Dell latitude 7410 8fc8 bios password
  • omruu9
    • Apr 2016
    • 70
    Hello friends I have dell latitude 7410 bios password with 8fc8 suffix any friend can remove locked bios attached service tag is : 6PZH253
  • hardware1
    • Sep 2021
    • 2948
    • N/A
    Re: Dell latitude 7410 bios password
    Try this one.
    all donations are welcome,
    • magictouch
      • Apr 2021
      • 108
      • united kingdom
      Have dell Latitude 7410 Bios is locked Can someone Please unlock this File For me, I will Be Very Grateful.
      Regards
      • hardware1
        • Sep 2021
        • 2948
        • N/A
        Regards
        Try this file, i hope it works for you.
        • magictouch
          • Apr 2021
          • 108
          • united kingdom
          Thanks, Alot Mate It Worked, you are an Absolute Gem.
          • feherhollo
            • Nov 2019
            • 110
            • Hungary
            Please unlock my 7410 locked bios.
            LA-J261P 8FC8
            • hardware1
              • Sep 2021
              • 2948
              • N/A
              LA-J261P 8FC8
              Here's your Unlocked, try and give me the results.
              • hoaca388
                Badcaps
                • Jan 2022
                • 12347
                There is one more unedited offset.
                ​https://www.badcaps.net/donate
                • hardware1
                  • Sep 2021
                  • 2948
                  • N/A
                  I can't describe it correctly, but i had done it before and people said it's working fine. I found 3 offsets so i had just edited 2 (one opposite one), but when i edit a single offset without an opposite one they say it didn't works.
                  • feherhollo
                    • Nov 2019
                    • 110
                    • Hungary
                    Perfect! Work like a charm! Thanks
                    • sudhakar.sanet
                      • Mar 2014
                      • 27
                      • India
                      hi
                      pls unlock password on this file
                      • hardware1
                        • Sep 2021
                        • 2948
                        • N/A
                        Originally posted by sudhakar.sanet
                        hi
                        Here's your Unlocked file, try it.
                        • bushmann
                          • Feb 2014
                          • 147
                          • Slovakia
                          Hi .
                          Please can you help me with unlock this BIOS admin password
                          Thx
                          • Ali5914
                            • Dec 2020
                            • 48
                            • India
                            Originally posted by bushmann
                            Hi .
                            Thx
                            Please check your attached file. No bios dump attached. Please reattach the old bios and upload again....
                            • bushmann
                              • Feb 2014
                              • 147
                              • Slovakia
                              Ups my mistake.
                              New correct file is uploaded .
                              • volinakis
                                • Jan 2021
                                • 2874
                                • N/A
                                Ups my mistake.
                                try
                                • bushmann
                                  • Feb 2014
                                  • 147
                                  • Slovakia
                                  Originally posted by volinakis
                                  try
                                  Thank you very much.
                                  All works fine.
                                  Can you tell me what software you used to unlock it.
                                  If there is any software.
                                  • volinakis
                                    • Jan 2021
                                    • 2874
                                    • N/A
                                    All works fine.
                                    there is no software, just edited with iHex 4bytes to put it in factory mode. Compare your file with modified one and you'll figure out. (use HxD for win).
                                    • bushmann
                                      • Feb 2014
                                      • 147
                                      • Slovakia
                                      Yes, that's what I noticed when I compared the original and edited file in the hex editor.
                                      But I see that each model has it in a different place.
                                      When I look at different files from the same model, it is in the same place.
                                      So it's enough if I download the original and modified file for the same model, find the difference and modify it in my file and it will work.
                                      • estoyentucasa
                                        • Oct 2022
                                        • EspaƱa
                                        Looking for the same here!
                                        Apreciate your help guys!
                                        • gizaha
                                          by gizaha
                                          02-13-2024, 07:18 AM
                                          DELL Latitude 7410 Notebook 7000 Specification for Upgrade or Repair
                                          This specification for the DELL Latitude 7410 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 7410 boardview and 7410 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for DELL Latitude 7410...
                                          09-06-2024, 08:10 PM
