Dell n5010 uma transaction done, there is a problem
  • kaan51
    • Dec 2020
    • 4
    • t
    Hello my dear friends
    I'm sorry for my bad english
    Dell n5010 uma done but won't boot after dell logo
    There is an image and it enters the bios, but the usb and hdd do not boot, it stays on the black screen
    This is the first time I've encountered a problem like this.
    Thanks in advance for your help, best wishes
    Mainboard:09909-1 DG15 MB 48 . 4HH01. 011
  • harshana
    • Aug 2022
    • 216
    • Sri Lanka
    Re: Dell n5010 uma transaction done, there is a problem
    don't you try to flash bios?
    I was able to fix this kind of issue on HP 430 g4 laptop by flashing bios.
    • mcplslg123
      • Jun 2015
      • 7262
      • india
      Remove R3715. Located near EC bios chip. Bright chance this will solve your problem.
      • toti24
        (NEED HELP)dell precision m4600 problem after bios flash (unbrick)
        by toti24
        dell precision m4600 laptop
        i7 2760qm
        8gb ram 750gb HDD
        intel hd 3000 integraded and nvidia quadro 2000m
        pleasea bear with me english isnt my language and ill try to be as clear as possible
        note i live in mexico in a very small town..
        thank you.
        laptop got bricked (freeze at dell logo) i managed to unbrick it but now am facing a problem...... let me explain what and how it happened.
        the brick happened when i was installing win 10 using usb.
        used rufus and officia microsoft.iso
        it finished copying files from usb...
        03-06-2022, 08:39 PM
      • Matias1997caba
        Problem with Dell pp35l bios
        by Matias1997caba
        Hello everyone! I'm having a problem with the BIOS of a Dell PP35L motherboard (DA0RM5MB8E0 Rev:E Y509R Rev:A00). It powers on, beeps 5 times, then 6 times, but there's no display. The problem is that it has two 16MB BIOS files, and all the ones I found online are 1MB and 4MB. I flashed them anyway, but with those BIOS files, the fan doesn't even turn on. Any help would be greatly appreciated! I've attached the BIOS files. Model: Dell PP35L.. Mother DA0RM5MB8E0 Rev:E Y509R Rev:A00. Service Tag: GRZR9M1...
        11-26-2025, 08:33 AM
      • SDNarcia
        Dell 15R-5521 keyboard problem (KBC?)
        by SDNarcia
        Hello, I have a Dell 15R-5521, with the problem that the Ctrl, Alt, Shitf and Num Lock keys do not work, I tested the keyboard with a keyboard tester and it is functional, I also got another new keyboard and the computer has the same problem with the same keys. Check continuity between the ZIF connector from the keyboard to the KBC and all pins are correct. I cleaned the ZIF connector and the KBC and I still have the same problem. I reinstalled windows just in case, and it didn't work. I updated the BIOS to the latest version A16 and there were no changes.
        As additional information,...
        07-20-2024, 10:47 PM
      • Achille15
        Dell N5110 problem
        by Achille15
        so, I have this laptop Dell Inspiron N5110 with a heating problem on both CPU (I7-2680qm) and GPU (GT 525m), I tried many solutions, like changing thermal paste every month, using thermal pads on CPU and GPU, even using thermal pads on CPU nearby coils; but nothing worked, just minutes after booting the laptop shuts itself down so I thought it might be a short problem, so I decided to check what's going on, so I went online and some tutorial (general one) said to check inductors in order to find the shorted circuit, after checking (CPU removed), I found the culprit to be...
        03-29-2025, 04:41 PM
      • eltunisie
        Hdmi problem in dell insprion 3521
        by eltunisie
        i have dell insprion 3521
        hdmi port it can good work but now not disply alot of screen and i used convert hdmi to vga but not work
        i tray
        windows 7, windows 10, orginal vga drivers from dell, update bios
        i found 5v on th e socket
        what a problem?...
        11-06-2025, 06:24 AM
