Password - Lenovo İdeapad 3 15ITL6 - hs460 hs560 hs760 nm-d471
Every donation made will go towards server fees and maintenance costs. -
Every donation made will go towards server fees and maintenance costs.Comment
you have everything you need at post #14..
https://www.badcaps.net/forum/troubl...l6#post3299726Comment
Attached FilesDue to a lack of donations, server free space at a critical level, and possible closure of Bios Requests all donations are welcome, click:
Can you help me remove the BIOS password please?Comment
Mọi khoản quyên góp cho badcaps đều được hoan nghênh, hãy nhấp vào liên kết này để quyên góp. Cảm ơn tất cả những người ủng hộ----------------------------------------------------------------------------------------------------------------------------------------------------------------Comment
This is the file 16MB
TryAttached Files----------------------------------------------------------------------------------------------------------------------------------------------------------------------
----------------------------------------------------------------------------------------------------------------------------------------------------------------------Comment
Dear Friends., I have having a problem with this Laptop. It turn on when battery removed & then turns on with the power Adapter. But when I put back the battery, it works fine & charges well & the laptop works fine. I am assuming this is a BIOS problem. I am uploading both Original16MB & 8MB BIOS which is on the motherboard. Pls. if someone can re-build this BIOS for me, I would appreciate. Thanks in advance.
Model: Lenovo Ideapad 3 15ITL6.
HS460 HS560 HS 760 NM-D471 REV:2.0 VENDOR:HSB 2020-12-10
S/N: PF3DQKNMComment
S/N: PF3DQKNM
hi i need a bios file please for pc Lenovo IdeaPad 3 15ITL6 82H8
motherboard model nm-d472 REV2.0
serial number PF4DF2LW
old bios attached (there are two bios chips on this pc)Attached FilesComment
lenovo ideapad3 15tl6 nm-d741 password reset
sn:pf48tt94
Need password clean up, thanks in advance friendsAttached FilesComment
Please help. NM-D471 REV2.0.. any keyboard won't work, only letter 'i'. laptop keyboard, USB keyboard, bluetooth keyboard, not working, only letter "I".. At POST, beeping 2 times continuously.. Tried diffirent BIOS, still the same.. I will try disable onboard RAM and CLEARME.. please, anyone? SERIAL: PF4FKT9SAttached FilesComment
by elharouriamine won't turn on. if you press the power it flashes 12 times on the power button
so i need a helpe please
motherboard hs460 hs560 hs760 nm-d471 Rev 2.0 -
I have laptop Lenovo IdeaPad 3 15ITL6 with Intel Core i3-1115G4. When I press the start button, LED light on the start button starts blinking 12 times, then stops and after some time starts blinking 12 times again. When it stops, all voltages are down.
The motherboard is HS460 HS560 HS760 NM-D471 Rev: 2.0
S/N: PF3Q0WTF
The motherboard is not mine, also there were corrosion on the board which I cleaned.
Methods of fixing like fully turning off the motherboard or starting only with adapter doesn't work. All testing were did only with adapter on.
...06-07-2025, 02:40 AM -
by lrserviciosLenovo Ideapad 3 15ITL6 S/N: PF2RXCVG HS460 HS560 HS760- NM-D471 REV: 2.0
I suspect bios faliure because laptops start and power led keeps blinking please can you repair this BIOS for me please ??...-
Channel: BIOS Requests ONLY!
by samstownHello
I've got a Lenovo that stopped working. No sign of life at all. I was hoping it would be an easy fix but I am not sure it's mosfet, I think resistance should be low but it's OL.
Thermal camera show MOSFET heartbeat.... It's Sinopower SM4377.
Sam... - Loading...
