A315-55KG ec bios. Motherboard DA0ZAUMB8D0
  • muradterzi
    • Aug 2017
    • 40
    • Türkiye
    I need Acer Aspire A315-55KG ec bios. Motherboard DA0ZAUMB8D0 REV
    • 21679
    Re: A315-55KG ec bios. Motherboard DA0ZAUMB8D0
    post the laptop serial and full model number,such as NX.HEHER.004 ,it will be on a sticker on the base cover.
    Post your bios backup as well,the ec can often be copied from the bios region
    • hoaca388
      Badcaps
      • Jan 2022
      • 12271
      Aspire A315-55KG-EC
      • muradterzi
        • Aug 2017
        • 40
        • Türkiye
        Thank you, i will try.
        I'll let you know
        • muradterzi
          • Aug 2017
          • 40
          • Türkiye
          I'll let you know
          This bios worked. Thank you.
          • krusty09521
            • May 2021
            • ireland
            Acer A315-55KG-34FV Bios
            Aspire 3 A315-55KG-34FV
            Board: DA0ZAUMB8E0 Rev: E
            Thanks in advance, cant seem to find bios anywhere...
              • 21679
              Re: Acer A315-55KG-34FV Bios
              • krusty09521
                • May 2021
                • ireland
                S/N: NXHEHEK0030251F17070600 , Model N18Q13
                • glovecaps
                  by glovecaps
                  11-25-2024, 04:23 PM
                • EbrahimSiami
                  Acer Aspire 5920G - Requesting Modded BIOS (9600M GT) from .WPH for CH341A Flasher
                  by EbrahimSiami
                  I need help with my Acer Aspire 5920G laptop. Its original GeForce 8600M GT graphics card failed, so I replaced it with an Nvidia GeForce 9600M GT MXM card.
                  **Problem:** The laptop powers on, but there is no display (black screen) on either the internal LCD or external monitor. This indicates a BIOS compatibility issue with the new graphics card.
                  **What I have tried so far:**
                  1. I have my **original stock BIOS dump (1MB .BIN file)** from my laptop, which works and allows the laptop to power on normally (but no display with 9600M...
                  07-02-2025, 02:31 PM
                • fluzocapacitor
                  ACER Aspire 5542 does not boot. Can not read BIOS on the motherboard
                  by fluzocapacitor
                  I am trying to fix an Acer Aspire 5542. Upon turning it on, the fan starts to spin for a few seconds and then it stops. I hear no beeps from the speaker. I have no image both on the laptop screen and through VGA and HDMI connectors.
                  I measured voltages, and it seems all power supplies are OK. There are 5V, 3.3V (BIOS), 1.8V (RAM), and 1.1V (VCORE).
                  I tried to read the BIOS using a CH341A programmer, but it did not detect the chip. I took the BIOS chip away from the motherboard, and then the CH341A detected the chip, and I was able to read the code. However,...
                  02-01-2024, 01:24 PM
                • oragano
                  ASUS ex-b250-V7 motherboard bios corrupted - by me
                  by oragano
                  hey all, i did a silly thing and flashed bios to perfectly working board. None of the asus official download bios would work with ez flash. They all gave error saying not supported bios file. I tried using uefi tool to extract it to a bin file but then ez flash wouldnt even recognise it.
                  So, i used freedos and afudos with the aforementioned bin file i extracted and forced the issue. After bios reprogram, reboot and it was dead. Fans spinning but no post.
                  i have a bios writer and none of the .cap files from the official site work either. I just get one spin, then off, then all fans...
                  10-17-2024, 02:53 AM
                • AkaBukai
                  Is it okay to flash stock bios onto the motherboard's BIOS?
                  by AkaBukai
                  Hi there,
                  I have a 14" Lenovo Laptop (Flex 5 14ALC05) which has a boot issue.
                  The little LED on the power button is flashing slowly and nothing happen.
                  This unit do not have any BIOS button cell battery so I tried many times draining the power but it is still not powering on.
                  So I decided to flash the BIOS using a cheap programmer.
                  And I was successfully able to read the content (exactly 16MB file) which BTW is a WINBOND 74m12jwsiq (according to the package inscription - but detected as W25Q128FW in the software - IMSProg on Linux)
                  I also...
                  12-19-2024, 12:15 PM
