Samsung NP680Z5E NP670Z5E (mb: NIKE2-15-DC) BIOS file required
  • Kazik
    • Oct 2016
    • 53
    I received Samsung NP680Z5E laptop for repair. It is charging the battery (charging light on, the voltage on the battery confirms the charging process), but the laptop won't switch on. 3.3V present on the BIOS chip. Power switch checked (however the voltage on the switch is just below 1V - I have no clue if this is the right voltage). Cable connection between the power switch/USB logic board and the main motherboard was checked and is OK. I have no schematic or boardview and I'm also not the greatest specialist in motherboard repair.
    I'm thinking that the NO POWER problem might be related to the BIOS problem, so before going further with diagnostics I would like to reprogram the BIOS chip and check if it's going to solve the problem.
    Does anyone have a BIOS dump for Samsung NP680Z5E?
    Laptop model: NP680Z5E-X01UK
    Motherboard: NIKE2-15-DC
    BIOS: 64Mb (8MB)
    • 21669
    Re: Samsung NP680Z5E (mb: NIKE2-15-DC) BIOS file required
    BIOS: 64Mb (8MB)
    Make a backup and post it here .
    • Kazik
      • Oct 2016
      • 53
      Thank you for a quick reply.
      The BIOS dump attached.
      • Pedro Ramírez
        • Jul 2024
        • 21
        • Chile
        Hello dear colleagues, could you please help me with this corrupt BIOS? 🙌
        Please I can't get my file to work.
        Samsung NP670Z5E-X01CL
        S/N: JE9Z91HD400818N
        MB: NIKE2-15_DC
        • peste
          • Dec 2016
          • 13421
          • ROMANIA
          MB: NIKE2-15_DC
          try..
          • Pedro Ramírez
            • Jul 2024
            • 21
            • Chile
            Excuse my question. Is this a file ready to use in my BIOS IC? I'm deeply grateful for your help.
            • peste
              • Dec 2016
              • 13421
              • ROMANIA
              yes..write it on the chip and test it...
              • Pedro Ramírez
                • Jul 2024
                • 21
                • Chile
                It didn't work my dear friend
                • shiyab
                  • Sep 2023
                  • 1592
                  • india
                  MB: NIKE2-15_DC
                  hi try
                  • Pedro Ramírez
                    • Jul 2024
                    • 21
                    • Chile
                    Originally posted by shiyab
                    hi try
                    Hello dear friend, thanks for the BIOS. It worked for me, but I've solved some problems: it doesn't recognize the GPU, and it doesn't recognize the MB and serial number information. What can I do to fix this?
                      • 21669
                      try this one.
                      • Citymin
                        by Citymin
                        S/N : 5RNK9FFT70...
                        08-05-2025, 05:12 AM
                      • iZakre
                        HP Pavilion 15 bc400ns - Complete Black Screen - Only video on live usb
                        by iZakre
                        Hello everybody!
                        To put you in context I recently replaced the battery from my HP Pavilion 15 bc400ns with a used one, everything was going good. The same day, I decided to update the BIOS, everything went good. The thing occurred after I let the battery drain iddling on Windows 11 for the second time to calibrate it that the screen did not turn on again, the computer was on but the screen did not turn, like it would not wake from hibernation. I decided to restart the computer but got no video.
                        The thing is that I had installed TeamViewer and could log into the computer...
                        02-19-2023, 02:27 PM
                      • m1ch43lzm
                        Notice to users of XGecu TL866II Plus / T48 / T56 / T76 programmers regarding BIOS backup file size
                        by m1ch43lzm
                        Hi everyone
                        I noticed on the Xgpro software the BIOS backup files have extra bytes at the end when reading some chips, this is because the Xgpro software also reads the OTP region of those flash chips, and by default will append that region to the saved file
                        Programmer models: XGecu TL866II Plus / T48 / T56 / T76
                        Example: GD25LQ128D (1.8V), IC size is listed as 0x1000000 Bytes (16777216 bytes) + 0xC00 bytes, those extra 0xC00 bytes will be appended to the end of the saved file by default, resulting in a file size of 16780288 bytes
                        There's also an extra OTP Secu.R...
                        09-06-2025, 05:47 PM
                      • Citymin
                        Samsung NT750QCJ or NP750QCJ(Galaxy Book Flex Alpha) Bios File Please.
                        by Citymin
                        HI all.
                        I need Bios dump File for
                        NT750QCJ or NP750QCJ(Galaxy Book Flex Alpha - 15inch).
                        My Samsung Galaxy Book laptop Flex Alpha has no display and won't boot.
                        09-14-2025, 06:12 PM
                      • Wutru
                        HP Elitebook 820 G4 BIOS repair assistance required
                        by Wutru
                        Hi guys,
                        If someone would be able to provide some expertise, I'd be very grateful.
                        BIOS Corruption - Cause
                        So I managed to corrupt my machine by installing linux and enrolling custom secure boot keys. I did choose to enroll the Microsoft keys as well, to prevent any potential bricking due to 3rd party drivers from HP being signed with those keys.
                        After doing that, and rebooting(it did boot, powerLED, fanspin etc.), the laptop did not give any video output on the LCD or video connectors. I think I was able to get in BIOS and trigger the beeper by pressing ESC....
                        09-06-2025, 10:32 AM
