MSI ge70 ms-1759 bios request
  • mnciks11
    • Aug 2019
    • 347
    • south Africa
    Hello guys
    I have an MS-1759
    S/N: GE70 2PE-429ZAK140700027
    Fans spins fast and no display, i believe the ME region or the bios is corrupted need to be cleaned
    i have attached my backup file below
  • peste
    • 13924
    • ROMANIA
    Re: MSI ge70 ms-1759 bios request
    Originally posted by mnciks11
    Hello guys
    I have an MS-1759
    it wasn't hard to find...
    https://www.msi.com/Laptop/ge70-2pe-apache-pro/support
    • istvanszasz99
      Razer Blade 15 (2022) RZ09-0421 BIOS Modding / editing help request
      by istvanszasz99
      Product ID: RZ09-0421
      Motherboard: CH580
      Bios File Size: 32,768 KB
      Dear Forum Readers!
      !!! MY RAZER BLADE...
      11-24-2025, 05:52 PM
    • jbonavita
      by jbonavita
      Some issues
      Things I tried
      04-29-2025, 09:38 PM
    • Wahaz
      by Wahaz
      10-30-2023, 08:42 PM
    • hotcrossedbuns999
      M715q Desktop (ThinkCentre) - Type 10M3 - Request bios chip location and useable bios for use with CH341A Programmer.
      by hotcrossedbuns999
      My pc updated bios through Windows Update and I was greeted with BLACK SCREEN WITH CPU FAN MAX SPEED. I don't think there is even a screen signal, because it triggers my monitor for a couple seconds and then the monitor turns off. I tried the other outputs as well.
      1. I tried clearing bios, resetting bios, removed the CMOS battery, removed m.2 ssd, wifi, and ram. Still black screen with CPU fan blasting.
      2. I tried using the Lenovo BIOS CD and BIOS USB, but neither worked. At least I couldn't get anything to work.
      3. I could only locate two chips that look like bios chips. Could someone verify this
      01-03-2025, 12:32 PM
    • mkdj
      by mkdj
      Dear all,
      10-19-2025, 04:41 AM
