lenovo thinkpad l14 gen 1
    Re: lenovo thinkpad l14 gen 1
    Originally posted by hoaca388 View Post
    CH341A can not read/write EC/IO chip.
    What programmer should I buy?
      HI
      Please anybody know vich programmer read io nuvoton NPCE 68APAODX
        Master help to unlock this file. TIA master
        Main bios is 32mb
        EC bios is 1mb
          i have one, its AMD ryzen, power blink 3 times, and not turn on, bios or IO problem?
            Help!! Thinkpad L14 Gen1 Detecting and removing Absolute persistence
            Need Bios Backup thinkpad l14 gen1 without asolute persistence module .thanks
              Hello need to remove pass from ec dump.Thanks.
                full model of the board and also serail number
                  SB20W48120L1HF17602XP S20U2S3MD00PF31N2E
                  try
                    BN - NM-C631 REV 1.0
                    SN - PF-23YDER
                    orgnl file attached
                      SMDFlea commented
                      Editing a comment
                      Thread merged.
                    #30
                    hi,
                    i have a locked T14 gen1. Serial number can't be read unfortunately(the sticker is torn) , i don't know what details to give you in such case, except the board is NM-C631.
                    I managed to read the Nuvoton NPCE68 with SVOD4, i attach the file.
                    I tried to remove the password by comparing with the file for SSDD that MAXpower3 gave.
                    Now it gives me "bad SVP data" error and shuts down. I also attach the file i modified.
                    Please help me
                    Later edit: i also modify only the areas that Maxpower mentioned (3C420 to 3C45F and 3D420 to 3D45F) and also, BAD SVP.
                      SMDFlea commented
                      Editing a comment
                      posts moved from L15 topic to L14 Gen 1
                    #31
                    Originally posted by babydoll8867 View Post
                    hi,
                    Please help me
                    your serial is in EC dump: PF1T6YFJ
                    try this file
                      Volinakis, I got rid of SVP error but it still asks for password (Did the programming with internal and CMOS battery connected and after programming i immediately disconnect both batteries)
                        there are bits everywhere in the L series, I don't understand
                          you should look at my posts, once I made a file for L14/15, there was an error but he managed to enter the setup and do F9. but I don't know anymore or know
                            attached file with Absolute Persistence issue.
                            L14 GEN1
                            NM-C631 REV 1
                            SN: PF2W4LTP
                            thanks..
                              L14 GEN1
                              NM-C631 REV 1
                              SN: PF2W4LTP
                              thanks..
                              hi try and feedback
                                Originally posted by shiyab View Post
                                hi try and feedback
                                thank you.. it works, but it took around 44secs for the display to come out... can you clean the ME region?
                                  why so many changes in the file. it doesn't work with only 1 byte??
                                    hi try
                                      I wrote the file you gave me, still SVP error.... i will look through your posts now
