Need bios for Lg Gram 1XZ90
  • Francisco.s
    • 686
    • Spain
    Hi, need bios dump for Lg Gram 1XZ90 main b/d pcb rev 1.2
    This is the old one:
  • hoaca388
    Badcaps
    • Jan 2022
    • 11691
    Re: Need bios for Lg Gram 1XZ90
    There is no bios for your model on the LG homepage. Try this clean ME file (this is your bios file with ME region cleaned)
    • Francisco.s
      • 686
      • Spain
      Hi hoaca388, thanks for your help.
      I have tested the cleaned bios and it behaves the same as before.
      I can measure a few pulses at pin 1 of flash chip and also all voltages rise, but power comsumtion is very low. (about 60 mili amps)
      After all tests with the cleaned dump, I have reread it and all data in bios are there without any byte change. Seems that pch doesn't modified the ME region.
      Probably the board have other problem, or the bios is corrupted in other part than ME region.
      I will try to get de schematic for this board and measure plt_rst and other related signals.
      Perhaps i will be lucky and get the schematic, or somebody in the forum have another good bios
      Many thanks for your effort.
      • laptopgreen
        • Aug 2017
        • 18
        • VN
        Thanks hoaca388. Bios working perfect for me.
        • Habble7
          by Habble7
          Suspected Cause:
          Troubleshooting Attempts:
          05-22-2025, 07:28 AM
        • loopster
          Need help cleaning ME region on Zbook 17 G1 bios dump
          by loopster
          Hello guys,
          could I please get some help cleaning the ME region of the attached Zbook 17 G1 bios dump (CH341a, neoprogrammer, chip-desoldered, dumped twice, identical checksum)?
          Symptoms, delayed BIOS post (ca. 45 secs.) keyboard not working, touchpad not working, booting linux live, console says "Management engine not configured".
          I tried following the ME firmware cleaning guide, but whatever Flash Image Tool version I try, I get the same error:
          Error 10: Failed to open with processed commands.
          Unable to open file: C:\Users\Elitebook...
          06-16-2024, 09:57 AM
        • DynaxSC
          by DynaxSC
          11-17-2023, 10:56 AM
        • macabook
          by macabook
          🧩 Initial Issue
          07-24-2025, 02:17 PM
        • grimacelord
          Trying To Find UUID In BIOS Dump - HP 14-dq0055dx
          by grimacelord
          This laptop is the same laptop I was working on in this thread and I wasn't sure if I should post a new topic or post in that thread because I already solved the issue that thread was discussing and this is a completely different issue although it is dealing with the same laptop. I decided to make a new thread since it's a new issue, but please move if I made a mistake.
          Motherboard model number: DA0PAMB46A1 REV: A
          Secondary motherboard model number: 0PAB
          SKU: 685K4UA
          Serial number is: 5CD3223BJP
          Recently reflashed this laptop with latest BIOS and once...
          05-07-2024, 08:06 AM
