Lenovo flex 5-14alc05
    • 21672
    Re: Lenovo flex5 14alc05
    Originally posted by nacho9062
    edit:
    here.
    • nacho9062
      • Mar 2023
      • Argentina
      #42
      I'm freaking out! perfectly! thank you so much!!
      • zurvanielle
        • Feb 2017
        • 137
        • Philippines
        #43
        I hope it works fine.
        works perfectly....^_~
        thank u for sharing.....^_~
        • alfredodinolfo
          • 128
          • N/A
          #44
          Hello, I fixed 5V section issue on flex 5 14ALC05 but I found SPI empty (one shop before me ).
          s/n: R912G0J9
          m/b: LC56-14A SVT 203021-1
          448.0MD07.0011
          MTM:82HU002JIX
          I need help with bios+dmi
          It is possible without original dump?
          thx
          • hardware1
            • Sep 2021
            • 2946
            • N/A
            #45
            s/n: R912G0J9
            448.0MD07.0011
            MTM:82HU002JIX
            thx
            Try the file from Post #17
            all donations are welcome,
            • cobragfox
              • Oct 2017
              • 7
              Lenovo IdealPad Flex 5 14LC05
              Having no image issue like a few of the post above. Exact same symptoms. Cap's lock light and power button light is on. Can someone help fix the bios file i've attached. Please help
              • alfredodinolfo
                • 128
                • N/A
                #47
                blink power button, light caps-look and Esc on no blink
                • hardware1
                  • Sep 2021
                  • 2946
                  • N/A
                  #48
                  Try the file in Post #17, if it works we can transfer your DMI after that.
                  • hardware1
                    • Sep 2021
                    • 2946
                    • N/A
                    #49
                    So it's the same symptoms as before or what? It's a Virgin BIOS from Lenovo and it should works fine.
                    • cobragfox
                      • Oct 2017
                      • 7
                      What programmer would you suggest using as I think mine may not be compatible. It doesn't call out this particular chip but a W25Qxxx and not the W74Mxxx.
                      • peste
                        • 13421
                        • ROMANIA
                        #51
                        go on the internet and see which programmer is compatible with that chip and choose one according to your budget and how often you will use it...try to choose a compatible chip from the programmer's database..
                        • cobragfox
                          • Oct 2017
                          • 7
                          It worked. Display is now on. How do I perform the next step of transferring the DMI?
                            VIP Moderator
                            • Aug 2018
                            • 4386
                            • Bulgaria 🇧🇬
                            #53
                            By reading the thread from the beginning, because it's already been explained.
                            With attached CopyDMI script...
                            Become a Badcaps supporter
                            Thanks to all supporters.​
                            • cobragfox
                              • Oct 2017
                              • 7
                              Thanks guys. This fixed it.
                              • cthtuf13
                                • Jul 2023
                                • Ukraine
                                #55
                                Re: IdeePad 5 15ALC05 bios please!
                                LENOVO Flex 5 14ALC05
                                82HU00C1RA
                                auto power on, blinking power button and light on Caps Lock and Esc
                                • peste
                                  • 13421
                                  • ROMANIA
                                  #56
                                  82HU00C1RA
                                  try post #11
                                  https://www.badcaps.net/forum/showth...hlight=15ALC05
                                  • cdwayne foremost
                                    • Mar 2015
                                    • 22
                                    • jamaica
                                    #57
                                    Hello there,
                                    So this laptop doesn't display images, everything else seems to be working fine, it seems to be bios related.
                                    this is the backup file , the actual bios on system.
                                    please fix for me and deep thanks......
                                    bios dump
                                    • hardware1
                                      • Sep 2021
                                      • 2946
                                      • N/A
                                      #58
                                      Originally posted by cdwayne foremost
                                      Hello there,
                                      bios dump
                                      If your device Model Number is "IdeaPad Flex 5-14ALC05 Type (82HU)", the file from post #17 should works fine.
                                      • cdwayne foremost
                                        • Mar 2015
                                        • 22
                                        • jamaica
                                        #59
                                        yes thats correct its flex5 14alc05
                                          VIP Moderator
                                          • Aug 2018
                                          • 4386
                                          • Bulgaria 🇧🇬
                                          #60
                                            Lenovo IdeaPad Flex 5 Hybrid (2-in-1) Flex Specification for Upgrade or Repair
                                            This specification for the Lenovo IdeaPad Flex 5 Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Flex 5 boardview and Flex 5 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Lenovo...
                                            09-07-2024, 07:20 AM
                                            09-07-2024, 06:38 AM
