need bios for gateway GWTN156-*** N14PB REV: 1.0
  • cdsh009
    • Nov 2017
    • 44
    • Venezuela
    Hello, I need the bios for this laptop GWTN156-4GR
    ​ , the problem it presents is that when trying to give video it turns off, sometimes it gives video but it turns off again, thanks
  • peste
    • Dec 2016
    • 12218
    • ROMANIA
    Re: need bios for gateway GWTN156-4GR N14PB REV: 1.0
    Originally posted by cdsh009
    Hello, I need the bios for this laptop, the problem it presents is that when trying to give video it turns off, sometimes it gives video but it turns off again, thanks
    post the original bios even if it is corrupted
    • cdsh009
      • Nov 2017
      • 44
      • Venezuela
      dump
        • 20272
        dump
        post the laptop serial number
        • cdsh009
          • Nov 2017
          • 44
          • Venezuela
          1gwtn1564gr0f21d030358
          • M.Salman
            • Aug 2022
            • 13
            • Pakistan
            no display fan spin plzz clear this file gate way LAPTOP
            model no GWTN156-1BK
            • laptopbn
              • Jul 2016
              • 71
              • Viet Nam
              Please
                • 20272
                Originally posted by laptopbn
                Please
                Please read
                You MUST:
                • smali
                  • Sep 2014
                  • 287
                  • Pakistan
                  Same problem. Please repair the above shared bios. Thanks in advance
                  • adri1804
                    • May 2023
                    • 4
                    • Argentina
                    Hello, any news about this bios file?
                    • Norag33
                      • Mar 2024
                      • 14
                      • Cuba
                      I have a Gateway GWTN156-5BK, board N14PB REV
                      1.0, S/N 1GWTN1565BK1A20L010968
                      I need this laptop EC BIOS but since theres no any resource available for this model nor bios schematic or EC BIOS I've found that 4GR BIOS is compatible, and since the boards are the same I think EC BIOS should be the same too, so if anybody can provide me an EC BIOS dump ill be very gratefull
                        • 20272
                        EC.
                        • Norag33
                          • Mar 2024
                          • 14
                          • Cuba
                          EC.
                          Thank you, I will try an post the result also will post the results, also will upload a dump of my actual EC BIOS
                          • marian.pigna
                            • Oct 2023
                            • 11
                            • Argentina
                            Originally posted by SoporteNetFe
                            This is from gateway usa support, maybe can use this.
                            Hi! I'm also from Argentina, maybe you have a working bios for GWTN156-1BK? Someone was messing around before with Bios.
                            Notebook charges battery normally, when AC charger is plugged there is 3,3 and 5v and current is about 30mA, that seems a little bit much for a standby state.
                            When power button is pressed to turn on the notebook then 1,8v is present and current is about 330mA but there is no voltage for integrated ram neither vcore. Curious thing if you press power button to shutdown led goes off but current stays at 330mA. Never happen to me before. Fan never spins and of course there is no picture ever. Also there is no short on any coil.
                              • 20272
                              Post moved to different topic. Please post your bios backups and the laptop serial number
                              • SoporteNetFe
                                • Aug 2021
                                • 98
                                • Argentina
                                https://www.badcaps.net/forum/troubl...-n141b-rev-2-1
