BIOS for lenovo ideapad 3 NM-D031
  • alberto232732
    • Oct 2020
    • 8
    • mexico
    Please rebuild BIOS, no image on screen
    • hoaca388
      Badcaps
      • Jan 2022
      • 12268
      You MUST:
      • Read BIOS guides, methods, resources and tools
      • Try the method at BIOS guides, methods, resources and tools before requesting help
      • Explain you were not able to succeed with the methods at BIOS guides, methods, resources and tools
      • Use search function in case someone already answered your request
      • Post under a related thread if it exists
      • Provide the full machine model number, serial number (or Service tag, SNID) and the board model number (see https://www.badcaps.net/forum/showthread.php?t=88758 ) ,The serial number, make, full model number, motherboard model and revision (except QR codes) must be written/typed at your request as per the rules. Not as a picture, part of the file name and so on.
      • Name your thread with make, full model numbers and request
      • Provide a BIOS/EC dump if possible
      • Attach files directly to your post instead of linking to external websites
      • Post what the problem is, be specific - black screen, no boot, running slow, password. Do NOT post "clean me", "clear bios", "clean bios", "fix bios", "bios need" or other such terms
      • Arafat91
        • Aug 2023
        • 15
        • Bangladesh
        Idiapad 3 14iil05
        model- 81wd
        sn-PF2VG9AG
        problem no diplay
        • hoaca388
          Badcaps
          • Jan 2022
          • 12268
          Originally posted by Arafat91
          Idiapad 3 14iil05
          model- 81wd
          sn-PF2VG9AG
          problem no diplay
          ideapad 3-14IIL05 Laptop - Type 81WD
          • DrSeronja
            • Jan 2021
            • 12
            • Bosnia & Herzegovina
            I have a problem with the mentioned laptop. The laptop powers on but doesn’t display an image. I flashed the BIOS with a file I found in a Telegram group, and now the laptop turns on but very slowly, and it seems like it resets the BIOS every time. (The BIOS battery is working properly.) Sometimes it won’t power on at all, and I have to disconnect and reconnect the BIOS battery. This is my original BIOS dump, so I’m asking if you could help me solve the problem.
            Laptop : IdeaPad 3 15IIL05
            CPU : INTEL I5-10GEN
            Model name : 81WE
            SN: PF2ANM72
            MTM : 81WE00GEIX
            MB : GS454/GS554/GV450/GV550 REV : 1.0 NM-D031 2019-12-06.
            • peste
              peste commented
              Editing a comment
              post merged..next time look for a thread with the name and model, motherboard model of the laptop, and post there, if you can't find it, then make a new thread..
          • DrSeronja
            • Jan 2021
            • 12
            #26
            Ok sorry
            • peste
              • 13420
              • ROMANIA
              #27
              Model name : 81WE
              SN: PF2ANM72
              MTM : 81WE00GEIX
              you have everything you need at post #32..
              https://www.badcaps.net/forum/troubl...-nm-d031/page2
              • DrSeronja
                • Jan 2021
                • 12
                #28
                I did everything as described in post #32, I used the BIOS extracted from the Lenovo site that you mentioned a few posts above. Now the laptop powers on quickly as it should, but when I try to shut it down, it won’t power back on. Instead, it keeps turning on and off without showing any display. When I disconnect the BIOS battery and reconnect it, then it starts up again. As long as I use the Restart option while the laptop is on, there’s no problem and it works fine — the issue only happens when I use Shut Down. Maybe I didn’t do something correctly in HxD. Here’s the .bin file that I flashed, so if it’s not a problem, could you take a look at it?
                • peste
                  • 13420
                  • ROMANIA
                  #29
                  It's good what you did...maybe you wrote it with errors...write it again...
                  The bios chip must be unsoldered from the board before writing or reading..
                  do not use the clip, you may have errors..if you do not have anything to unsolder it with,
                  solder wires between the programmer and the bios chip..
                  here is a video for example..https://www.youtube.com/watch?v=DWWi...nnel=ThisIsHow
                  • DrSeronja
                    • Jan 2021
                    • 12
                    #30
                    From bad expirience i never use clip, i always desolder chip and solder it direct on the pad that i connect to programmer. I try few times with different speed, and always get same problem...
