Lenovo IdeaPad Flex 5 14ITL05 bios dump
  • hardware1
    • Sep 2021
    • 2949
    • N/A
    #41
    Re: Lenovo IdeaPad Flex 5 14ITL05 bios dump
    Originally posted by 230Volt
    Thank you. The laptop started, the display still does not work, only HDMI. I think it's a hardware problem. Need to find flex eDP
    You're welcome, go to the Hardware section and post your request there.
    https://www.badcaps.net/forum/forumdisplay.php?f=23
    all donations are welcome,
    • ahmet06
      • Nov 2017
      • türkey
      #42
      Hello, I have sent the corrupted bios. Can you help with the fix?
      Model : IdeaPad Flex 5 14ITL05
      S/N : PW00002T
      MTM : 82HS00FFTX
      MO : PWN0B1A06002
      • Vesko356
        VIP Moderator
        • Aug 2018
        • 4386
        • Bulgaria 🇧🇬
        #43
        S/N : PW00002T
        MTM : 82HS00FFTX
        MO : PWN0B1A06002
        Use the bios at post #25, replace the DMI and Windows key in the dump with the one from your backup using offsets:
        DMI 1461000 - 14613FF
        Windows key 1420000 - 14200BF
        Become a Badcaps supporter
        Thanks to all supporters.
        • ahmet06
          • Nov 2017
          • türkey
          #44
          Worked. Thank you very much.
          • Vesko356
            VIP Moderator
            • Aug 2018
            • 4386
            • Bulgaria 🇧🇬
            #45
            You're welcome.
            • 70star
              • Aug 2014
              • canada
              #46
              Please help to fix this bios. CAps lock on black screen.
              code board LC56-14T 203013-1 448.0K121.0011 s.n.10000sr9117rba0
              Thanks you.
              • peste
                • Dec 2016
                • 13891
                • ROMANIA
                #47
                Thanks you.
                try post #2...
                https://www.badcaps.net/forum/showth...hlight=14ITL05
                • peñacruz
                  • Sep 2023
                  • Mexico
                  #48
                  Hello, please, you are my last hope and I need your help. I updated my BIOS and it didn't turn on anymore. What device is suitable for flashing the Gigadevice GD25R256DYING brand BIOS? Or could any member of the forum tell me which programmer they use for this model of bios chip.
                  IDEAPAD FLEX 5 14ITL05
                  MODEL: 82HS
                  S/N: PW00TX77
                  MTM: 82HS00R9US
                  MO: PWN0B2104001
                  Thank you very much and excuse my bad English.
                  • peste
                    • Dec 2016
                    • 13891
                    • ROMANIA
                    #49
                    MODEL: 82HS
                    S/N: PW00TX77
                    MTM: 82HS00R9US
                    MO: PWN0B2104001
                    you could search the internet yourself for each programmer's database..
                    • raf007
                      • Sep 2023
                      • 5
                      • BE
                      #50
                      Hello friends, can anyone help me with my BIOS please.
                      Serial number R91191SC
                      Thanks in advance
                      • peste
                        • Dec 2016
                        • 13891
                        • ROMANIA
                        #51
                        Thanks in advance
                        read ..
                        read post #43..
                        • raf007
                          • Sep 2023
                          • 5
                          • BE
                          #52
                          Originally posted by peste
                          Thanks for your feedback and info.
                          • raf007
                            • Sep 2023
                            • 5
                            • BE
                            #53
                            Thanks in advance
                            bump.Any help please.
                            • peste
                              • Dec 2016
                              • 13891
                              • ROMANIA
                              #54
                              read post#51..
                                • 22236
                                https://www.badcaps.net/forum/showpo...5&postcount=43
                                If you can`t add the DMI info yourself let us know.
                                • raf007
                                  • Sep 2023
                                  • 5
                                  • BE
                                  #56
                                  Thanks a a lot it worked very well.
                                  The laptop is back online again.
                                  Thanks again for your help.
                                  • bhteam
                                    • Jan 2016
                                    • 7
                                    • Bulgaria
                                    #57
                                    I'm trying to repair a Lenovo Flex 5 15ITL05 LC56-14T laptop.
                                    The laptop had liquid spilled on it. After pcb repair, all voltages are present and the laptop starts. Caps lock and num lock are illuminated. Fan spins shortly, then stops and then starts again and goes from 0% to 100% and stays at 100%. Battery is charging, so the SIO is working fine. Display is black and does not post.
                                    I'm guessing that the BIOS might be corrupted. This is a dump of it.
                                    Can anyone please help me clean it? Or Uncorrupt it? I'm not sure how to do it.
                                    • hoaca388
                                      Badcaps
                                      • Jan 2022
                                      • 12432
                                      #58
                                      Serial number ?
                                      • bhteam
                                        • Jan 2016
                                        • 7
                                        • Bulgaria
                                        #59
                                        Originally posted by hoaca388
                                        serial number ?
                                        pw00ry4n
                                        • OmanCloud
                                          • Aug 2023
                                          • 19
                                          • Oman
                                          #60
                                          Flex 5-14ITL05
                                          working thank you sooooo much 100% Good
                                            Lenovo IdeaPad Flex 5 14ITL05 Hybrid (2-in-1) Flex Specification for Upgrade or Repair
                                            This specification for the Lenovo IdeaPad Flex 5 14ITL05 Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Flex 5 14ITL05 boardview and Flex 5 14ITL05 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                            09-07-2024, 04:30 AM
                                          • Ahari
                                            by Ahari
                                            I...
                                            08-13-2025, 06:12 AM
                                          • Jogger9663
                                            Flex 5-14ITL05 Laptop (ideapad) - Type 82HS bricked after BIOS update
                                            by Jogger9663
                                            Hello all! New here, trying to fix a Lenovo Flex 5 14ITL05 laptop.
                                            TL;DR: How do you connect a programmer to a "leg-less" SPI Flash chip? Model: Winbond W25R256JVEIQ on a board with part number 5B21B33119.
                                            Attached are photographs of the board for context. One is of the SPI chip close-up, the other is of the full board with the chip highlighted.
                                            I have a Lenovo Flex 5 14-ITL05 with the following symptoms following a BIOS update:
                                            • Black screen / no display
                                            • Caps lock indicator stuck ON
                                            • Power LED blinking
                                            • FN Lock key on at boot, but can be toggled
                                            12-14-2022, 02:12 PM
                                            Lenovo IdeaPad IdeaPad Flex 5 14ALC05 Notebook Specification for Upgrade or Repair
                                            This specification for the Lenovo IdeaPad IdeaPad Flex 5 14ALC05 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the IdeaPad Flex 5 14ALC05 boardview and IdeaPad Flex 5 14ALC05 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                                            09-07-2024, 04:10 AM
                                            Lenovo IdeaPad IdeaPad Flex 5 14ALC05 Notebook 5 Specification for Upgrade or Repair
