Need Bios + EC.bin for la-g881p
  • kjchatman
    • Dec 2012
    • 213
    • united states
    the original is damaged. I was told in another forum that the board will not start without programming the EC first. I have a bios file but i'm not sure if the EC bin is attached. HELP!
  • lapfix
    • Mar 2020
    • 2764
    • my workshop
    Re: Need EC.bin for la-g881p
    whats your service tag
    • kjchatman
      • Dec 2012
      • 213
      • united states
      the service tag is GN1P3Z2
      • hoaca388
        Badcaps
        • Jan 2022
        • 12508
        Alienware Area-51m
        • kjchatman
          • Dec 2012
          • 213
          • united states
          Originally posted by hoaca388
          Alienware Area-51m
          Is this the EC or the main bin? I need the bin to program the EC
          • kjchatman
            • Dec 2012
            • 213
            • united states
            need Clear ME on la-g881p bios dump
            Can someone clean my bios image for me. I can't find the correct firmware repository to do it myself. thanks
              • 22415
              Re: need Clear ME on la-g881p bios dump
              ME firmware repository https://mega.nz/folder/PJFXnCDK#lWSX5W0ODubZ2pf3gu3unw
              (a note about ME 16 ,not relevent to this thread, all ME 16 firmware is hosted seperately at win-raid at the moment,not sure if it will be added to the other mega shares)
              ME System Tools https://mega.nz/folder/qdVAyDSB#FLCPaDVIsPYiy2TAUjD7RQ
              • kjchatman
                • Dec 2012
                • 213
                • united states
                Re: Need Bios + EC.bin for la-g881p
                the hard drive won't detect after clearing the ME. what am i doing wrong?
                • Marc97
                  • Jan 2016
                  • 189
                  • Phillipines
                  do you have for alienware DDQ70 LA-G881P REV:2.0
                  IS THIS unit work even without battery,,,
                  2 charger use,,,
                  my unit as per client said after removing battery goes no power,,,
                  no shorted parts,, i think there is sensor,, or unit need battery
                  • miansh621
                    Banned
                    • May 2022
                    • 133
                    • pakistan
                    Master password OF BCKRZW2
                      Common SPI bios chip programming Questions and Answers
                      by SMDFlea
                      Q: I have a bios request,i can`t post my backup as i can`t read from the chip.
                      A: If you can`t read from it how do you expect to write to it ?.
                      Q: Why is my bios chip unreadable ?.
                      A: The programmer is faulty or has a worn or broken zif socket.
                      The USB cable is frayed,connector pins worn or some other physical damage.
                      Not enough amperage or voltage to power the programmer properly.
                      Bad...
                      09-02-2021, 04:40 PM
                    • macabook
                      by macabook
                      🧩 Initial Issue
                      07-24-2025, 02:17 PM
                    • cr4zychriss
                      by cr4zychriss
                      • Rebrand: PC Specialist
                      11-14-2025, 04:04 PM
                      by Vesko356
                      08-11-2023, 03:27 AM
                    • jbonavita
                      by jbonavita
                      Some issues
                      Things I tried
                      04-29-2025, 09:38 PM
