Originally posted by hoaca388
View Post
Lenovo ThinkBook 14 G2 ITL FLV34 LA-K051P bios
Originally posted by 147369258 View PostPlease help me. I received a ThinkBook model 14 G2ILT S/N:MP1YTF5G
MTM:20VD0034US
MO:MPNXB131170JV. I didn't have a backup BIOS. I programmed all three IC UC3-XM25QH128A-UC12-XM25QH64A-UT2-W25Q80. The laptop turned on, but it showed a blank image. The bigger problem is that it doesn't recognize the SSD drive. Is there a way to solve this problem? If you can send me the correct files, thank you.
UT2 is not bios chip
MTM:20VD0034US
MO:MPNXB131170JV. I didn't have a backup BIOS. I programmed all three IC UC3-XM25QH128A-UC12-XM25QH64A-UT2-W25Q80. The laptop turned on, but it showed a blank image. The bigger problem is that it doesn't recognize the SSD drive. Is there a way to solve this problem? If you can send me the correct files, thank you.Attached Files
Originally posted by danito View PostWhat's the problem with this bios?
Shift LED turns off after 5-6 Seconds and if i kill it with 10s power button the next start the white power led keeps turning on and off every 5 seconds.
Do you know anything thats wrong? Charing works and no burns, black components or other sings of failure.
Thank you for the fast reply.
Could you fix my main bios and ec bios chip bins as well please?
MODEL NAME :THINKBOOK 14 G2 ITL
FLV34 LA-K051P REV:1B
S/N: MP1Y104Z
MTM: 20WE0009GE
hello. please will anyone help or point me in right direction.
thanks.
hello can i have help unlocking bios and mdm possible absolute
S/N :MP1YCBD1
MTM:20VD008UUKAttached Files
hello. volinakis.
it worked thank you.
i need to do 3 more of these laptop. could i use the 16MB file and use golden key to just change the dmi stuff ?
or do i just need to post the 16mb files and system info ?
thanks again
Originally posted by jj.ww View Posthello is it possible for somebody to help unlock bios password.
S/N MP1Y9VDW
MTM:20VD008UUK
S/N MP1Y9VDW
MTM:20VD008UUK
Hello. can I post bios dump for password reset? ThinkBook 14 G2 ITL
I can donate if needed )
Originally posted by volinakis View Post
check soldering
P.S. Please note that I previously updated Intel Management Engine 15.0 Firmware to version F8ME05WW.
Thank you!
Try
Originally posted by Pavel Kudryavtcev View PostHi
Lenovo Thinkbook 14 G2 ITL
MO: MPNXB13230E6
MTM: 20VD00CSUA
Factory ID: PRC4
S/N: MP1ZHRPF
After updating to firmware f8cn59ww, the fan stopped working and the sound card was not detected. On the support forum, the manufacturer sent me the previous firmware f8cn58ww and after this update, the screen stopped showing. HDMI connection does not work. I only have dumps of the firmware f8cn58ww, I will attach them to the message. I will also add the installation file.
I also tried the firmware from post 19, it does not work.
Please help me fix the firmware.
Thank you!Attached Files
Hi
MO: MPNXB13230E6
MTM: 20VD00CSUA
Factory ID: PRC4
S/N: MP1ZHRPF
Thank you!
