Inspiron 15 5566 BAL60 LA_D871p bios
  • haris199000
    • Nov 2019
    • 73
    • pakistan
    please help clearme bios for me original file attached
    • 20892
    Re: BAL60 LA_D871p bios clear me
    Post the full laptop model number and service tag
    • haris199000
      • Nov 2019
      • 73
      • pakistan
      Dell Inspiron 15-5566
      service tag: G6X71G2
      • hoaca388
        Badcaps
        • Jan 2022
        • 11735
        • haris199000
          • Nov 2019
          • 73
          • pakistan
          THANKS SIR its working
          • superbad
            • Aug 2019
            • brasil
            Re: Inspiron 15 5566 BAL60 LA_D871p bios clear me
            hello, I have a motherboard LA-D871P REV: 1.0 core i7 7th generation that turns on and gives video for about 30 seconds
            • hardware1
              • Sep 2021
              • 2930
              • N/A
              Upload your BIOS Backup here and someone will clean it for you.
              If your Motherboard contains 2 Chips you need to upload both of them.
              all donations are welcome,
              • crznet
                • Aug 2022
                • 4
                • Brazil
                service tag: JGVD3N2
                • exerion5000
                  • Aug 2014
                  • 83
                  • Argentina
                  Please help clearme bios for me original file attached,thanks in advace.
                  Inspiron 15 5566
                  TAG: 8831YF2
                  LA-D871P UMA
                    • 20892
                    Inspiron 15 5566
                    TAG: 8831YF2
                    LA-D871P UMA
                    Post what the problem is, be specific, - black screen, no boot, running slow, password.Do NOT post "clean me", "clear bios", "clean bios", "bios need" or other such terms
                    • exerion5000
                      • Aug 2014
                      • 83
                      • Argentina
                      O.K,SMDFlea ,new rules i see (post #1 and #2 answer by you SMDFlea what is?).
                      The image takes 50 seconds to appear after turning on, after that the device works perfectly, this happened after replacing the Core i3 processor with a short USB with a Core i7 rescued from another unused board.Regards.
                        • 20892
                        Rescued from what board model. If its not from a dell with bootguard 5 then disabling bootguard in the original dell bios should work.That can be done by changing the FIT settings while cleaning the ME firmware
                        • exerion5000
                          • Aug 2014
                          • 83
                          • Argentina
                          Pulled from Samsung laptop board with i7-6500u
                          I try clean with 2 files generated by MEinject software but no work
                          CF25Q128AS@SOIC8_dell i3 + ME 11.8.70.3626 - 11.8.70.3626_CON_LP_C_NPDM_PRD_RGN
                          CF25Q128AS@SOIC8_dell i3 + ME 11.8.70.3626 - 11.8.70.3626_SLM_LP_C_NPDM_PRD_EXTR
                          In fact, one of the 2 files created does not generate an image
                            • 20892
                            Its not recommended to use MEinject, at least not with anything above version 7 ME firmware.
                            https://www.badcaps.net/forum/showpo...41&postcount=3
                            Try the attached bios. EDIT: Do NOT use this bios if you have the original dell CPU/PCH
                            • exerion5000
                              • Aug 2014
                              • 83
                              • Argentina
                              Hello. After the third reboot the system starts perfectly thanks to the Magic that you did, I have a lot of skill in electronics and hardware repair but I am very lazy with the software, tell me how much I owe you for your precious time, best regards.
                                • 20892
                                I`m glad its working,you don`t owe anything,all help is given for free.Site donations are welcome but entirely optional.
                                All i did was clean the ME firmware using the guide,but i changed the bootguard profile from 5 to 0 ,and changed the OEM public key to zero`s .
                                • exerion5000
                                  • Aug 2014
                                  • 83
                                  • Argentina
                                  Thank you very much for sharing your valuable knowledge, I will soon donate to contribute to the maintenance of the site.
                                  • superhache
                                    • Nov 2018
                                    • 46
                                    • Argentina
                                    Hello, got this dell 15 5566 , with slow boot to logo around 33s, after that it works normally
                                    so can fix boot time and Clean ME ? thanks
                                    Dell Inspiron 15 5566
                                    pcb BAL60 LA-D871P Rev 1.0
                                    service tag: 9 P 7 N T F 2
                                    express: 2 1 1 1 5 5 6 3 9 5 0
                                    • wanderson15
                                      • Aug 2019
                                      • 5
                                      • brasil
                                      Hello everyone, how are you? I would like to know if anyone can help me fix a Dell Inspiron 15 5566 bios that does not post.
                                      Dell inspiron 15-5566-A10b
                                      Service Tag: 2ZP2SP2
                                      Express Service Code: 6512001734
                                      board model: BAL60 LA-D871P rev.: 1.00(A00)
                                      Core i3 6º
                                      I thank you in advance
                                        DELL Inspiron 5566 Notebook 5000 Specification for Upgrade or Repair
                                        This specification for the DELL Inspiron 5566 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 5566 boardview and 5566 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for DELL Inspiron 5566...
                                        09-06-2024, 07:30 AM
                                      • macabook
                                        by macabook
                                        🧩 Initial Issue
                                        07-24-2025, 02:17 PM
                                      • zlr8r
                                        looking for fully extracted by programmer Bios for a Dell Inspiron 17 (7786)
                                        by zlr8r
                                        looking for a fully extracted (by programmer) Bios for a Dell Inspiron 17 (7786) v.1.09 or newer, so I can compare it with my own bios to check for corruption.
                                        cheers
                                        Dell Inspiron 17 (7786) Laptop
                                        Service Tag: 5J0NHT2
                                        Bios: 1.9.0
                                        MOBO: RO 15 17 WHL 2GB MB / 18706-2
                                        Attached;
                                        1. My saved bios using a programmer
                                        2. Dells Bios updater .exe (v1.16)
                                        3. Dells Bios recovery file
                                        4. What I got when i tried to extract the main bios .bin file from Dells Bios v1.16 exe/rcv using some .py script i found online.
                                        5. Image of ME...
                                        12-18-2023, 03:08 PM
                                      • Vesko356
                                        by Vesko356
                                        08-11-2023, 03:27 AM
                                      • jbonavita
                                        by jbonavita
                                        Some issues
                                        Things I tried
                                        04-29-2025, 09:38 PM
