Lenovo flex 5-14alc05
  • freenlnl
    • May 2014
    • 28
    • The netherlands
    #141
    Originally posted by freenlnl
    Lenovo IdeaPad Flex 5 14ALC05 i think bricked through Lenovo Vantage. The screen black and Capslock LEDs are lighting up
    Could please rebuild?
    SN - PW0309GV
    • paddymoney
      • Aug 2024
      • 10
      • Deutschland
      #142
      Hi, i get a Lenovo ideapad Flex 5 14ALC05 and i do an bios Update. After that i got a black screen. keyboard is lighting and nothing else. remove battery dont solve the issue.
      now will buy an CH341A and flash the bios again. Can i use an bios file from here and flash the bios again with the tool from CH341A?
      The BIOS chip is left side from the cpu right?
      here the data from the laptop:
      IdeaPad Flex 5 14 ALC05
      Mfg Date: 2021/11/04
      S/N: PW002VZE
      BIOS IC 74W12JWSIQ 2140
      MTM: 82HU00GGEE
      MO: PWN0B1B0400Q
      LC56-14A SVT
      203021-1
      448.OMD08.0011
      • kalilinux25
        • Mar 2018
        • 2089
        • ZAMBOANGA SIBUGAY
        #143
        If you can post a clear picture It will be a big help to assist you
        • paddymoney
          • Aug 2024
          • 10
          • Deutschland
          #144
          Is this thie BIOS Chip? Than Put in the Chip the ch341a right? https://www.amazon.de/TECNOIOT-CH341.../dp/B07RKXSMKH
          • volinakis
            • Jan 2021
            • 2741
            • N/A
            #145
            pic is not that clear, what is written on chipset_? 74W(H, M)12JWSIG? If it is you also need a 1.8V adapter.
            • paddymoney
              • Aug 2024
              • 10
              • Deutschland
              #146
              S/N: PW002VZE
              MTM: 82HU00GGEE
              MO: PWN0B1B0400Q
              LC56-14A SVT
              203021-1
              448.OMD08.0011​
              • volinakis
                • Jan 2021
                • 2741
                • N/A
                #147
                yep, you also need 1.8V adapter. Use ASProgrammer or NeoProgrammer for CH341A and read chipset 3-4 times and compare results with HxD (Analyze tab). When you have 2 identical reads it means you have a good backup. I advise you to read Bios Guide of this forum if you are doing this for 1st time.
                https://www.badcaps.net/forum/troubl...t=phoenix+bios
                • paddymoney
                  • Aug 2024
                  • 10
                  • Deutschland
                  #148
                  You mean this right? https://www.amazon.de/EEPROM-Program...1&gad_source=1
                  • volinakis
                    • Jan 2021
                    • 2741
                    • N/A
                    #149
                    yes, this one has 1.8V adapter included in kit.
                    • paddymoney
                      • Aug 2024
                      • 10
                      • Deutschland
                      #150
                      Fine, do you have a manual, how i should handle the kit? IT IS my First time to try to flash a BIOS Chip...
                      • volinakis
                        • Jan 2021
                        • 2741
                        • N/A
                        #151
                        search on youtube how to use CH341A
                        • paddymoney
                          • Aug 2024
                          • 10
                          • Deutschland
                          #152
                          I will do it. Which bios file i can use to flash the BIOS?
                          • volinakis
                            • Jan 2021
                            • 2741
                            • N/A
                            #153
                            1st you have to read your bios chipset even it is faulty and post the backup here.
                            • paddymoney
                              • Aug 2024
                              • 10
                              • Deutschland
                              #154
                              Ok, when i write after that an bios file from here, i get an error with the serial number and windows license right?
                              is this old procedure maybe possible? https://forums.lenovo.com/t5/Lenovo-...3208?page=1​
                              • paddymoney
                                • Aug 2024
                                • 10
                                • Deutschland
                                #155
                                The name from thei BIOS chip is "74W12JWSIQ" shoud i use the 25 bios chip area on the ch314a tool? i cannot find the information in google...
                                Click image for larger version  Name:	image.png Views:	0 Size:	1.27 MB ID:	3326310
                                  • 21029
                                  Yes.
                                  • paddymoney
                                    • Aug 2024
                                    • 10
                                    • Deutschland
                                    #157
                                    Originally posted by SMDFlea
                                    Yes.
                                    And choose in NeuProgrammer this chip: "W25Q128FW"
                                    Because i cannot find "74W12JWSIQ" in the list.
                                    • paddymoney
                                      • Aug 2024
                                      • 10
                                      • Deutschland
                                      #158
                                      BIOS is flashed, now my PC is working to copy the SN and so on and Windows Key informations to an working bios file was easy. Thanks to all for help
                                        SMDFlea commented
                                        Editing a comment
                                        You`re welcome :-)
                                    • Everest Topi
                                      Orestis
                                      • Sep 2024
                                      Lenovo flex5 14alc05
                                      s/n PW004F3G
                                      MTM 82HU00GEGE
                                      455.0MD02.0003
                                      Please help transfer serial number and activation code​
                                        • 21029
                                        s/n PW004F3G
                                        MTM 82HU00GEGE
                                        455.0MD02.0003
                                        Try this https://www.badcaps.net/forum/troubl...95#post1769295
                                          Lenovo IdeaPad Flex 5 Hybrid (2-in-1) Flex Specification for Upgrade or Repair
                                          This specification for the Lenovo IdeaPad Flex 5 Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Flex 5 boardview and Flex 5 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Lenovo...
                                          09-07-2024, 07:20 AM
                                          09-07-2024, 06:38 AM
