Bios for ideapad 1-11IGL05.
  • pepegotera454
    • Jul 2014
    • 15
    • andorra
    Hello, does anyone have the ideapad 1-11IGL05 bios dump?
    Thank you
  • peste
    • 12933
    • ROMANIA
    Re: Ideapad 1-11IGL05 bios dump
    Thank you
    read this..
    post the bios original..
    • Abdiazizy44
      • Dec 2020
      • 6
      • SOMALIA
      Need bios unlock for lenovo ideapad 1 11igl05 11
      I need assistance to unlock my forgotten bios password. I would highly appreciate your help. I also wanted to know if you could just decrypt the password and send it instead of reprogramming the chip.
      • AAAC
        • Jan 2020
        • 458
        • Mexico
        Re: Bios for ideapad 1-11IGL05.
        @Abdiazizy44
        Before starting make sure you have a good backup of the BIOS.
        The password is hashed, so just modify "SaDatabase" variable header at offset 621958h, from AA553F to AA553C, to invalidate "SaDatabase" variable that stores the password, save to a new file and use it to program the BIOS chip.
        • Abdiazizy44
          • Dec 2020
          • 6
          • SOMALIA
          @AAAC How can i edit and use what application to modify the file, If you could clarify more. Could you also explain to me where to find the offset 621958h
            VIP Moderator
            • Aug 2018
            • 4386
            • Bulgaria 🇧🇬
            AAAC explained it clearly enough, what else do you need as an explanation?
            Video tutorials?
            Become a Badcaps supporter
            Thanks to all supporters.
            • Ahari
              by Ahari
              I...
              08-13-2025, 06:12 AM
            • Habble7
              by Habble7
              Suspected Cause:
              Troubleshooting Attempts:
              05-22-2025, 07:28 AM
            • haitham sharabati
              by haitham sharabati
              Hello engineers 😀,
              🔧 Device Info:
              - Model: HP 15-da2007ne
              - Product Number: 8XF55EA#ABV
              - Serial Number: CND0338P0D
              - CPU: Intel Celeron N4000
              💀 Problem:😅
              08-07-2025, 04:54 AM
            • Citymin
              by Citymin
              S/N : 5RNK9FFT70...
              08-05-2025, 05:12 AM
            • DynaxSC
              by DynaxSC
              11-17-2023, 10:56 AM
