Lenovo E14 NM-D011 Rev. 1.0 TYPE 20TA Bios request
  • hoaca388
    Badcaps
    • Jan 2022
    • 12243
    #41
    Originally posted by niherasebe88
    Lenovo Thinkpad E14 gen2
    Board GE4B0/GE5B0 NM-D011 rev 1.0
    SN PF2HRFX9
    maybe someone can help me.
    When pressing the button, it turned on and immediately turned off
    Standby voltages of 3 and 5 volts appeared
    IT8227E-256 was not detected in the programmer (SUCCESSOR)
    After many attempts, I managed to dump it
    IT8227E-256 was replaced with a new one and flashed with the dumped one
    The laptop began to turn on, all standby voltages appeared, but there is no image, the power button blinks and turns off
    Tried different BIOS dumps from this site and vlab
    Flashed IT8227E-256 and 25R256JVEQ together and separately, the result changed But there was no image
    I am 100% sure that my problem is in the wrong BIOS
    Perhaps the dump 256 Kb is also faulty
    Maybe someone has a set of 256 Kb and 32768 KB
    Thanks in advance
    E14 Gen 2 Laptop (ThinkPad) - Type 20TA
    • niherasebe88
      • Mar 2022
      • 5
      • rossia
      #42
      SN PF2HRFX9
      Thank you for your help. Yesterday I programmed your dump
      T8227E-256 and 25R256JVEQ the laptop turns on with the button and immediately turns off
      I tried probably all the options from this forum for the NM-D011 rev 1.0 board, but none helped the result either does not turn on or cyclic reboot or immediately turns off, the indicator blinks 3 times
      After numerous attempts to program with different versions of T8227E-256 and 25R256JVEQ I got a stable result, the laptop turns on, the processor heats up, the cooler turns on, the battery is charging, but there is no image
      I am posting a dump with which it works without an image
      Thank you​
      • shiyab
        • Sep 2023
        • 1592
        • india
        #43
        SN PF2HRFX9
        Thank you
        hi try and feedback
        • niherasebe88
          • Mar 2022
          • 5
          • rossia
          #44
          Thank you! Your bios dump cured my laptop!!! YOU ARE A GENIUS
          the disk was detected and the system booted
          THANK YOU for your help and support
          Merry Christmas and Happy New Year to all
          • ThinkpadMounty
            • Sep 2023
            • 14
            Trying to fix no picture issue with Lenovo E14 and having tried many other things would like to try a bios
            chip is Winbond 25R256JVEN
            SERIAL NO PF3D3N83
            MOD TYPE 20TA-004QUS
            Current dump attached if someone can check or provide alternative to try that would be appreciated
              SMDFlea commented
              Editing a comment
              Thread merged.Please make use of the forum search before posting to find related threads where you can post your request.You do not need to start a new thread every time.
          • hoaca388
            Badcaps
            • Jan 2022
            • 12243
            #46
            SERIAL NO PF3D3N83
            • pepebmx
              • Aug 2020
              • 11
              • Argentina
              #47
              Dear friends, this is E14, power on no display, no fan, all voltages present. Beeps ocasionaly, not always. Mosfets on the back are in place Could yo please check if it is correct. Dead after firmware update.
              Lenovo ThinkPad e14 Gen2
              S/N: MJ-0GWH1A
              Board Label: GE4B0/GE5B0 NM-D011 Rev 1.0
              Type #: 20TA-002CUS
              bios chip 25r256jveq with black resin of death.
              Thanks a lot!
                SMDFlea commented
                Editing a comment
                Post moved to E14 20TA thread topic.
            • hoaca388
              Badcaps
              • Jan 2022
              • 12243
              #48
              S/N: MJ-0GWH1A
              Type #: 20TA-002CUS
              Thanks a lot!
              • pepebmx
                • Aug 2020
                • 11
                • Argentina
                #49
                Thanks gona try tomorrow. I see there is one ite.bin should i flash it to? I dont have svod 4 but could get one if it is necessary.
                • pepebmx
                  • Aug 2020
                  • 11
                  • Argentina
                  #50
                  Didn't work. Same symptoms. Thanks anyway!
                  • theBread
                    • Apr 2022
                    • 16
                    Hi ^^
                    I have a E14 Gen2 that boots, but then throws
                    Code:
                    0183: Bad CRC of Security Settings in EFI variable.
                    I cannot continue booting and entering the BIOS prompts for a supervisor password that probably doesn't exist. Entering the BIOS anyway by using maxpowers EC bypass method and emptying the supervisor password doesn't result in an update notification and exiting the BIOS yields
                    Code:
                    Failed to save storage: LenovoSecurityConfig. Status: Time out.
                    and
                    Code:
                    0187: EATA access error
                    after a reboot.
