hp 17-cn0013dx BIOS Build ID does not match
  • Mazorca
    • Jan 2017
    • 463
    Howdy, I got an HP 17-cn0013dx, serial number 5CG1154ZW4 that will not "see" the hard drive nor an m.2 drive. Both drives show up good in HP diagnostics (F2) but Diskpart.exe will not see them at all either. On my backup (16MB), build ID shows up as 0883C but on HP update two show up, 08840 (16MB) and 0883E (8MB). I only found one BIOS chip on board. I have tried to update BIOS using a USB flash drive but will not update, says BIOS file not found. Perhaps because it is not the correct one? I have also cleaned the ME Region, same errors, won't boot. HP update is sp139182.exe, I think it is not the correct one for my laptop.
    Original BIOS backup posted before cleaning ME region.
    Anyone has this bios?
  • imranromi
    • Jan 2015
    • 1288
    • Pakistan
    Re: hp 17-cn0013dx BIOS Build ID does not match
    Try this
      • 21053
      D 801000 - 80203F
      w 887000 - 88703F
      • Mazorca
        • Jan 2017
        • 463
        Thank you imranroni, unfortunately, same symptoms. I will set it aside for later. and thanks SMDFlea, got the DMI region allright, and set the winkey manually. I feel that my BIOS skills are getting a bit better thanks to the forum.
        • Mazorca
          • Jan 2017
          • 463
          Update on this laptop:
          I bought another motherboard, same specifications, (icore3), , and it works....... with the SAME SYMPTOM, no fixed drive detected, nor the m.2 drive. I replaced DDR4 RAM, another new 2.5 SSD, another new m.2 SSD, the HP diagnostics (F2) "sees" them (as old mobo did too) but stops booting with error "inaccessible boot device". I have not worked at all on the BIOS chip from the new mobo. Diskpart does not see any fixed disks either, when run from installation USB, only the installation flash drive.
          Things I have in common from the old mobo: screen, power switch board, battery, keyboard. Everything else is disconnected or was replaced by new/working components.
          Any suggestions?
          • piernov
            • Jan 2016
            • 4436
            • France
            Disable Intel RST or add Intel RST driver during installation.
            • Mazorca
              • Jan 2017
              • 463
              Thank you for your suggestion, I will do so on Monday morning when I have access to the laptop. I do remember seeing that setting on the HP BIOS setup but didn't change anything, only change was for default settings. Again, thanks.
              • Mazorca
                • Jan 2017
                • 463
                Update status. Thanks to Piernov, I have fully reinstalled windows to original hard drive and now "see" m.2 NVMe SSD too. File to download is named F6flpy-x64 - VMD, contains two drivers, top one is what I used. You must load this driver during windows installation, and drives will magically appear. This youtube video explains more: https://www.youtube.com/watch?v=JyipHq7LUk4
                • alshalami1970
                  • May 2017
                  • 5
                  • jordan
                  Re: hp 17-cn0013dx
                  Hi all
                  this original bios no signal and shotdown
                  iam trying many bios and signal ok but not ditect ssd or m2
                  any help to fix my original bios please
                    VIP Moderator
                    • Aug 2018
                    • 4386
                    • Bulgaria 🇧🇬
                    Re: hp 17-cn0013dx
                    Originally posted by alshalami1970
                    Hi all
                    Bios is attached at post #2, DMI and Windows Key addresses at post #3, post #6 mentions what you need to do about the SSD. What more do you want?!
                    Become a Badcaps supporter
                    Thanks to all supporters.​
                    • Cookie12122802
                      • May 2022
                      • cuidad de mexico
                      Re: hp 17-cn0053cl bios help
                      I have an HP 17-cn0053cl someone will have the bin to be able to flash it
                      Thank you
                        • 21053
                        Thank you
                        Off topic, different model number.Start your own thread please.
                        • mikeybass
                          by mikeybass
                          04-23-2025, 04:30 PM
                        • akwky
                          by akwky
                          Hi!
                          04-14-2025, 01:56 PM
                        • al3m0di
                          Update bios EFCN58WW to EFCN59WW
                          by al3m0di
                          Update bios EFCN58WW to EFCN59WW for solving The Connected AC adapter has a lower wattage than the recommended AC adapter
                          I have a Lenovo Legion 5 15imh05a device that I bought used online. It came with a 20V 8.5A 170W charger.
                          The BIOS version is EFCN58WW.
                          When I turn on the device, it displays the message:
                          "The Connected AC adapter has a lower wattage than the recommended AC adapter..."
                          The device rarely charges the battery, and even when it does, it doesn't show that it's charging.
                          I've tried
                          07-29-2024, 10:32 AM
                        • iZakre
                          HP Pavilion 15 bc400ns - Complete Black Screen - Only video on live usb
                          by iZakre
                          Hello everybody!
                          To put you in context I recently replaced the battery from my HP Pavilion 15 bc400ns with a used one, everything was going good. The same day, I decided to update the BIOS, everything went good. The thing occurred after I let the battery drain iddling on Windows 11 for the second time to calibrate it that the screen did not turn on again, the computer was on but the screen did not turn, like it would not wake from hibernation. I decided to restart the computer but got no video.
                          The thing is that I had installed TeamViewer and could log into the computer...
                          02-19-2023, 02:27 PM
                        • trix11
                          Dell Precision T1650 MT Workstation bricked after BIOS update
                          by trix11
                          I have a Dell Precision T1650 MT workstation (of the following spec.) that was bricked yesterday when attempting to update the BIOS from A27 to A28 per:
                          - https://www.dell.com/support/home/en...-t1650/drivers > Dell Precision T1650 System BIOS
                          - Dell Precision T1650 mid tower Workstation
                          - Xeon E3-1225 V2
                          - 32Gb PC3-12800E RAM
                          - 4Tb SATA HDD
                          - motherboard: Dell part: 0C3YXR CN-0C3YXR-72200-39C-01GR-A02
                          I see now that others have experienced like issues e.g.:
                          - https://www.dell.com/community/Prec...
                          10-24-2022, 10:35 PM
