Lenovo ThinkBook 14 G2 ITL FLV34 LA-K051P bios
  • 147369258
    replied
    Originally posted by hoaca388 View Post
    ThinkBook 14 G2 ITL Laptop - Type 20VD
    UT2 is not bios chip
    Unfortunately, the laptop did not boot with these files. I probably found the backup files. I will upload them again. Please fix it. It does not boot with these either. Thanks.
  • hoaca388
    replied
    Originally posted by 147369258 View Post
    Please help me. I received a ThinkBook model 14 G2ILT S/N:MP1YTF5G
    MTM:20VD0034US
    MO:MPNXB131170JV. I didn't have a backup BIOS. I programmed all three IC UC3-XM25QH128A-UC12-XM25QH64A-UT2-W25Q80. The laptop turned on, but it showed a blank image. The bigger problem is that it doesn't recognize the SSD drive. Is there a way to solve this problem? If you can send me the correct files, thank you.
  • 147369258
    replied
    MTM:20VD0034US
  • Frank Walter
    replied
    Originally posted by danito View Post
    What's the problem with this bios?
    The Power LED turns on white, the ESC + Shift LED turns on white and nothing happens. No Display no fan spinning and all leds keep white until i disconnect it from power.
    Shift LED turns off after 5-6 Seconds and if i kill it with 10s power button the next start the white power led keeps turning on and off every 5 seconds.
    Do you know anything thats wrong? Charing works and no burns, black components or other sings of failure.
    Thank you for the fast reply.
  • danito
    replied
    Originally posted by Frank Walter View Post
    Could you fix my main bios and ec bios chip bins as well please?
    MODEL NAME :THINKBOOK 14 G2 ITL
    FLV34 LA-K051P REV:1B
    S/N: MP1Y104Z
    MTM: 20WE0009GE
  • Frank Walter
    replied
    S/N: MP1Y104Z
    MTM: 20WE0009GE
  • jj.ww
    replied
  • jj.ww
    replied
    hello. please will anyone help or point me in right direction.
    thanks.
  • jj.ww
    replied
    hello can i have help unlocking bios and mdm possible absolute
    S/N :MP1YCBD1
    MTM:20VD008UUK
  • jj.ww
    replied
    hello. volinakis.
    it worked thank you.
    i need to do 3 more of these laptop. could i use the 16MB file and use golden key to just change the dmi stuff ?
    or do i just need to post the 16mb files and system info ?
    thanks again
  • volinakis
    replied
    Originally posted by jj.ww View Post
    hello is it possible for somebody to help unlock bios password.
    S/N MP1Y9VDW
    MTM:20VD008UUK
    try. Write only 16Mb chipset.
  • jj.ww
    replied
    S/N MP1Y9VDW
    MTM:20VD008UUK
  • elariz
    replied
    its clean me region
    working 100%
  • peste
    replied
    Originally posted by -danger- View Post
    Hello. can I post bios dump for password reset? ThinkBook 14 G2 ITL
    I can donate if needed )
    post S/N, full name and model, motherboard model,post the original contents of the bios chip..etc.
  • -danger-
    replied
  • Pavel Kudryavtcev
    replied
    Originally posted by volinakis View Post
    check soldering
    There really was a problem with soldering. I redid it, checked it with a microscope. The behavior when starting the laptop has changed as it was after the f8cn58ww update. The power button, esc and caps lights up, then everything goes out and lights up again, while caps goes out and nothing else happens. If there are any other options on how to fix this, please suggest.
    P.S. Please note that I previously updated Intel Management Engine 15.0 Firmware to version F8ME05WW.
    Thank you!
  • volinakis
    replied
    Originally posted by Pavel Kudryavtcev View Post
    Unfortunately, it didn't work. But the symptoms are different, earlier the LEDs on the caps lock and escape were lit, now only the power button slowly blinks. As if there is no BIOS at all.
    check soldering
  • Pavel Kudryavtcev
    replied
    Try
  • volinakis
    replied
    Hi
    Lenovo Thinkbook 14 G2 ITL
    MO: MPNXB13230E6
    MTM: 20VD00CSUA
    Factory ID: PRC4
    S/N: MP1ZHRPF
    After updating to firmware f8cn59ww, the fan stopped working and the sound card was not detected. On the support forum, the manufacturer sent me the previous firmware f8cn58ww and after this update, the screen stopped showing. HDMI connection does not work. I only have dumps of the firmware f8cn58ww, I will attach them to the message. I will also add the installation file.
    I also tried the firmware from post 19, it does not work.
    Please help me fix the firmware.
    Thank you!
    Try
  • Pavel Kudryavtcev
    replied
    Hi
    MO: MPNXB13230E6
    MTM: 20VD00CSUA
    Factory ID: PRC4
    S/N: MP1ZHRPF
    Thank you!