                    • misiek_michal
                      • Sep 2023
                      • 15
                      • Poland
                      #31
                      Idepad 3 15IIL05 NM-D031 rev. 1.0
                      RAM errors at first. After disabling the built-in RAM, it still freezes with a black screen. It won't boot. Please check the BIOS. Thank you.
                      Bios oryginal
                      • hoaca388
                        Badcaps
                        • Jan 2022
                        • 12268
                        #32
                        Bios oryginal
                        Serial number ?
                        • misiek_michal
                          • Sep 2023
                          • 15
                          • Poland
                          #33
                          Originally posted by hoaca388
                          Serial number ?
                          sorry, PF2R2QA6
                          • misiek_michal
                            • Sep 2023
                            • 15
                            • Poland
                            #34
                            Hi, can you help?
                            • hoaca388
                              Badcaps
                              • Jan 2022
                              • 12268
                              #35
                              sorry, PF2R2QA6
                              ideapad 3-15IIL05 Laptop - Type 81WE
                              • skywavee1
                                • Jan 2022
                                • Indonesia
                                #36
                                Lenovo ideapad 3 15IIL05
                                S/N : PF23KPK1
                                Problem : M.2 NMVE not detected, trying with M.2 SATA and it runs normally
                                • peste
                                  • 13420
                                  • ROMANIA
                                  #37
                                  S/N : PF23KPK1
                                  • jendkkd jeje
                                    Lenovo IdeaPad 330 15-AST 81D6 BIOS Recovery
                                    by jendkkd jeje
                                    So a couple of years ago i got a bios update through Lenovo Vantage, so i installed it and bricked my whole BIOS, so i couldn't fix it so i put that ideapad in a box, 3 years later i found that one PC and want to recover it to switch from a 2014 hp laptop to this one.
                                    I found a method to recover the BIOS of many lenovo laptops tha consists in pluging in a USB Flash with the BIOS files and power on the laptop with Fn + R keys pressed until fans go loud and start beeping loud, but nothing worked, so i think filename is wrong, i tried naming the bios file as 07WW.BIN, BIOS.BIN, BIOS.fd,...
                                    10-11-2024, 03:12 PM
                                  • joven016
                                    Lenovo Ideapad S145 need working bios HELP!!
                                    by joven016
                                    Problem is blinking power led only
                                    i don't know exactly if it's s145-15igm or s145-14igm
                                    have a backup bios file but i dont know the serial.. coz text already erased at the back of the cover
                                    Mother board : fs440fs541 nm-c111 rev 1.0 2019-01-08
                                    Already tested some of posted bios here
                                    S145-14igm - success but invalid serial and not booting on OS
                                    S145-15igm - success with serial and some other info in bios but still not booting on OS
                                    already tried installing new windows but always booting on bios setup
                                    windows installer flash drive detected on...
                                    08-21-2025, 10:55 PM
                                  • lucaszmn
                                    by lucaszmn
                                    Problem:
                                    Initial Findings:
                                    • I concluded that the
                                    08-12-2025, 03:01 PM
                                  • mximiliandz
                                    help bios lenovo ideapad s145-14iil type 81w6
                                    by mximiliandz
                                    Good morning, gentlemen, I hope you can help me with my laptop, I told you that I saved it about 2 years ago because it wouldn't turn on, now I have a ch341a programmer, I made a backup of the bios, I flashed an original downloaded from lenovo and it started, but it turned off after a few minutes, I entered the bios configuration and the brand, model, serial number, windows serial number, etc. did not appear, I request your help, I did everything I found in the forum but I could not solve it, also now it won't start again, it turns on but the fan does not turn, I will share all the information...
                                    06-20-2025, 06:50 AM
                                  • Wahaz
                                    by Wahaz
                                    10-30-2023, 08:42 PM
