Asus TP412FA-EC111T
  • danro
    • Aug 2011
    • 55
    • Serbia
    Asus TP412FA-EC111T
    I need help to clean ME for this dump. I haven't find CSME 14.0.64.1551 firmware and don't know how to extract from new bios (downloaded from ASUS site)
    Please clean this original or guide me how to extract from installer file.
    Thank you
  • cacla
    • Apr 2015
    • 444
    Re: Asus TP412FA-EC111T
    Hi there is 2 models TP412FA here is one if this bios dont work i will need the sn form your unit.
    • danro
      • Aug 2011
      • 55
      • Serbia
      thanks for help!
      dump ok, problem solved
      • mkdj
        by mkdj
        Dear all,
        10-19-2025, 04:41 AM
      • kodox
        Asus ExpertBook B1400CB Bios Dump Needed
        by kodox
        need original bios dump, original bios has flashed by other technician before me.
        attached bios was read from the chip but no display and amperage fluctuating from 0.6A to 0.34 and back to 0.6A.
        unit info:
        Model: Asus ExpertBook B1400CBA-0711A1235U
        S/N: R6NXNZ006657238
        CN: 7F6F
        Mainboard Code: B1500CBA R2.1...
        08-16-2025, 12:20 PM
      • kcp0085
        Request BIOS dump for ASUS FA617NS
        by kcp0085
        Aloha, I'm trying to recover my ASUS TUF Gaming A16 (FA617NS-A16.R77600)
        I have the CH341A programmer and can flash the BIOS chip directly. I need a verified full .bin dump (2MB or full SPI region) for this specific model.
        Specs:
        - ASUS TUF FA617NS-A16
        - CPU: AMD Ryzen 7
        - BIOS chip: Winbond W25Q16JVSIQ (2MB)
        If anyone has a full dump or can share from a working unit, it would be hugely appreciated.
        Thanks in advance!
        05-02-2025, 12:52 AM
      • Tamo Neko
        Request for MX25VB8035F (1MB) Firmware Dump – Asus TUF Gaming H670-Pro
        by Tamo Neko
        I'm working on an Asus TUF Gaming H670-Pro motherboard and need help finding a firmware dump for the MX25VB8035F (1MB) SPI flash chip.
        What Happened:
        I mistakenly removed and erased this 1MB chip, thinking it was part of the main BIOS.
        • I later found that the board has two main BIOS chips (8MB + 16MB), which I have backups for.
        • My backup for the MX25VB8035F chip is just an empty 1MB segment filled with FFs, meaning I have no valid data to restore.
        What I Need:
        • A firmware dump for the MX25VB8035F chip from the same motherboard (or a compatible
        02-12-2025, 11:29 PM
      • Anchar777
        ASUS P1412CE need BIOS DUMP
        by Anchar777
        Sorry for creating a second post, I didn't understand how to fix the error in the message. I need help, laptop ASUS P1412CE (P1411CEA-EK0395X) SN: N4NXCV033901146. There was a failure during BIOS flashing, and the laptop stopped turning on. The original, non-working BIOS is attached. Unfortunately, I was unable to correctly generate the BIOS from what is presented on the Asus website. Help me make a dump. Thank you....
        06-26-2025, 03:39 AM
