So i have a laptop i got and it has a custom company boot screen. could someone point me in the correct direction am guessing its in the bios somewhere.
T460S Boot screen
Tags: None
Re: T460S Boot screen
Extract the windows bios update (with innoextract) and read the "BIOS_LOGO.TXT" file.
You must enable bios rollback in bios settings if the update version is the same as you have.
.Last edited by SMDFlea; 09-28-2022, 08:56 AM.Comment
by kenkaniffProduct Name: HP Pro x360 Fortis 11-inch G9
System BIOS: U94 Ver.01.08.00 10/06/2023
Serial Number: 5CG31946F5
SKU Number: 85W05EC#AK8
Motherboard: ANOLE10-MV-TRIPOD / 6050A3332901-MB-A01 / 2021-11-09
This motherboard has 2 similar chips. One is on the front marked with BIOS SKT "Winbond 25Q256JVEN" and one on the back marked with U351 "Gigadevice 25B256EYIG". I ignored the one on the back and only desoldered front chip. Made a backup, made sure the reading was the same with another 3 backups.
I needed to remove bios password...-
Channel: BIOS Requests ONLY!
by EotisHi folks. I have a Framework 13 laptop with these specs.
Motherboard: Framework FRANBMCPOC AC
Processor: 11th Gen Intel® Core™ i7-1185G7 @ 3.00GHz 3.00 GHz
Graphics: Intel Iris xe
Installed RAM: 64.0 GB (63.8 GB usable)
System type: 64-bit operating system, x64-based processor
Bios: Uefi InsydeH20 3.24
Edition: Windows 11 Pro/ AtlasOS
Version: 23H2
Installed: 9/16/2024
OS build: 22631.4169
Intel Chipset driver: 10.1.19502.8391
This processor seems to...11-18-2025, 08:55 PM -
by throwaway327ASUS ROG Ally X - (Handheld Gaming PC)
Model No: RC72LA
Serial No: SBNVKD001014459
I used a tool called 'Smokeless-UMAF' to access usually hidden settings in the bios. I tweaked one or two 'safe' things but made the mistake of tweaking a lot of settings under 'USB/Thunderbolt Configurations' when I didn't know what they did. For...-
by Max029I've searched and read Beginners guidelines and other sticky threads. This is just a simple bios question. If I may, I'm having trouble finding any help, including from lenovo tech support & forum, for how to get usb boot to list in boot options. I'm trying to run memtest86 so nothing as highfaluting as re-install, flash a bios, etc.
I've made usb boot enabled and secure boot is disabled. I can find no other option in bios ver LZCN34WW (the original bios). Would anyone here be familiar with LOQ or Legion bios versions & know what is going on?
TY,
by iZakreHello everybody!
To put you in context I recently replaced the battery from my HP Pavilion 15 bc400ns with a used one, everything was going good. The same day, I decided to update the BIOS, everything went good. The thing occurred after I let the battery drain iddling on Windows 11 for the second time to calibrate it that the screen did not turn on again, the computer was on but the screen did not turn, like it would not wake from hibernation. I decided to restart the computer but got no video.
The thing is that I had installed TeamViewer and could log into the computer... - Loading...
