Apple MacBook Air A1932 EMC 3184
  • mferna14
    • Jun 2018
    • 1017
    I am working on Apple MacBook Air A1932 EMC 3184., NO DISPLAY. I observe in the background the logic board seems to be running, the voltages are ok & the board is taking the required AMPs through the AMP meter connected to it's Original power adapter. I am assuming that this BIOS has to be re-build. I am attaching the ORIGINAL BIOS Bin files taken off the logic board, can anyone rectify & re-build this BIN file. The files on this thread "https://www.badcaps.net/forum/showthread.php?t=104860" does not seem to be correct as the BIN files size for this model is 1024KB where as my Original bin files size is 4096 KB. The chip is U4770 1.8V SPI SOCROM. Thanks in advance.
  • mferna14
    • Jun 2018
    • 1017
    Re: Apple MacBook Air A1932 EMC 3184
    Can someone help.. or this BIOS Dump cannot be re-build????
      Apple MacBook Air Retina A1932 820-01521 Schematic & Board View
      Apple MacBook Air Retina A1932 820-01521 Schematic & Board View...
      10-03-2024, 04:25 AM
    • bouch
      unlock macbook air A1932 2019
      by bouch
      hi
      i whant unlock macbook pro A1932 2019 whit ibridge 9,3 ;
      i change efi files find on files mina T2 activator 1,4 and use for activation mina T2 activator 1,3 , but fault ssh?
      i use mina T2 ramdisk activator 1,0 and 3,0 . but whon t work ?
      have you other programme or method compatible whit this macbook ibridge 9,3 for bypass ?
      I need help or information?
      Does anyone have the minat2 activator 1.4 software?
      Or did they use it for bypass macbook air 2019 a1932 with new ibridge 9.3?
      Thank yo...
      03-12-2025, 10:14 AM
    • samstown
      Apple 076-00236 Genuine Apple Data Migration Tool for MacBook Pro 2016 2017
      by samstown
      This special tool from Apple is used to recover data from Macbook A1706. I've been using it for a while but it stops working. When connecting Thunderbolt 3 between the tool and working Macbook, Macbook should prompt "new device detected, allow or not"... but it doesn't.
      Has anyone ever experience this ? It's not a cabling or power supply issue, some IC have stopped working but not sure which one. Probably the one that manager thunderbolt 3
      Claude...
      05-09-2024, 02:02 AM
    • TOMÁŠ
      MacBook Air A1932
      by TOMÁŠ
      Hi, I've never worked with a MacBook before, so I need some advice.
      I have a MacBook Air A1932 (820-01521). When I plugged in the charger with an amp meter, it showed 19.7V and 1.9A, which indicates that it's charging, but when I press the power button, it doesn't turn on. So, I disassembled it, disconnected the battery, and plugged in the charger again. It showed 19.6V and 0.04A, and pressing the power button had no effect—no current draw at all. Then, I removed the motherboard, connected the charger again, and got the same results. I took a multimeter and checked all the coils, and everything...
      05-20-2025, 11:19 AM
    • astroboypaul
      Macbook A1932 Some Keys Not Working
      by astroboypaul
      Macbook A1932 had completely dead keyboard. I found liquid damage on circuitry on keyboard itself, and repaired it by replacing what i think was a 10k 0201 resistor (here's my post requesting schematic for keyboard circuitry where I included a photo of the resistor: https://www.badcaps.net/forum/troubl...ic-820-01294-a)
      Now most of the keyboard works and I can login, but the following keys don't work: Delete, "/', left...
      06-10-2024, 05:32 AM
