panasonic toughbook CF-31 Bios Password
  • Reda123456
    hi
    • Jan 2022
    • 86
    • iraq
    Hello
    who can unlock my laptop bios password
    Panasonic toughbook CF-31
    This is my locked bios
  • hoaca388
    Badcaps
    • Jan 2022
    • 11150
    • Viet Nam
    Re: panasonic toughbook CF-31 Bios Password
    Originally posted by Reda123456
    Hello
    Try
    Mọi khoản quyên góp cho Badcaps đều được hoan nghênh . Trở thành người ủng hộ Badcaps >>>>> nhấp vào liên kết này để quyên góp <<<<< Cảm ơn tất cả những người ủng hộ . -------------------------------------------------------------------------------------------------------------------------------------------------------------
    • Reda123456
      hi
      • Jan 2022
      • 86
      • iraq
      thank you its working
      • wolf3d.exe
        • Jan 2023
        • 33
        Panasonic cf-31
        I have a CF-31 with BIOS password.
        I followed posts from forum and followed https://gist.github.com/en4rab/55088...f3039e3c8ab6fd as guide.
        I downloaded both Universal BIOS backup toolkit and AMI BIOS flasher (AFUWINGUI.EXE) to obtain BIOS dumps. (Uni. Bios backup results in 8 mb file and the AMI BIOS flasher results 2mb file)
        I used Amidecyrptor and AMIDSEDecyript with no luck, the python one gives gibberish decode as password and the AMIdecyrptor gives nothing at all.
        When I open dump(s) with UEFI tool to manually decode, I cannot find "AMITSESetup". I cant see any NVAR entry.
        I am lost
        I need help Thanks
          • 20299
          Re: Panasonic cf-31
          Originally posted by wolf3d.exe
          I am lost
          I need help Thanks
          Use HxD hex editor,search for the text word AMITSE
          • wolf3d.exe
            • Jan 2023
            • 33
            Re: Panasonic cf-31
            I used .py code and replaced with BINARY data but instead of giving me a sequence it gives me a sha1 hash.
            • Vesko356
              VIP Moderator
              • Aug 2018
              • 4386
              • Bulgaria 🇧🇬
              Re: Panasonic cf-31
              Thank you for the tip, need further help with ciphered password
              I must disappoint you - it won't be the easy way if that's what you think.
              From here on, you take the classic way - programmer, dump, edit the dump, reprogram the chip with the edited dump, and so on.
              Become a Badcaps supporter
              Thanks to all supporters.
                • 20299
                Re: Panasonic cf-31
                It can`t be decoded,so the selected area wil need filling with zero`s ,there are 2 seperate areas that need filling.
                You might have a problem flashing the file back, if you can`t flash back with software then you will have to buy an SPI bios programmer.
                • wolf3d.exe
                  • Jan 2023
                  • 33
                  Re: Panasonic cf-31
                  Following this
                  He can decode with ease, I am using what you are highlighted, which is
                  5B 61 B6 46 11 4D 6C 78 C7 BE 22 FD 7D FB D8 5A 33 34 8E AA E9 01 44 C5 9F FA FA E2 55 FF B0 CC 0B 71 66 50 C1 47 1C 1F 77 16 D2 A9 2D 3D 88 D0 E3 63 3E F7 99 8A F4 1D 4F B1 AA 44 05 D8 60 6B
                  Is there a way to get UEFI Tool NE alpha 51? I looked everywhere but no luck. Just to get the right data.
                  • Vesko356
                    VIP Moderator
                    • Aug 2018
                    • 4386
                    • Bulgaria 🇧🇬
                    Re: Panasonic cf-31
                    He can decode with ease...
                    The decryption algorithm is absolutely different for the Panasonic CF-U1.
                    The same approach cannot be used in your case.
                    I told you above what you should do, but of course you can continue to waste your time.
                    • wolf3d.exe
                      • Jan 2023
                      • 33
                      Re: Panasonic cf-31
                      The reason I am trying because I have seen people offering this service, they just ask for dumps (without taking the laptop apart) with software and they provide a password. They ask for complete model number and dump. That means there is a way.
                        • 20299
                        Re: Panasonic cf-31
                        There might be some who know what the newer algorithm is,personally i don`t. If you want to pay go and find a seller,if they can unlock the new algorithm.If you want it done cheaper then buy a programmer,post the full backup and someone here will help for free
                        • wolf3d.exe
                          • Jan 2023
                          • 33
                          Re: Panasonic cf-31
                          Thank you, I am opening the laptop now. Will try to reach the BIOS chip
                          • wolf3d.exe
                            • Jan 2023
                            • 33
                            I finally reached the BIOS chip and took 3 dumps. In the past I cleared multiple passwords but for different laptops mostly hp and dells. Below is the BIN file for the BIOS, what are the steps to take to clear the passwords since I have multiple laptops?
                            Is it the same method as the poster explains (please see the attached picture)
                            Will I loose any DMI data?
                            I ask all these because, I don't want to put this laptop back and see something wrong and disassemble again...... I am sure you know what I mean
                            • Vesko356
                              VIP Moderator
                              • Aug 2018
                              • 4386
                              • Bulgaria 🇧🇬
                              I finally reached the BIOS chip...
                              The full dump must be 16MB, yours is 8MB?
                              What is the chip markings?
                              • wolf3d.exe
                                • Jan 2023
                                • 33
                                Originally posted by vesko356
                                the full dump must be 16mb, yours is 8mb?
                                what is the chip markings?
                                mx25l6406e
                                • Vesko356
                                  VIP Moderator
                                  • Aug 2018
                                  • 4386
                                  • Bulgaria 🇧🇬
                                  mx25l6406e
                                  all donations are welcome,
                                  • wolf3d.exe
                                    • Jan 2023
                                    • 33
                                    Thank you for this, since I have multiple of this, could you explain how to remove the password? Thanks again.
                                    • wolf3d.exe
                                      • Jan 2023
                                      • 33
                                      I compared both dumps and noticed crypted password was removed, thank you for the help. It was very valuable. But considering the work I rather make a hole right under the keyboard to reach the BIOS chip
                                      • pooya_pm
                                        • Jan 2021
                                        • 251
                                        • iraq
                                        panasonic -cf-31 bios DFUP2424ZD CF-31MK5 HAVE PASSWORD
                                        PLS UNLOCK BIOS
                                        • outsider
                                          Panasonic FZ-G1 MK5 - BIOS password returning
                                          by outsider
                                          Hello
                                          I removed the BIOS password thanks to the help of one of the friends of this forum.
                                          https://www.badcaps.net/forum/troubl...61#post3637661
                                          The batch from which the password was removed works correctly but... after some time, the BIOS password is set again, I reprogrammed the batch with the removed password, it's ok, there is no password, I set my password, ok, I can enter the BIOS with my password but...
                                          06-17-2025, 12:51 AM
                                        • zenius
                                          by zenius
                                          12-08-2024, 06:13 AM
                                        • traxformania
                                          TONGFANG "GM7TG7P" Bios Password Problem?
                                          by traxformania
                                          I tried :
                                          -I removed the BIOS battery and main battery. Waited for a long time but it didn't work. They already stated in the user manual that the password will not be reset even if the batteries...
                                          11-15-2023, 07:32 AM
                                        • Nopslide
                                          by Nopslide
                                          04-01-2024, 04:27 PM
                                        • AquaMan Ua
                                          by AquaMan Ua
                                          05-17-2025, 09:40 AM
