hp 240 G7
  • kesmeseker
    • Jan 2015
    • 117
    • turkey
    hp 240 G7
    Hi. I need hp 240 g7 bios dump
    granGer2-6050A3155201-MB-A01 mainboard.
    thanks...
  • hoaca388
    Badcaps
    • Jan 2022
    • 11687
    Re: hp 240 G7
    thanks...
    Where's your serial number ?
    Where's your original corrupt bios file ?
    • kesmeseker
      • Jan 2015
      • 117
      • turkey
      Re: hp 240 G7
      sn 5CG9447W4N (CASE)
      • hoaca388
        Badcaps
        • Jan 2022
        • 11687
        Re: hp 240 G7
        HP 240 G7 Notebook PC
        Serial number : 5CG9447W4N
        • kesmeseker
          • Jan 2015
          • 117
          • turkey
          Re: hp 240 G7
          thnaks......
          • kesmeseker
            • Jan 2015
            • 117
            • turkey
            Re: hp 240 G7
            no display.not working
            • hoaca388
              Badcaps
              • Jan 2022
              • 11687
              Re: hp 240 G7
              There is another version of this model. If it also doesn't work then your problem is not bios related.
              • kesmeseker
                • Jan 2015
                • 117
                • turkey
                Re: hp 240 G7
                The orj bios is corrupt. It works for 30 seconds. And then it shuts down after 5 seconds. then off.
                no power.
                • hoaca388
                  Badcaps
                  • Jan 2022
                  • 11687
                  Re: hp 240 G7
                  No, with original from Hp home page , it will work if your problem is bios error.
                  • kesmeseker
                    • Jan 2015
                    • 117
                    • turkey
                    Re: hp 240 G7
                    i change my eprom and try again dude
                    • DanielDacko
                      • Mar 2015
                      • 325
                      • Macedonia
                      Re: hp 240 G7
                      The file from post #4 should work, if it doesn't, check your programmer or try to find some other problems.
                      I don't provide help for people using CH341A and a clip.
                      • aqila
                        • Jul 2022
                        • indonesia
                        Re: hp 240 G7
                        hp 240 g7
                        sn:5CG9121MD5
                        • peste
                          • Dec 2016
                          • 12729
                          • ROMANIA
                          Re: hp 240 G7
                          Originally posted by aqila
                          hp 240 g7
                          sn:5CG9121MD5
                          What problem do you have??
                          • kassyhamza
                            • Nov 2019
                            • 9
                            • rwanda
                            Re: hp 240 G7
                            I need bios for 240 g7 sn:5CG1100MR0
                            • hardware1
                              • Sep 2021
                              • 2930
                              • N/A
                              Re: hp 240 G7
                              See if your bios chip is 8MB or 16MB, perhaps my hints will be useful.
                              all donations are welcome,
                                • 20781
                                Re: hp 240 G7
                                Serial number 5CG1100MR0
                                https://parts.hp.com
                                HP 240G7 i3-1005G1 14 4GB/1T PC
                                i3-1005G1 10th gen
                                Open each bios with ME Analyzer and look at the chipset support.It can`t be 08498 either as its KBP kaby lake with ME 11 firmware.
                                • hardware1
                                  • Sep 2021
                                  • 2930
                                  • N/A
                                  Re: hp 240 G7
                                  i3-1005G1 10th gen
                                  So, why when I search by the model number, it gives me 7 different CPUs!
                                  https://support.hp.com/ph-en/document/c06168317
                                    • 20781
                                    Re: hp 240 G7
                                    Thats the way HP bundle bios updates,for different models in the same updater or for the same model with different SKU`s, crazy i know.
                                    • exerion5000
                                      • Aug 2014
                                      • 83
                                      • Argentina
                                      Hi guys.
                                      Someone can Fix this corruped BIOS? (no screen after replace U66310 burned) , thanks in advance.
                                      Serial Number: 5cg9455lrt
                                      Product Number: 6GJ38LT
                                      Description: HP 240 G7
                                      Core i5-8265U
                                      GRANGER2-6050A3155201-MB-A01(A1)
                                      • Zutileza
                                        • Nov 2024
                                        • Bolivia
                                        Product Number: 151D6LT
                                        Description: HP 240G7 i3-1005G1 14 4GB/1T PC​
                                        • Habble7
                                          by Habble7
                                          Suspected Cause:
                                          Troubleshooting Attempts:
                                          05-22-2025, 07:28 AM
                                        • EGUG
                                          Bios Dump for Fujitsu Esprimo D7010n with Mainboard D3823-A2 required
                                          by EGUG
                                          I have a Fujitsu PC with defective bios after bios update from Windows. Therfore I need a bios dump to fix it.
                                          Serial number EICK023345
                                          Mainboard D3823-A2
                                          Hope somebody can help me.
                                          04-10-2025, 02:05 AM
                                        • TripTop
                                          Dell Latitude E7270 - Requesting BIOS clean/corrupt? service tag CB00KC2
                                          by TripTop
                                          Hi
                                          i have dell latitude E7270 with following symptoms:
                                          - takes long time to restart.
                                          - sometimes powers on and then off
                                          - sometimes while working it just dies,
                                          From googling online bios clean could possible resolve this?
                                          i was able to save bios and was going to try bios clean myself but get an below error when i drop it in ME analyzer.(unsure whether this sometimes occurs or could be due to bad/corrupt bios)
                                          As ME analyzer gave me an error i just decided to write bios with a cleaned bios from E7270 bios post.
                                          I reinstall...
                                          09-09-2024, 02:05 PM
                                        • DynaxSC
                                          by DynaxSC
                                          11-17-2023, 10:56 AM
                                        • MDSI
                                          HP OMEN 17-an012nf BIOS dump with EC (DAG3BAMBAF0 REV : F)
                                          by MDSI
                                          I'm requesting a full BIOS dump (including EC firmware) for an HP OMEN 17-an012nf laptop.
                                          Details:
                                          Model : HP OMEN 17-an012nf
                                          Motherboard Part Number : DAG3BAMBAF0 REV : F
                                          Serial Number (S/N) : 5CD7280D51
                                          BIOS chip : Winbond W25Q64VSIQ
                                          Programmer : EZP2023+
                                          Issue : The motherboard is not powering on. Only the 5V rail is present. The 3.3V rail is missing because EN1 on the SY8286B remains stuck at 0V. This signal is driven directly by the EC/SIO. I replaced the 3.3V regulator and confirmed it's working.
                                          I already...
                                          Today, 07:11 AM
