latitude 5420 board LA-k491P bios problem.
If you have found our forum useful please consider supporting us. Subscribe for a small monthly fee and receive extra benefits including our bios, boardview & schematic archive.
Subscribe to support us. It only takes 1 minute:
https://www.badcaps.net/settings/subscriptions -
plz help me , this bios eror TPM device is not detected
Dell 5420
SVT : FFNC6G3
i5 gen 11
Attached FilesPremium supporters get full download access and other benefits.
Latitude 5420
Service Tag: FFNC6G3Attached FilesPremium supporters get full download access and other benefits.
https://www.badcaps.net/settings/subscriptionsComment
ServiceTag: 6ZKF6J3
I had used the https://github.com/chromebreakerdev/DellBIOSTools script, but it gives me an error, that the Intel signature not found.
Think i perhaps know why, wanted to read the bios file with my EZP2019 programmer and pushed the wrong button 😣 (AUTO > auto recognize the chip brand and size).Attached FilesPremium supporters get full download access and other benefits.
Corrupt backup, slow the programmer speed to 6Mhz and try again.ServiceTag: 6ZKF6J3
Think i perhaps know why, wanted to read the bios file with my EZP2019 programmer and pushed the wrong button 😣 (AUTO > auto recognize the chip brand and size).Comment
A small update regarding my situation.
I had found in topic need bios dump dell latitude 5420 cpu 11th this posting.
Someone else mentioned that the file "try 2nd outimage" worked for that person, so I have used it also.
And I can confirm, the file worked like a charme. Kudo's to qayyum786
dell latitude 5420
gdf40 la-k91p/rev:3.0
st-1RJS3K3
PASSWORD
plz unlockAttached FilesPremium supporters get full download access and other benefits.
hi tryAttached FilesPremium supporters get full download access and other benefits.
Hi guys, I have a latitude 5420 here, I've done a few but this one is proving to be an issue.
I successfully removed the admin password with the 8FC8 patcher (although it seems to change entries in more than two locations?).
I was under the impression the 8FC8 patcher only edited two strings, when I use it on this dump it edits 4.
Chip resoldered, laptop boots but NVME not detected, from a bit of reading this could be a corrupt ME region?
Can anybody help please?
I have uploaded the original locked dump, so if somebody could remove the admin password and repair the ME I would be forever grateful, thank you.
Dell Latitude 5420
ST - 90517M3Attached FilesPremium supporters get full download access and other benefits.
Hi in this bios TPM Error , dell logo hang, green, red, blue, white screens coming
Kindly anyone fix This
Dell Latitude 5420,
Service TAG-9QZF3F3,
LA-K491P REV 2.0(A01)
2021-10-15.
Thank You in advanceAttached FilesPremium supporters get full download access and other benefits.
any alternate file please,
Dell Latitude 5420,
2021-10-15.
Here I attached bios which i got from badcaps, in this bios dell logog coimg after blank display. kindly help me with thiss. in this bios TPM not Detected error kindly fix thisAttached FilesPremium supporters get full download access and other benefits.
Dell Latitude 5420
HI, COULD YOU HELP ME WITH THIS BIOS? IT SHOWS A TPM ERROR AND HAS AN ADMINISTRATOR KEY? CAN YOU HELP ME PLEASE?
BOARD MODEL: GDF40 LA-K491P REV 2.0(A01)
2020-11-16
DELL MODEL: LATITUDE 5420
ST: 4X036D3Attached FilesPremium supporters get full download access and other benefits.
I have a Dell Latitude 5420 (tested without HDD) and I’m running a diagnostic tool such as Aiken Workbench. The problem is that the tool detects the onboard LAN card, but it shows the message:"no working driver for it"
and the test result is NO Driver.
Interestingly, when I install Windows, the LAN card works perfectly fine, which confirms that the hardware itself is okay. I have tried multiple cables and diagnostic environments, but the result is the same.
For comparison, I have a BIOS dump from a working unit and another from the problematic unit. The file sizes are identical. I suspect the issue might be related to a missing or corrupted PXE/UEFI network driver module in the firmware.
My questions:- Has anyone experienced this issue before?
- What are the recommended steps to add the proper LAN driver to a diagnostic/WinPE environment, or to safely repair the firmware?
- If no solution can be found, I would appreciate it if any expert who knows how to fix this fault could contact me privately to suggest the right approach.
Thank you in advance for your help.Comment
by TopPopSorry for the long story. I have a Dell Latitude 5530 (i7) laptop (South Peak 15 MLK MB DDR4 203102-1 FK8VG$JA) with an admin BIOS password that I want to remove. Service Tag: HYKFPT3. Other than that the laptop worked OK.
I found a CH341A Black and went looking for the BIOS chip on the motherboard. After trying to read one chip that was a firmware chip but not the BIOS I think I found the BIOS chip labeled Winbond 25Q256JVEN. Altogether I think I found 4 different firmware chips in the laptop. The BIOS chip is a WSON8 6x8. I used the CH341A, NeoProgrammer, and a cheap pogo pin clip... -
by SathsulSo, i kinda spend significant ammount of the last couple of days trying to flash a new bios, and or unlocking the current bios password with little to no results.
The whole thing started with it being the 8fc8 bios, i found the tools to unlock that but i needed a bios dump. So i pursued that, im at a point where i dessoudered the chip, and succesfully soudered it to the ch341, dumped whatever was on it.
However, the tools supposed to unlock the 8fc8 say that there is no 8fc8 hex inside. And when i followed diffrent tutorials to just flash a new bios onto the chip i got stuck on the...-
Channel: BIOS Requests ONLY!
by TripTopHi
i have dell latitude E7270 with following symptoms:
- takes long time to restart.
- sometimes powers on and then off
- sometimes while working it just dies,
From googling online bios clean could possible resolve this?
i was able to save bios and was going to try bios clean myself but get an below error when i drop it in ME analyzer.(unsure whether this sometimes occurs or could be due to bad/corrupt bios)
As ME analyzer gave me an error i just decided to write bios with a cleaned bios from E7270 bios post.
I reinstall...-
by macabookHello everyone,
07-24-2025, 02:17 PM -
by Godfather79Hello everyone in the community
Dear Sir,
I need help removing/unlocking the BIOS Service Tag password on my Dell Latitude 5520 laptop.
Problem details:
* Model: Dell Latitude 5520.
* Board ID (from BIOS file): TGL MB 8L 19819-1 (Southpeak15).
* Required Password Code: 3FE2 (BIOS Service Tag Lockout Code).
* Service Tag: (Enter your actual Service Tag from the laptop here)
* BIOS Status: I successfully modded the BIOS file and created FINAL_CLEANED_ME.bin (32MB) with a clean ME region (CSME 15.0), because the original dump was corrupt....-
- Loading...
