latitude 5420 board LA-k491P bios problem.
  • LBTT1121
    • Nov 2024
    • 904
    • Việt Nam
    #361
    Originally posted by aamkaachaar
    My Bios is Corrupted , It's just parttial power on , no (Run_on) supply , tried with CLR ME, and Even With New Bios Region, Same condition , with some other bios here it gets powered on but Some RGB color , Some loop restart , Some hang on Dell logo , i am attaching my origional dump if someone can help ?
    Latitude 5420
    ST:6LYQ2J3
    try and feedback
    • aamkaachaar
      • Jun 2013
      • 7
      • india
      #362
      Originally posted by LBTT1121
      try and feedback
      Still the Same , Partial power on EC doesn't releases (Run_on_en), Draws 100ma Current only, I have already tried with clear ME and NEw Bios Region the Condition Doesn't change , Any Further Help Would be appreciated .
      • Markus1741
        • Sep 2020
        • 946
        • N/A
        #363
        Latitude 5420
        ST:6LYQ2J3
        Hello this is not your original file you say ServiceTag is 6LYQ2J3 but in your file it is BCYC1J3 ?????????
        And ServiceTag 6LYQ2J3 coud not be found!!!!!!!!
        • aamkaachaar
          • Jun 2013
          • 7
          • india
          #364
          Sir i have provided the service tag written on the backcase , may be the backcase has been swapped by someone but the bios file i have provided was intact bios for the machine ... if you can help me with a good bios for BCYC1J3 , things would help
          • ezazuk
            • Nov 2023
            • 6
            • GB
            #365
            hi, need help to remove TPM error:
            TPM DEVICE IS NOT DETECED
            DELL LATITUDE 5420-I7-11GEN
            SERVICE-TAG-8ZQHR73
            • LBTT1121
              • Nov 2024
              • 904
              • Việt Nam
              #366
              SERVICE-TAG-8ZQHR73
              try
              • ezazuk
                • Nov 2023
                • 6
                • GB
                #367
                SERVICE-TAG-8ZQHR73
                try
                same error
                • Markus1741
                  • Sep 2020
                  • 946
                  • N/A
                  #368
                  same error
                  Sorry but just cleaning the ME region does not fix the TPM error, only replacing the TPM IC helps, anything else is nonsense .....
                  • joaopedrogallo
                    • Feb 2023
                    • 13
                    • Brazil
                    #369
                    Hi there!
                    I have a Dell Latitude 5420 / ST: FC2JQF3 / GDF40 LA-K491P / Rev: 2.0 (A01) / 2020-11-16 / i5-11 model.
                    My client told me it ran out of battery while updating BIOS (yes, it did) and now seems more like a brick.
                    I have some doubts about this one:
                    It charges using a USB-C plug adapter and I have an asymmetric power source to see the consumption.
                    I don't know if I can plug it in 20V.
                    When plugged on 5V and when I try to raise it to 20, it turns out on 7V.
                    The original adapter is here with me, but It only shows a tiny white light and it's working fine.
                    I tried:
                    • Flash BIOS (UC2)
                    • Flash EC (UT7)
                    None of this worked.
                    But the behavior is always the same, before and after flashing: when I plug the adapter (5V), it consumes a variable amount of energy: 0.40 / 0.52 / 0.61 / 0.30 and keeps variating.
                    The original BIOS is attached here and also the EC.
                    I also added the boardview.cad and schematic to help.
                    Can someone help me to find the solution?
                    • LBTT1121
                      • Nov 2024
                      • 904
                      • Việt Nam
                      #370
                      Originally posted by joaopedrogallo
                      Hi there!
                      I tried:
                      • Flash BIOS (UC2)
                      • Flash EC (UT7)
                      try and feedback
                      • TripTop
                        Dell Latitude E7270 - Requesting BIOS clean/corrupt? service tag CB00KC2
                        by TripTop
                        Hi
                        i have dell latitude E7270 with following symptoms:
                        - takes long time to restart.
                        - sometimes powers on and then off
                        - sometimes while working it just dies,
                        From googling online bios clean could possible resolve this?
                        i was able to save bios and was going to try bios clean myself but get an below error when i drop it in ME analyzer.(unsure whether this sometimes occurs or could be due to bad/corrupt bios)
                        As ME analyzer gave me an error i just decided to write bios with a cleaned bios from E7270 bios post.
                        I reinstall...
                        09-09-2024, 02:05 PM
                      • macabook
                        by macabook
                        🧩 Initial Issue
                        07-24-2025, 02:17 PM
                      • gizaha
                        by gizaha
                        02-13-2024, 07:18 AM
                        DELL Latitude 5420 Notebook 5000 Specification for Upgrade or Repair
                        This specification for the DELL Latitude 5420 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 5420 boardview and 5420 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for DELL Latitude 5420...
                        09-07-2024, 06:31 AM
                        09-07-2024, 03:40 AM
