HP fpi50 la-h329p bios dump needed help!
  • nitish300
    • Jul 2019
    • 21
    • india
    I was flashing the bios of hp fpi50 la-h329p rev:2
    Suddenly loptop restarts and is not turning on
    While the fan keeps runing
    • 20844
    Re: Dell fpi50 la-h329p bios dump needed help!
    Originally posted by nitish300
    I was flashing the bios of Dell fpi50 la-h329p rev:2
    Post the full laptop model number,service tag or serial,and your bios backup .
    • nitish300
      • Jul 2019
      • 21
      • india
      I have attached the photo of mother bord and model and sorry it is hp laptop
      • hoaca388
        Badcaps
        • Jan 2022
        • 11717
        Your original backup bios file ?
        • nitish300
          • Jul 2019
          • 21
          • india
          Re: HP fpi50 la-h329p bios dump needed help!
          Here is the dump file
          • Mazorca
            • Jan 2017
            • 463
            Try this file from hp website, I could not find your DMI on your backup, so you will have to enter your own. Check again your backup, do another one and compare. To enter your own info look here, post 17: https://www.badcaps.net/forum/showpo...7&postcount=17
              • 20844
              Your backup is corrupt,make another couple of backups before trying any other bios,and compare them to make sure both are the same.Are you using a sop8 clip with a CH341A programmer ? and what software version
              If the backup is corrupt due to the programmer,clip or software then theres a good chance that the bios you write back will also be corrupt.
              • nitish300
                • Jul 2019
                • 21
                • india
                Re: HP 15s-du2009TU fpi50 la-h329p bios dump needed help!
                i try the same with another laptop it is working fine i need a bios bin for this laptop i cant find it online
                  • 20844
                  Can you answer the questions,rather than telling us everything is working fine. I looked at your bios corruption and its consistent with a bad read .
                  • nitish300
                    • Jul 2019
                    • 21
                    • india
                    im useing ch341a and the sop8 clip
                    I have attach software im useing
                    i dont know much my friend helps me out most of the time but he is out of town
                    • hoaca388
                      Badcaps
                      • Jan 2022
                      • 11717
                      Available software include: NeoProgrammer, Colibri, AsProgrammer, Flashrom…
                      ASProgrammer is here - https://github.com/nofeletru/UsbAsp-flash/releases/
                      • nitish300
                        • Jul 2019
                        • 21
                        • india
                        im using xmc xm25qh128b chip cant find in asprogrammers
                          • 20844
                          Try NeoProgrammer. https://www.badcaps.net/forum/showpo...2&postcount=26 Also if you have a powered USB hub use that,or attach the charger to the laptop after attaching the clip,this will give the ch341a a bit more amperage.
                          If you have the black PCB version there`s a voltage mod you can do as well to make the programmer a bit more stable
                          https://www.badcaps.net/forum/showthread.php?t=103526
                          Quote:
                          If you have a black PCB, it is very likely that it needs to be modified for 3V operation instead of 5V. Failing to do so could damage the ROM IC.
                          Watch the instructions there:
                          https://www.youtube.com/watch?v=-ln3VIZKKaE
                          https://www.youtube.com/watch?v=HwnzzF645hA
                          • nitish300
                            • Jul 2019
                            • 21
                            • india
                            I did the mod and it's working fine now but i can't find another dump of hp 15s-du2009tu fpi50 la-h329p to program bios. i used neoprogrammer it has xmc spi-nor
                              • 20844
                              Post another backup,if its a good backup then your DMI (serial number,feature byte,win key) can be copied to a new bios using a hex editor easily.You can try the bios at post #6 but you will lose the DMI and windows key.The DMI can be added using HP DMI tools ,but its not easy if you`ve never used the tools before https://www.badcaps.net/forum/showpo...43&postcount=5
                              • nitish300
                                • Jul 2019
                                • 21
                                • india
                                That was the only backup I had post #5.
                                And i ask my friend he said the bios was corrupt and laptop was not turning on he downloaded a dump file from net and programmed the chip but now the laptop keeps restarting
                                • Hachem25
                                  • Aug 2021
                                  • 45
                                  • algeria
                                  try this one and report back
                                  • shabbir.asas
                                    • Oct 2018
                                    • 82
                                    • kuwait
                                    thnx its working for me
                                    • mnciks11
                                      • Aug 2019
                                      • 345
                                      • south Africa
                                      hello guys
                                      i have the bios file below that is bios locked ,i need bios removed, serial number : CND14037DW
                                      • hoaca388
                                        Badcaps
                                        • Jan 2022
                                        • 11717
                                        Originally posted by mnciks11
                                        hello guys
                                        This bios file for HP 250 G8 Notebook PC (1T4K6AV)
                                        Serial : CND1211WK4
                                        Product : 2V0W6ES
                                        • DynaxSC
                                          by DynaxSC
                                          11-17-2023, 10:56 AM
                                        • TacticalFahrrad
                                          [REQUEST] Fujitsu Lifebook E5513 – Full BIOS Dump Needed (.bin)
                                          by TacticalFahrrad
                                          I'm trying to recover a Fujitsu Lifebook E5513 (most likely 2023 model) that was bricked during a BIOS update. The update was interrupted (probably due to power loss), and now the laptop is stuck in a boot loop showing "PBB rollback" / "SBB rollback" messages.
                                          BIOS access (F2) and Boot Menu (F12) are no longer possible – the system instantly reboots after the rollback messages.
                                          I extracted the official BIOS update package from Fujitsu (contains FJNB2FD.CAP, ~18.7 MB) and tried tools like UEFIExtract, but it seems to only contain...
                                          06-30-2025, 04:09 AM
                                        • vinaypundith
                                          Razer RZ09-01682 Blade Stealth 13 2016 BIOS dump needed
                                          by vinaypundith
                                          I have this laptop that does boot but it's on an older BIOS that has issues with Secure Boot, and I cannot use the normal Razer BIOS updater because for some reason the serial number is missing / got deleted somehow (Common issue on this model, from what I've read). I got a dump of the BIOS chip (or at least what I think is the BIOS chip), and its 16MB in size - the files from the Razer BIOS update are 8MB. (There's two 8MB files, am I supposed to combine these somehow? Or combine with an Intel ME firmware? I have no idea).
                                          So, I'm looking for a BIOS dump for this machine - a 16MB one....
                                          08-03-2024, 12:32 PM
                                        • James Maxwell
                                          HP DM1-4000er Bios Dump needed
                                          by James Maxwell
                                          I badly need bios dump for HP DM1-4000er,
                                          Model: HP DM1-4000er
                                          Motherboard: DA0NM9MB6D0 REV.D
                                          Product: QJ490EA#ACB
                                          Please help. My bios chip burned so I don't have the old bios anymore. I need bios dump before I can install the replacement.
                                          10-28-2024, 05:38 PM
                                        • Habble7
                                          by Habble7
                                          Suspected Cause:
                                          Troubleshooting Attempts:
                                          05-22-2025, 07:28 AM