                    I can't tell if the BIOS itself is at fault or the EC and I sadly don't own an EC programmer. Also, the schematic and boardview reads like the EC firmware is in the BIOS firmware as well, is that correct?
                    S/N: PF-3FPE9T
                    Type: 20TA-00EWGE
                    Board: GE4B0/GE5B0 NM-D011 Rev 1.0
                    BIOS Chip: 25R256JVEN
                    I'd be very happy if someone could fix my BIOS dump or at least point me to the right direction.
                    • Laboratorio JG
                      • Apr 2025
                      • 29
                      • Colombia
                      #52
                      Could you help me with this BIOS? The machine is beeping as soon as it turns on and doesn't give an image. I tried the BIOS published here, but some do the same thing. So I opted for the original BIOS to see if you could help me.
                      model: THINKPAD E14 GEN 2
                      model board: GE4B0/GE5B0 NM-D011 REV 1.0
                      SN: PF39TZAN
                      20TB-S1P900
                      • gabo5x
                        • Dec 2022
                        • 18
                        • Brazil
                        #53
                        Hello I need working bios for this laptop
                        Lenovo ThinkPad E14 Gen2
                        Motherboard ge4b0/ge5b0 nm-d011
                        SN: PE0AAVSA
                        Thanks in advance!
                        • peste
                          peste commented
                          Editing a comment
                          post merged...next time look for a thread with the name and model, motherboard model of the laptop, and post there, if you can't find it, then make a new thread..
                      • bejaoui
                        • Feb 2017
                        • 61
                        • ariana
                        #54
                        Lenovo E14 NM-D011 Rev. 1.0 TYPE 20TA-002CSP
                        NO SERIAL NUMBER
                        power on no display
                        • shiyab
                          • Sep 2023
                          • 1592
                          • india
                          #55
                          NO SERIAL NUMBER
                          power on no display
                          hi try
                          • bejaoui
                            • Feb 2017
                            • 61
                            • ariana
                            #56
                            Originally posted by shiyab
                            hi try
                            think you very match
                            • giggid
                              • Sep 2025
                              • Italia
                              #57
                              Hi, I have a ThinkPad E14 Gen2 20TA-000CIX. The PC had trouble booting up, often the usual 3 flashes, and then pressing "Return" would turn it on, but not always. I successfully updated the BIOS, but it no longer turned on. The laptop doesn't have a password. I need a clean, working BIOS file. I'd like to post a dump of my chip and would like to know which EPROM to read. Thanks.
                              • giggid
                                • Sep 2025
                                • Italia
                                #58
                                sn PF-2VB75K
                                • peste
                                  • 13350
                                  • ROMANIA
                                  #59
                                  sn PF-2VB75K
                                  the 32MB one......
                                  • giggid
                                    • Sep 2025
                                    • Italia
                                    #60
                                    Originally posted by peste
                                    the 32MB one......
                                    yes .
                                    Can this be okay?
                                    NO SERIAL NUMBER
                                    power on no display
                                    hi try
                                    • akwky
                                      by akwky
                                      Hi!
                                      04-14-2025, 01:56 PM
                                    • lucaszmn
                                      by lucaszmn
                                      Problem:
                                      Initial Findings:
                                      • I concluded that the
                                      08-12-2025, 03:01 PM
                                    • mximiliandz
                                      help bios lenovo ideapad s145-14iil type 81w6
                                      by mximiliandz
                                      Good morning, gentlemen, I hope you can help me with my laptop, I told you that I saved it about 2 years ago because it wouldn't turn on, now I have a ch341a programmer, I made a backup of the bios, I flashed an original downloaded from lenovo and it started, but it turned off after a few minutes, I entered the bios configuration and the brand, model, serial number, windows serial number, etc. did not appear, I request your help, I did everything I found in the forum but I could not solve it, also now it won't start again, it turns on but the fan does not turn, I will share all the information...
                                      06-20-2025, 06:50 AM
                                    • Wahaz
                                      by Wahaz
                                      10-30-2023, 08:42 PM
                                    • cyber16
                                      Lenovo P1 g1 Type 20MD-002PUS "BIOS Help Needed"
                                      by cyber16
                                      Please I need help.
                                      Quick rundown long story shorter, but still long winded.
                                      I received this Lenovo P1 GEN 1 about a year ago from a business.
                                      It was pretty much dead hit the power button and the LED on the power light would come on as would the keyboard back light a couple times and just shut off or go into high speed fan mode without life other than the power button led.
                                      At that time it was still under warranty, I spoke to Lenovo and I was going to send it in to have them repair it.
                                      Then late last fall my father-in-law suffered...
                                      09-08-2022, 07:32 AM
