HP Probook 4441s
  • raajkumar
    • Mar 2015
    • 354
    • Srilanka
    HP Probook 4441s
    HP Probook 4441s Rocky_Intel_Mb 11243-1 48.4SI01.011 Motherboard. It's having AMD Graphics controller.
    I can go inside the bios setup and can make changes without any problem. But when i going to exit by saving the bios setting its going to freeze. I removed HDD, ODD and wifi module but still having the same issue. Is it a bios issue or any hardware issue ? I update several bios dump on it. The problem is it doesn't had the old bios chip or program because it was removed by another technician.
    Is it possible to fix it?
  • fauzanmint
    • Jun 2018
    • 80
    • Indonesia
    Re: HP Probook 4441s
    have yu try flashing bios?
    • harshana
      • Aug 2022
      • 215
      • Sri Lanka
      Upload your current working bios dump.
      • raajkumar
        • Mar 2015
        • 354
        • Srilanka
        i don't have an accurate bios for it. i used someone sent it for me. but it shows the model number is hp probook 4540s. my laptop model is HP Probook 4441s. Motherboard: Rocky_Intel_Mb 11243-1 48.4SI01.011 with AMD Radeon Graphics controller.
        • harshana
          • Aug 2022
          • 215
          • Sri Lanka
          It doesn't matter. Try to reflash same bios file by cleaning ME region. We can change model details later. first try to boot from hard disk.
          If you upload the bios file which work right now, I may able to clean it.
          • raajkumar
            • Mar 2015
            • 354
            • Srilanka
            Here is the file i attached.
            • harshana
              • Aug 2022
              • 215
              • Sri Lanka
              I cleaned the bios file you sent. please try this and let me know. It it worked, We can try to fix product information.
              • raajkumar
                • Mar 2015
                • 354
                • Srilanka
                I flashed bios with your cleaned file. but it still in same condition. It freezes on save and exit time on bios.
                • harshana
                  • Aug 2022
                  • 215
                  • Sri Lanka
                  Then It could be a hardware problem.
                  https://www.badcaps.net/forum/showthread.php?t=110244
                  see above thread. may related to yours.
                  Do you have schematics of this motherboard?? Study the power diagram and test Power rails. May be you will find something strange something like missing rails when stuck or anything unusual.
                  • raajkumar
                    • Mar 2015
                    • 354
                    • Srilanka
                    Its not helped in my case. does anyone have any ideas for this case.
                    • studdy05
                      Bricked HP Probook 450 G7 Bios questions
                      by studdy05
                      Hp Probook 450 G7 s# SCD0348W35 had a locked BIOS. Bought BIOS and EC chips off Ebay that were supposed to match this machine - the 450 G7. Flashed in the BIOS on chip i bought using a CH341. BIOS unlocked next boot. Some error to contact HP. Entered BIOS and reset to system defaults and rebooted. Machine worked fine but every cold boot the contact HP message popped and everything else worked as fine. Assumed the error was from EC chip not matching BIOS that i just flashed in. So i flashed in the EC that was supposed to match from the EBay chip i bought and instant brick.
                      Ive got...
                      07-08-2025, 09:24 PM
                    • macabook
                      by macabook
                      🧩 Initial Issue
                      07-24-2025, 02:17 PM
                      by Vesko356
                      08-11-2023, 03:27 AM
                    • the_raz
                      Need (unlocked) bios for HP Probook 450 G3 Notebook
                      by the_raz
                      I'm requesting a bios .bin for 2 of my hp Probook 450 G3's. Both of which I had forgotten the bios passwords. I stupidly flashed both of them with firmware "made" by the RCUnlocker software and I guess I shouldn't have. The last thing I did was flash both of them with RCUnlocker-fw thinking it would 100% work and left my programmer etc behind and won't have access to them for another 2 days so I figured I'd create a thread to see if I'd be so lucky that someone might have a working file laying around 😝
                      Laptop number 1:
                      Model: HP ProBook 450 G3
                      Motherboard part number:...
                      12-17-2024, 03:37 PM
                    • jbonavita
                      by jbonavita
                      Some issues
                      Things I tried
                      04-29-2025, 09:38 PM
