Help bios Lenovo T15 gen2 NM-D551 rev.03
  • fredyjbi
    • Feb 2021
    • 144
    • malaysia
    good night friends greetings success always! I ask for help for those who have the lenovo T15 gen2 NM-D551 rev.03 bios file, thank you
  • peste
    • 12734
    • ROMANIA
    Re: Help bios Lenovo T15 gen2 NM-D551 rev.03
    post the original bios even if it is corrupted
    • fredyjbi
      • Feb 2021
      • 144
      • malaysia
      Original bios dump no display
      • fredyjbi
        • Feb 2021
        • 144
        • malaysia
        Above the laptop's original bios is on but there is no display thank you much peste for the help
        • fredyjbi
          • Feb 2021
          • 144
          • malaysia
          help clean me bios nm-d551 rev 03
          Last edited by SMDFlea; 10-06-2022, 05:23 AM. Reason: Thread merged,bios removed already posted !!
          • lapfix
            • Mar 2020
            • 2719
            • my workshop
            Your serial number
            • fredyjbi
              • Feb 2021
              • 144
              • malaysia
              Mr. Lapfix sticker, the serial number on the case is gone, so I don't know what the serial number is! Thank you
              • fredyjbi
                • Feb 2021
                • 144
                • malaysia
                Need bios thinkpad T15p nm-d551 rev.03
                power on no display thanx's
                Last edited by SMDFlea; 10-10-2022, 12:56 PM. Reason: Thread merged,Bios removed already posted once.........
                • hardware1
                  • Sep 2021
                  • 2930
                  • N/A
                  Re: Need bios thinkpad T15p nm-d551 rev.03
                  This file is without DMI. if it works, you can write your serial number, and we will try to Replace it from the dump.
                  all donations are welcome,
                  • fredyjbi
                    • Feb 2021
                    • 144
                    • malaysia
                    thank you hardware one I will try and will give a report
                    • fredyjbi
                      • Feb 2021
                      • 144
                      • malaysia
                      Sir, I have tried the laptop so it won't turn on, can you help me fix my corrupted original bios, thank you
                      • fredyjbi
                        • Feb 2021
                        • 144
                        • malaysia
                        this laptop pack has 2 bios ic, the file you uploaded is for u2001 or u4402, thank you
                        • madrali
                          lenovo e15 gen2 bios ? problem
                          by madrali
                          Model: Lenovo ThinkPad E15 Gen 2 (Intel)
                          20TD-50S0KU00
                          Hi, my laptop suddenly shut down while it was running. When I try to turn it back on, the screen stays black and it emits a melodic beep.
                          I used Lenovo's SmartBeep decoder and it returned error 0284:
                          "TCG-compliant functionality-related error (possibly BIOS code validation failure)"
                          I then tried to enter crisis BIOS recovery mode by pressing Fn + R at boot. The melodic error code changes, but nothing else happens regardless of whether a USB is inserted. I receive another...
                          06-16-2025, 12:06 PM
                        • Wahaz
                          by Wahaz
                          10-30-2023, 08:42 PM
                        • grimacelord
                          by grimacelord
                          Hello there.
                          History:
                          03-15-2023, 03:29 PM
                        • jendkkd jeje
                          Lenovo IdeaPad 330 15-AST 81D6 BIOS Recovery
                          by jendkkd jeje
                          So a couple of years ago i got a bios update through Lenovo Vantage, so i installed it and bricked my whole BIOS, so i couldn't fix it so i put that ideapad in a box, 3 years later i found that one PC and want to recover it to switch from a 2014 hp laptop to this one.
                          I found a method to recover the BIOS of many lenovo laptops tha consists in pluging in a USB Flash with the BIOS files and power on the laptop with Fn + R keys pressed until fans go loud and start beeping loud, but nothing worked, so i think filename is wrong, i tried naming the bios file as 07WW.BIN, BIOS.BIN, BIOS.fd,...
                          10-11-2024, 03:12 PM
                        • mximiliandz
                          help bios lenovo ideapad s145-14iil type 81w6
                          by mximiliandz
                          Good morning, gentlemen, I hope you can help me with my laptop, I told you that I saved it about 2 years ago because it wouldn't turn on, now I have a ch341a programmer, I made a backup of the bios, I flashed an original downloaded from lenovo and it started, but it turned off after a few minutes, I entered the bios configuration and the brand, model, serial number, windows serial number, etc. did not appear, I request your help, I did everything I found in the forum but I could not solve it, also now it won't start again, it turns on but the fan does not turn, I will share all the information...
                          06-20-2025, 06:50 AM
