BIOS file for N550JK (original dump attached)
  • joshAU
    • Oct 2008
    • 34
    Hi all.
    I'm looking for a BIOS file for an Asus N550JK.
    I have a Asus R552J, which I believe is identical to the Asus N550JK.
    I downloaded the latest BIOS (210) for the R552.
    It is named N550JKAS.210.
    The BIOS file is however only 6mb in size.
    I've read the chip with a CH341A programmer and verified the file.
    That file is actually 8mb in size.
    I'm wanting to remove the BIOS password from this unit.
    It prompts you to input the password when turned on, so its sort of behaving like a power on password rather than a BIOS password.
    i.e it prompts for the password on startup, not just when you try to enter the BIOS.
    Other suggestions to remove the password have failed.
    Eg.
    1. Reset CMOS
    2. short pins under the RAM (JRST2001 & JRST2002)
    3. Pressing Alt & R at the password screen...
    4. RC unlocker reports "Missing unlockable content".
    I'll attach the file I read from the BIOS chip.
    Any help greatly appreciated.[/QUOTE]
  • pooya_pm
    • Jan 2021
    • 253
    • iraq
    Re: BIOS file for N550JK (original dump attached)
    Mothrboard rev? Vga chip number?
    • joshAU
      • Oct 2008
      • 34
      Hi pooya_pm.
      The motherboard PN is 60NB04L0-MB2030(216)
      Is that what you're after?
      It also has this number on the memory slot as well:
      69N0QXM11B06
      I cannot see any revision number on the board?
      The numbers on the Nvidia chip are:
      S TAIWAN 1411A2
      T2S496.000
      N15P-GT-A2
      Thank you.
      • pooya_pm
        • Jan 2021
        • 253
        • iraq
        Bios asus n550jk n550jv 2.0 vga 850m cpu i7 4th test pls
        • Maxpower3
          Bad Veteran
          • Feb 2018
          • 1215
          • France
          Originally posted by joshAU
          Hi all.
          Eg.
          1. Reset CMOS
          [/QUOTE]
          try maybe password : $ELABEL
          • joshAU
            • Oct 2008
            • 34
            Hi again pooya_pm.
            Thank you so much!
            I really appreciate it.
            I haven't had a chance to test it today, but will try it tomorrow and will let you know.
            Thanks again.
            • joshAU
              • Oct 2008
              • 34
              try maybe password : $ELABEL[/QUOTE]
              Hi Maxpower3.
              Thanks for your input and help.
              I tried that, as is, and in lower case, but unfortunately it did not work.
              Thanks anyway for your help though, I appreciate it.
              • Phil916
                • Mar 2018
                • 12
                • France
                i dont have CH341A programmer or i would have copied the bios for you.
                i have a probably corrupted bios on my N550JK (black screen at charger connected with power ON lighted up and fans turn on to the max after few seconds)
                probably i have to purchase this programmer
                what is your test result please ?
                • jaglion19
                  • Oct 2017
                  • 86
                  • TURKEY
                  I need the bios dump for n550jk rev 2.1 uma please help, I downloaded it from the asus website and added the working bios file that I merged with the bios on it. I removed the gpu rams and coils but the fan is spinning a lot, I would be glad if someone could help me with this.
                    • 20581
                    Thread merged. Read the rules, type the laptop serial number https://www.badcaps.net/forum/troubl...before-posting
                    • jaglion19
                      • Oct 2017
                      • 86
                      • TURKEY
                      My intention is not to break the rules, I just feel the need to open a topic when I search but can't find it. SN : EBN0CY26077146B
                      • hoaca388
                        Badcaps
                        • Jan 2022
                        • 11532
                        • Viet Nam
                        Have you cleaned the ME region ?
                        • jaglion19
                          • Oct 2017
                          • 86
                          • TURKEY
                          Since I got the bios dump file by serial number, I didn't need to clean it. But I'll try cleaning it as well.
                          • jaglion19
                            • Oct 2017
                            • 86
                            • TURKEY
                            I have now cleaned it and tried it, the situation is the same. The device's graphics card is faulty. I removed the graphics card, removed the VRAMs, removed the graphics card supply coils and the VRAM coil.
                          • bondminer009
                            Need Bios for Latitude 7650 (No Original / dump bios file)
                            by bondminer009
                            Good Evening,
                            Need help, is there any possible to get the bios file? Because received from my team without any dump file / original bios file
                            Thank You
                            Salam,
                            Three
                            11-12-2024, 07:48 AM
                          • adelage
                            Merge ECS Z77-H2 bios cap file with original dump
                            by adelage
                            I am trying to recover an ECS Z77-H2 motherboard, I dumped the original bios with a ch341a programmer, the bios from the manufacturer is a .cap file of smaller size, and it seems that I need to merge this file with other information from the dump, anyone can explain how to do that?
                            03-11-2025, 03:07 AM
                          • EbrahimSiami
                            Acer Aspire 5920G - Requesting Modded BIOS (9600M GT) from .WPH for CH341A Flasher
                            by EbrahimSiami
                            I need help with my Acer Aspire 5920G laptop. Its original GeForce 8600M GT graphics card failed, so I replaced it with an Nvidia GeForce 9600M GT MXM card.
                            **Problem:** The laptop powers on, but there is no display (black screen) on either the internal LCD or external monitor. This indicates a BIOS compatibility issue with the new graphics card.
                            **What I have tried so far:**
                            1. I have my **original stock BIOS dump (1MB .BIN file)** from my laptop, which works and allows the laptop to power on normally (but no display with 9600M...
                            07-02-2025, 02:31 PM
                          • silverflea
                            Need Bios MSI B75A G43 Dump File
                            by silverflea
                            Hi. I need dump file bios MSI B75A-G43
                            My bios got corrupted and wont boot, so i need to flash it using Ch341A programmer, but bios file from the official website is to large, so i need bios dump file from working motherboard, or anyone know how to cut the bios size to fit bios chip
                            Thanks!
                            08-09-2022, 01:37 AM
                          • grimacelord
                            by grimacelord
                            07-10-2025, 02:52 PM
