I put a standard password on the BIOS and the laptop does not accept it now. Ok, you can do a reset. I boot from F2, it asks for the password and the ctrl-tab-ctrl-enter key combination does not work. Shows the Not Certified message. Unplugging the BIOS battery did not help, resets the computer did not help, it happens both on the battery and on the AC power. I am in a deadlock, I do not know how to call up the codes needed to unlock. I assume that the password is not kept in the BIOS, so removing the bones and programming with the programmer will not help. The whole problem is that I have the Boot Menu blocked in the BIOS and in the event of an SSD failure, I will not be able to do anything after inserting a new SSD. Can anyone help me? In the laptop is the 3rd generation i5, if it matters, a laptop from the business line
Toshiba B553/J BIOS password problem
by traxformaniaHello,
I'm using TONGFANG "GM7TG7P" model laptop for over 3 years and i'm entering the same bios administrator password everyday. My laptop has Aptio BIOS (American Megatrends, AMI).
But today it's not accepting my password. I'm %100 sure i'm entering the correct password.
I'm trying to reset my bios without success.
I tried :
-I removed the BIOS battery and main battery. Waited for a long time but it didn't work. They already stated in the user manual that the password will not be reset even if the batteries... -
Channel: BIOS Requests ONLY!
by AquaMan UaHello. I am asking you for a hint on how to solve the problem with my touchbook Panasonic CF53-2 standart model. After setting up the BIOS, the laptop displays the wrong image until Windows loads. (More precisely, it displays, but distorted, instead of the Panasonic image immediately after turning it on, it displays what is in photo #1 in the attached file) Then the image appears when Windows starts loading and then there are no problems with the screen until the reboot. If you enter the BIOS, just a black screen. If you connect an external screen, the image on it is the same as on the built-in...2 Photos
by outsiderHello
I removed the BIOS password thanks to the help of one of the friends of this forum.
https://www.badcaps.net/forum/troubl...61#post3637661
The batch from which the password was removed works correctly but... after some time, the BIOS password is set again, I reprogrammed the batch with the removed password, it's ok, there is no password, I set my password, ok, I can enter the BIOS with my password but...-
by RMDUiFTGood day. I apologize if I posted this in the wrong topic. I saw somebody selling a Thinkpad E495 with a Ryzen 3500U CPU near me. In the pictures the laptop is running windows 10. I contacted the seller and asked a few questions about upgradability and if it has a bios password on it. He confirmed it has a bios password. I searched through the forum, I found a guide regarding removing the bios password using the autopatcher, I also found a thread with the e495 where people requested help with unlocking the bios password.
I have a few questions:- If I would buy this laptop and have
- Loading...
