Toshiba B553/J BIOS password problem
  • papieju
    • Jul 2022
    • Poland
    I put a standard password on the BIOS and the laptop does not accept it now. Ok, you can do a reset. I boot from F2, it asks for the password and the ctrl-tab-ctrl-enter key combination does not work. Shows the Not Certified message. Unplugging the BIOS battery did not help, resets the computer did not help, it happens both on the battery and on the AC power. I am in a deadlock, I do not know how to call up the codes needed to unlock. I assume that the password is not kept in the BIOS, so removing the bones and programming with the programmer will not help. The whole problem is that I have the Boot Menu blocked in the BIOS and in the event of an SSD failure, I will not be able to do anything after inserting a new SSD. Can anyone help me? In the laptop is the 3rd generation i5, if it matters, a laptop from the business line
  • traxformania
    TONGFANG "GM7TG7P" Bios Password Problem?
    by traxformania
    I tried :
    -I removed the BIOS battery and main battery. Waited for a long time but it didn't work. They already stated in the user manual that the password will not be reset even if the batteries...
    11-15-2023, 07:32 AM
  • zenius
    by zenius
    12-08-2024, 06:13 AM
  • cr4zychriss
    by cr4zychriss
    • Rebrand: PC Specialist
    11-14-2025, 04:04 PM
  • lucaszmn
    by lucaszmn
    Problem:
    Initial Findings:
    • I concluded that the
    08-12-2025, 03:01 PM
  • AquaMan Ua
    by AquaMan Ua
    05-17-2025, 09:40 AM
