
                                thank you very much ...working good.
                                thanks again
                                • shukys
                                  • 31
                                  HP Elitebook 830 G8
                                  SN 5CG21519Z1
                                  6050A3426501-MB-A02
                                  • shukys
                                    • 31
                                    And the second dump file
                                    • shukys
                                      • 31
                                      Please help to unlcok bios for :
                                      HP Elitebook 830 G8
                                      SN 5CG21519Z1
                                      6050A3426501-MB-A02
                                      Dump files are in posts: #18 and #19
                                      Thank you
                                      • traxformania
                                        TONGFANG "GM7TG7P" Bios Password Problem?
                                        by traxformania
                                        I tried :
                                        -I removed the BIOS battery and main battery. Waited for a long time but it didn't work. They already stated in the user manual that the password will not be reset even if the batteries...
                                        11-15-2023, 07:32 AM
                                      • AlexRaspberry
                                        HP Elitebook X360 1030 G3 remove password BIOS.
                                        by AlexRaspberry
                                        Password removal option for those who do not have a method through HPUnlocker.
                                        This option saves all information in the BIOS (serial number, Windows key, etc.) and also excludes the appearance of BIOS notifications at startup (hp endpoint security controller problem).
                                        1. Read BIOS (32MB) and EC (16MB) firmware.
                                        Be sure to make backups.
                                        2. EC:
                                        2.1) Copy the area from the original and paste into a clean "EC (16MB) Clean".
                                        Region start - 0, length - DA3000
                                        2.2) Find in "EC (16MB) Clean" and...
                                        09-13-2021, 12:38 PM
                                      • Nopslide
                                        by Nopslide
                                        04-01-2024, 04:27 PM
                                      • beBoss
                                        HP ProDesk 400 G6 mini - BIOS Password attempt to remove it
                                        by beBoss
                                        as noobie to this please excuse my lack of experience.
                                        I am trying to remove a BIOS password from this machine:
                                        HP ProDesk 400 G6 Mini
                                        but so far I still have no success.
                                        I bought CH341 programmer and decided to give it a try.
                                        The programmer came with 8 pin cables and connectors or whatever everything else is called so I had to buy a new 16 pin cable because the chip which I think is the BIOS is with 16 pins..
                                        I connected everything and downloaded AsProgrammer and NeoProgrammer then installed drivers...
                                        05-30-2024, 12:48 PM
                                      • BlackVisor
                                        How to Decode BIOS password for RedmiBook Pro15 2022 6800H
                                        by BlackVisor
                                        RedmiBook Pro 1542022 6800H
                                        SKU: TM2113-39463
                                        Model Number: RMA2204-AB
                                        CMIIT ID: 2022AP1835
                                        SN: 39463/22WD01355
                                        BIOS version: RMARB5B0P1010 20230628
                                        1. I bought this laptop from flea market, and the seller said that he had never set a password, however here is a password required when pressing F2 to enter BIOS.
                                        2. And after entering incorrrect password 3 times, there is no any useful information like "recovery code"
                                        3. I used universal bios backup tool, and dumped 8MB bin file, but hex code after "SystemSupervisorPw" is...
                                        01-14-2024, 06:35 AM
