hp 240 G7
  • kesmeseker
    • Jan 2015
    • 121
    • turkey
    hp 240 G7
    Hi. I need hp 240 g7 bios dump
    granGer2-6050A3155201-MB-A01 mainboard.
    thanks...
  • hoaca388
    Badcaps
    • Jan 2022
    • 11815
    Re: hp 240 G7
    thanks...
    Where's your serial number ?
    Where's your original corrupt bios file ?
    • kesmeseker
      • Jan 2015
      • 121
      • turkey
      Re: hp 240 G7
      sn 5CG9447W4N (CASE)
      • hoaca388
        Badcaps
        • Jan 2022
        • 11815
        Re: hp 240 G7
        HP 240 G7 Notebook PC
        Serial number : 5CG9447W4N
        • kesmeseker
          • Jan 2015
          • 121
          • turkey
          Re: hp 240 G7
          thnaks......
          • kesmeseker
            • Jan 2015
            • 121
            • turkey
            Re: hp 240 G7
            no display.not working
            • hoaca388
              Badcaps
              • Jan 2022
              • 11815
              Re: hp 240 G7
              There is another version of this model. If it also doesn't work then your problem is not bios related.
              • kesmeseker
                • Jan 2015
                • 121
                • turkey
                Re: hp 240 G7
                The orj bios is corrupt. It works for 30 seconds. And then it shuts down after 5 seconds. then off.
                no power.
                • hoaca388
                  Badcaps
                  • Jan 2022
                  • 11815
                  Re: hp 240 G7
                  No, with original from Hp home page , it will work if your problem is bios error.
                  • kesmeseker
                    • Jan 2015
                    • 121
                    • turkey
                    Re: hp 240 G7
                    i change my eprom and try again dude
                    • DanielDacko
                      • Mar 2015
                      • 325
                      • Macedonia
                      Re: hp 240 G7
                      The file from post #4 should work, if it doesn't, check your programmer or try to find some other problems.
                      I don't provide help for people using CH341A and a clip.
                      • aqila
                        • Jul 2022
                        • indonesia
                        Re: hp 240 G7
                        hp 240 g7
                        sn:5CG9121MD5
                        • peste
                          • Dec 2016
                          • 12887
                          • ROMANIA
                          Re: hp 240 G7
                          Originally posted by aqila
                          hp 240 g7
                          sn:5CG9121MD5
                          What problem do you have??
                          • kassyhamza
                            • Nov 2019
                            • 9
                            • rwanda
                            Re: hp 240 G7
                            I need bios for 240 g7 sn:5CG1100MR0
                            • hardware1
                              • Sep 2021
                              • 2939
                              • N/A
                              Re: hp 240 G7
                              See if your bios chip is 8MB or 16MB, perhaps my hints will be useful.
                              all donations are welcome,
                                • 21040
                                Re: hp 240 G7
                                Serial number 5CG1100MR0
                                https://parts.hp.com
                                HP 240G7 i3-1005G1 14 4GB/1T PC
                                i3-1005G1 10th gen
                                Open each bios with ME Analyzer and look at the chipset support.It can`t be 08498 either as its KBP kaby lake with ME 11 firmware.
                                • hardware1
                                  • Sep 2021
                                  • 2939
                                  • N/A
                                  Re: hp 240 G7
                                  i3-1005G1 10th gen
                                  So, why when I search by the model number, it gives me 7 different CPUs!
                                  https://support.hp.com/ph-en/document/c06168317
                                    • 21040
                                    Re: hp 240 G7
                                    Thats the way HP bundle bios updates,for different models in the same updater or for the same model with different SKU`s, crazy i know.
                                    • exerion5000
                                      • Aug 2014
                                      • 83
                                      • Argentina
                                      Hi guys.
                                      Someone can Fix this corruped BIOS? (no screen after replace U66310 burned) , thanks in advance.
                                      Serial Number: 5cg9455lrt
                                      Product Number: 6GJ38LT
                                      Description: HP 240 G7
                                      Core i5-8265U
                                      GRANGER2-6050A3155201-MB-A01(A1)
                                      • Zutileza
                                        • Nov 2024
                                        • Bolivia
                                        Product Number: 151D6LT
                                        Description: HP 240G7 i3-1005G1 14 4GB/1T PC​
                                        • Ahari
                                          by Ahari
                                          I...
                                          08-13-2025, 06:12 AM
                                        • Habble7
                                          by Habble7
                                          Suspected Cause:
                                          Troubleshooting Attempts:
                                          05-22-2025, 07:28 AM
                                        • haitham sharabati
                                          [Request] Clean BIOS dump for HP 15-da2007ne (8XF55EA#ABV) - N4000 - BIOS Lock
                                          by haitham sharabati
                                          Hello engineers 😀,
                                          I’m kindly requesting a clean and unlocked BIOS dump for the following HP laptop, as it’s bricked after flashing SP152727. The system now keeps rebooting, and the original issue was an Administrator / Power-On Password that I can no longer access.😏
                                          🔧 Device Info:
                                          - Model: HP 15-da2007ne
                                          - Product Number: 8XF55EA#ABV
                                          - Serial Number: CND0338P0D
                                          - CPU: Intel Celeron N4000
                                          - EC/BIOS Chip: [Add chip number from the motherboard or BIOS chip]
                                          💀 Problem:😅
                                          - Device shows “Administrator Password”...
                                          08-07-2025, 04:54 AM
                                        • EGUG
                                          Bios Dump for Fujitsu Esprimo D7010n with Mainboard D3823-A2 required
                                          by EGUG
                                          I have a Fujitsu PC with defective bios after bios update from Windows. Therfore I need a bios dump to fix it.
                                          Serial number EICK023345
                                          Mainboard D3823-A2
                                          Hope somebody can help me.
                                          04-10-2025, 02:05 AM
                                        • Citymin
                                          by Citymin
                                          S/N : 5RNK9FFT70...
                                          08-05-2025, 05:12 AM
