lenovo thinkpad l14 gen 1
  • Syavko1
    • Mar 2022
    • 53
    • Ivano-frankivsk
    Re: lenovo thinkpad l14 gen 1
    Originally posted by hoaca388
    CH341A can not read/write EC/IO chip.
    What programmer should I buy?
    • salim1gr
      • Oct 2018
      • 22
      • Sweden
      HI
      Please anybody know vich programmer read io nuvoton NPCE 68APAODX
      • smallvhin
        • Jul 2015
        • 183
        • philippines
        Master help to unlock this file. TIA master
        Main bios is 32mb
        EC bios is 1mb
        • judamex
          Active Member
          • Jan 2021
          • 183
          • Mexico
          i have one, its AMD ryzen, power blink 3 times, and not turn on, bios or IO problem?
          • gsmcaleb
            • May 2022
            • 10
            • Philippines
            Help!! Thinkpad L14 Gen1 Detecting and removing Absolute persistence
            Need Bios Backup thinkpad l14 gen1 without asolute persistence module .thanks
            • Desertearch
              • Apr 2016
              • 7
              • West Side
              #26
              Hello need to remove pass from ec dump.Thanks.
              • kalilinux25
                • Mar 2018
                • 2089
                • ZAMBOANGA SIBUGAY
                #27
                full model of the board and also serail number
                • Maxpower3
                  Bad Veteran
                  • Feb 2018
                  • 1226
                  • France
                  #28
                  SB20W48120L1HF17602XP S20U2S3MD00PF31N2E
                  try
                  • mactouch
                    • Nov 2018
                    • 86
                    • abudhabi
                    #29
                    BN - NM-C631 REV 1.0
                    SN - PF-23YDER
                    orgnl file attached
                      SMDFlea commented
                      Editing a comment
                      Thread merged.
                  • babydoll8867
                    • Nov 2014
                    • 91
                    • romania
                    #30
                    hi,
                    i have a locked T14 gen1. Serial number can't be read unfortunately(the sticker is torn) , i don't know what details to give you in such case, except the board is NM-C631.
                    I managed to read the Nuvoton NPCE68 with SVOD4, i attach the file.
                    I tried to remove the password by comparing with the file for SSDD that MAXpower3 gave.
                    Now it gives me "bad SVP data" error and shuts down. I also attach the file i modified.
                    Please help me
                    Later edit: i also modify only the areas that Maxpower mentioned (3C420 to 3C45F and 3D420 to 3D45F) and also, BAD SVP.
                      SMDFlea commented
                      Editing a comment
                      posts moved from L15 topic to L14 Gen 1
                  • volinakis
                    • Jan 2021
                    • 2734
                    • N/A
                    #31
                    Originally posted by babydoll8867
                    hi,
                    Please help me
                    your serial is in EC dump: PF1T6YFJ
                    try this file
                    • babydoll8867
                      • Nov 2014
                      • 91
                      • romania
                      #32
                      Volinakis, I got rid of SVP error but it still asks for password (Did the programming with internal and CMOS battery connected and after programming i immediately disconnect both batteries)
                      • Maxpower3
                        Bad Veteran
                        • Feb 2018
                        • 1226
                        • France
                        #33
                        there are bits everywhere in the L series, I don't understand
                        • Maxpower3
                          Bad Veteran
                          • Feb 2018
                          • 1226
                          • France
                          #34
                          you should look at my posts, once I made a file for L14/15, there was an error but he managed to enter the setup and do F9. but I don't know anymore or know
                          • salawayon
                            • Nov 2012
                            • 572
                            • philippines
                            #35
                            attached file with Absolute Persistence issue.
                            L14 GEN1
                            NM-C631 REV 1
                            SN: PF2W4LTP
                            thanks..
                            • shiyab
                              • Sep 2023
                              • 1483
                              • india
                              #36
                              L14 GEN1
                              NM-C631 REV 1
                              SN: PF2W4LTP
                              thanks..
                              hi try and feedback
                              • salawayon
                                • Nov 2012
                                • 572
                                • philippines
                                #37
                                Originally posted by shiyab
                                hi try and feedback
                                thank you.. it works, but it took around 44secs for the display to come out... can you clean the ME region?
                                • Maxpower3
                                  Bad Veteran
                                  • Feb 2018
                                  • 1226
                                  • France
                                  #38
                                  why so many changes in the file. it doesn't work with only 1 byte??
                                  • shiyab
                                    • Sep 2023
                                    • 1483
                                    • india
                                    #39
                                    hi try
                                    • babydoll8867
                                      • Nov 2014
                                      • 91
                                      • romania
                                      #40
                                      I wrote the file you gave me, still SVP error.... i will look through your posts now
                                        Lenovo ThinkPad X1 Carbon + ThinkPad USB 3.0 Pro Dock Notebook X Specification for Upgrade or Repair
                                        This specification for the Lenovo ThinkPad X1 Carbon + ThinkPad USB 3.0 Pro Dock Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the X1 Carbon + ThinkPad USB 3.0 Pro Dock boardview and X1 Carbon + ThinkPad USB 3.0 Pro Dock schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please...
                                        09-06-2024, 11:40 AM
