the original is damaged. I was told in another forum that the board will not start without programming the EC first. I have a bios file but i'm not sure if the EC bin is attached. HELP!
Need Bios + EC.bin for la-g881p
Re: Need EC.bin for la-g881p
Alienware Area-51mAttached Files
Mọi khoản quyên góp cho badcaps đều được hoan nghênh, hãy nhấp vào liên kết này để quyên góp. Cảm ơn tất cả những người ủng hộ----------------------------------------------------------------------------------------------------------------------------------------------------------------Comment
need Clear ME on la-g881p bios dump
Can someone clean my bios image for me. I can't find the correct firmware repository to do it myself. thanksComment
Re: need Clear ME on la-g881p bios dump
(a note about ME 16 ,not relevent to this thread, all ME 16 firmware is hosted seperately at win-raid at the moment,not sure if it will be added to the other mega shares)
ME System Tools https://mega.nz/folder/qdVAyDSB#FLCPaDVIsPYiy2TAUjD7RQComment
Re: Need Bios + EC.bin for la-g881p
do you have for alienware DDQ70 LA-G881P REV:2.0
IS THIS unit work even without battery,,,
2 charger use,,,
my unit as per client said after removing battery goes no power,,,
no shorted parts,, i think there is sensor,, or unit need batteryComment
by SMDFleaCommon SPI bios chip programming Questions and Answers
Bad...-
Channel: BIOS Requests ONLY!
09-02-2021, 04:40 PM -
by macabookHello everyone,
🧩 Initial Issue- Board powers on (fans spin, keyboard lights up and can be adjusted, caps lock led lights), but no display or backlight
- External display (HDMI) shows
07-24-2025, 02:17 PM -
by Vesko356First of all thanks to all of our members who have posted previously all methods posted here.
Operating system and OS version.If...-
by jbonavitaHi, my laptop wont boot at all
Some issues
Things I tried
1- Update / clear ME: Took the non working bios, made a backup, and did this: https://www.badcaps.net/forum/troubl...theory/trouble...-
- Loading...
