Dump Asus Vivobook Pro 14 15 M3500QA ver. 2.1
  • peste
    • Dec 2016
    • 13581
    • ROMANIA
    Originally posted by pooya_pm
    I need IT5121VG-I-128 bios.
    read the rules..https://www.badcaps.net/forum/troubl...before-posting
    post the S/N, the original bios of the laptop, the motherboard model, the full name and model of the laptop,EC bios if possible..etc..
    • dejanos87
      • Dec 2015
      • 26
      • slovenija
      hello, can someone please check the bios dump, the computer turns on but there is no image​
      • piszpunta
        • Jan 2019
        • 255
        • poland
        try
        • dejanos87
          • Dec 2015
          • 26
          • slovenija
          thanks piszpunta​ but it's not working...:-(
          • Mehmet Korhan
            • May 2024
            • 31
            Hey guys! Which one of these is the bios chip I need to reprogram exactly ?
            from my experience it’s usually the winbond one. But I wanna make sure.
            also, I need the correct bin file for this model.
            Ryzen 5
            Board model is: M3500QA R2.1
            serial number is: MAN0CX099389417
            • hoaca388
              Badcaps
              • Jan 2022
              • 12330
              #26
              Ryzen 5
              25LB128DSIG
              • Mehmet Korhan
                • May 2024
                • 31
                Originally posted by hoaca388
                25LB128DSIG
                Thank you! I connected it to
                my reader and it says it’s empty.
                anyone got the bin file for this?
                • Mehmet Korhan
                  • May 2024
                  • 31
                  Hey, so i took off the GigaDevice one you told me to remove and its an 8 MB one but the dumps on here are 16 MB. Is it the winbond chip instead?
                  attached my dump i saved.
                  • Mehmet Korhan
                    • May 2024
                    • 31
                    WONT LET ME EDIT Sorry for the multiple posts: So I read again, it's a 1.8v chip. Had to use an adapter. Tried reading and then erasing then writing. Gives an error when verifying. I am using EZP2023+. Do I need to get another programmer? This one supports up to GD25LQ128(1.8v).The chip I have is GD25LB128DSIG.
                    Please help. I need to reprogram this asap.​
                    • Mehmet Korhan
                      • May 2024
                      • 31
                      Does anyone have a working bios for this? Tried all the ones in the post but im not getting an image and the fans aren't spinning.
                      Charger light is on and battery light blinks every 5 secs.
                      Please help. I can't figure it out!
                      Ryzen 5
                      serial number is: MAN0CX099389417​
                      • peste
                        • Dec 2016
                        • 13581
                        • ROMANIA
                        #31
                        Ryzen 5
                        how can we help you if you don't post the bios!! the laptop bios should have 16MB, you posted an 8MB bios and that one is empty...learn to work with the programmer..post here what you are asked for and you will be helped. .you can find tutorials on the net, for using that programmer..
                        • Mehmet Korhan
                          • May 2024
                          • 31
                          Thank you for your reply. Unfortunately,the original bios is messed up. Couldn't read and save it. Someone previously attempted at repairing it. The one I saved is 16mb and its empty too. I bought a new programmer (The T48). I can program it easily now but it's corrupted. That's why i'm asking for the bios dump for my laptop with specs i gave. Much appreciated!
                          • peste
                            • Dec 2016
                            • 13581
                            • ROMANIA
                            #33
                            ok... read post#6..
                            • Mehmet Korhan
                              • May 2024
                              • 31
                              ok... read post#6..
                              here ya go boss. These are the only ones I saw.
                              • peste
                                • Dec 2016
                                • 13581
                                • ROMANIA
                                #35
                                try the first option from post#2..M3500qa...
                                • Mehmet Korhan
                                  • May 2024
                                  • 31
                                  Read post #30. I’ve tried every single one. They’re not working 😔
                                  • Ziome3eknh
                                    • Dec 2021
                                    • 61
                                    • Poland
                                    #37
                                    Hello, I'm piggybacking on this topic
                                    I have a M3500QA R2.1 board
                                    SN MBN0CX24K511462
                                    Qrcode subtitles
                                    141100148
                                    31XJEMB0560 D3A
                                    I need a working BIOS dump, preferably with BIOS version 311
                                    I don't know why, but older versions don't work for him. One went in but the BIOS crashed later and it's still the same, I'm sending an old backup, maybe it'll be helpful.​
                                    • hoaca388
                                      Badcaps
                                      • Jan 2022
                                      • 12330
                                      #38
                                      SN MBN0CX24K511462
                                      Qrcode subtitles
                                      141100148
                                      31XJEMB0560 D3A
                                      I searched by serial number and got the result
Name:	2024-11-23 18_04_36-Download Center _ Official Support _ ASUS Global.png
                                      • Ziome3eknh
                                        • Dec 2021
                                        • 61
                                        • Poland
                                        #39
                                        This is exactly the model you found in the photo on the Asus website. But the motherboard has the markings I wrote above. It turns out that it was installed in several vivobook models.
                                        • hoaca388
                                          Badcaps
                                          • Jan 2022
                                          • 12330
                                          #40
                                          ASUS Vivobook Pro 14X OLED (M7400, Dòng AMD Ryzen 5000)
                                          • shadow666
                                            ASUS Vivobook M3500QA Dump Bios
                                            by shadow666
                                            Hi
                                            i need dump bios for
                                            Motherboard : M3500QA
                                            Rev : 2.1
                                            CPU : AMD Ryzen 7 5800H
                                            GPU : NVIDIA GeForce RTX 3050
                                            i tested any bios in this topic but don,t working , I think the files placed in this thread are for the uma motherboard
                                            Code:
                                            https://www.badcaps.net/forum/troubleshooting-hardware-devices-and-electronics-theory/troubleshooting-laptops-tablets-and-mobile-devices/bios-requests-only/95276-dump-asus-vivobook-pro-15
                                            i,m attached backup bios & problem is notebook power on but don,t boot and blank screen
                                            Regards...
                                            01-10-2024, 10:41 AM
                                          • mkdj
                                            by mkdj
                                            Dear all,
                                            10-19-2025, 04:41 AM
                                          • razor_amd
                                            by razor_amd
                                            12-15-2020, 07:07 PM
                                          • pirati
                                            by pirati
                                            10-27-2025, 04:20 PM
                                            ASUS VivoBook ASUS VivoBook 15 S513 FHD i5 16GB/512GB G3 SSD Notebook 15 Specification for Upgrade or Repair
                                            This specification for the ASUS VivoBook ASUS VivoBook 15 S513 FHD i5 16GB/512GB G3 SSD Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the ASUS VivoBook 15 S513 FHD i5 16GB/512GB G3 SSD boardview and ASUS VivoBook 15 S513 FHD i5 16GB/512GB G3 SSD schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant...
                                            09-07-2024, 02:50 AM
