Dell Latitude 5430, LA-L591P Computrace setting unlock
  • rex98
    • Feb 2023
    • 1278
    • Mandaue CEBU, Philippines
    #281
    Originally posted by maf2003
    Can someone help clear Dell 5430 LA-L591P with BIOS admin password and Computrace enabled?
    1st boot, press F2, write service tag, disable Absolute, save (Apply changes), restart. 2nd boot press Alt+F to exit manufacturing mode.
    • maf2003
      • Jan 2021
      • 28
      Thank you so much, that worked.
      • Atillaoracle
        • May 2024
        • 13
        • Ireland
        #283
        Hi, unlock bios latitude 5430
        8FC8
        Please
        Not sure if i did it right as i used a clip
      • Blaze Tech
        Learner
        • 205
        • Ghana
        #284
        8FC8
        Please
        Write your Service Tag
        • Atillaoracle
          • May 2024
          • 13
          • Ireland
          #285
          55LJ2T3
          • hoaca388
            Badcaps
            • Jan 2022
            • 11732
            #286
            8FC8
            Please
            Read chip again , backup fail.
            • Atillaoracle
              • May 2024
              • 13
              • Ireland
              #287
              thanks, i did again, can u please check
              • hoaca388
                Badcaps
                • Jan 2022
                • 11732
                #288
                A successful backup file, after compression, has a capacity calculated in MB, not KB.
                • Atillaoracle
                  • May 2024
                  • 13
                  • Ireland
                  #289
                  Thanks for the reply, i even solder the chip to CH341A and i can read. When i save the capacity is 1 MB.
                    • 20873
                    Don`t use the programmer Auto-detect ,choose the chip manually. Are you using the recommended NeoProgrammer software ? .What is the part number on top of the chip
                    • Atillaoracle
                      • May 2024
                      • 13
                      • Ireland
                      #291
                      I used Asprogrammer and Ch341a V2.2.0.0 both gives the same result. The part number is W25Q80BV
                      • Atillaoracle
                        • May 2024
                        • 13
                        • Ireland
                        #292
                        I just did with the Neopragrammer and still 1MB
                          • 20873
                          W25Q80BV is not the bios chip,it is somewhere else on the motherboard
                          • Atillaoracle
                            • May 2024
                            • 13
                            • Ireland
                            #294
                            Ups, Thank you. I will try to locate it
                            • Atillaoracle
                              • May 2024
                              • 13
                              • Ireland
                              #295
                              is that the bios chip? I searched online but could not verify
                              thanks
                              • hoaca388
                                Badcaps
                                • Jan 2022
                                • 11732
                                #296
                                thanks
                                Good job.
                                • Atillaoracle
                                  • May 2024
                                  • 13
                                  • Ireland
                                  #297
                                  Good job.
                                  Dell Latitude 5430 bios password and the Computrace as well?
                                  I would be grateful
                                  Latitude 5430
                                  LA-L591P
                                  ST: 55LJ2T3
                                  original file is 16 MB but when archived its 67 KB.
                                  There is another chip with the name 25q256jven but the chip legs does not look like bios chip.
                                  Thanks in Advance​
                                  • hoaca388
                                    Badcaps
                                    • Jan 2022
                                    • 11732
                                    #298
                                    W25Q128JV and W25Q256JVEN are both bios chips.
                                    • PycLaH
                                      • Feb 2022
                                      • 28
                                      good day. plz can anyone help me with BIOS file. i made dump of original Bios , but every time i upload it i got this :
                                      power btn lights comes on, charging light comes on white. and no display , no fan spin. after a while i have few white blinks (charging light-4 times) and power lights goes off
                                      used to work fine be4.
                                      Please help - This is Dell Latitude 5430 Laptop . i5 16GB ram, STAG: FB1Z0T3
                                      is anyone can check my bios file dump and set it up to manufacture mode . no password in the dump.
                                      Thanks a lot
                                      • hoaca388
                                        Badcaps
                                        • Jan 2022
                                        • 11732
                                        #300
                                        Thanks a lot
                                        Post chip 16MB .
                                        • kaput
                                          Lenovo Thinkcentre M720q, disable activated Computrace
                                          by kaput
                                          Not a BIOS request per se, but closely related. Please bear with me
                                          A while ago I found an old Lenovo Thinkcentre M720q in pieces in the electronics scrap bin at work. There was only some minor damage to the case, so collected everything and brought it home to let it dry and see if it still worked. It did
                                          Unfortunately Computrace has been activated on it. Since I'm using it as an emulation console with Lakka now, it's no big deal, but would be nice to get rid of the annoying message popping up when entering the UEFI setup, and also learn something along the way....
                                          06-28-2024, 09:36 AM
                                          HP xw6600 Intel Xeon Quad Core 5430 2.66GHz 2GB/250GB No Graphics DVD+/-RW WVST Bus Workstation E5430 Specification for Upgrade or Repair
                                          This specification for the HP xw6600 Intel Xeon Quad Core 5430 2.66GHz 2GB/250GB No Graphics DVD+/-RW WVST Bus Workstation can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the xw6600 Intel Xeon Quad Core 5430 2.66GHz 2GB/250GB No Graphics DVD+/-RW WVST Bus Workstation boardview and xw6600 Intel Xeon Quad Core 5430 2.66GHz 2GB/250GB No Graphics DVD+/-RW WVST Bus Workstation schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated...
                                          09-12-2024, 03:36 PM
                                          DELL Latitude 5430 Notebook 5000 Specification for Upgrade or Repair
                                          This specification for the DELL Latitude 5430 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 5430 boardview and 5430 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for DELL Latitude 5430...
                                          09-07-2024, 06:31 AM
                                        • Syseng
                                          Lenovo P14s Gen 5 SVP unlock
                                          by Syseng
                                          This sums up discussion related to Lenovo P14s Gen5 in this thread. Credits go to Sbaro and especially Maxpower3. The locked dump is attached.
                                          The device is based on NM-F871 motherboard with Nuvoton NPCK397 series controller. The motherboard also contains three BIOS chips: two different Winbond chips for main BIOS and external EC flash, and also a Gigadevice chip which purpose I do not know. The password information is contained directly in controller and thus can be manipulated by reprogramming it, so reprogramming BIOS chips is technically not required, however you may wish to make...
                                          06-22-2025, 07:44 AM
