bios Nitro 5 FH51/FH51M LA-J871P
Nitro AN515-55
Attached Filesif you find these attachements useful please consider making a small donation to the site
https://www.badcaps.net/donateComment
Hi everyone, I need your help, I replaced a mosfset due to no net shorted power, I checked that I have all the voltages and they are correct, the keyboard starts electrically and turns on, I hear the fans starting but nothing on the screen.
ACER NITRO 5 AN515-55-73PG
SN: NHQ7MET00B026057803400SNID: 02602240034MAIN: FH51 LA-J871P REV:1A 2020-03-30Thanks so much in advanceAttached Filesif you find these attachements useful please consider making a small donation to the site
I need help
Problem: laptop has power with led lights on keyboard but no display..Thank you in advance
Motherboard: FH51M LA-J871P REV 1B
Acer Model: AN515-55 57DA
S/N: NHQ7NSP004033179AB3400
SNID: 03309668334
Nitro AN515-55
HELLO, PLEASE HELP ME WITH THIS BIOS, IT DOES NOT ENABLE VCC CORE AND VCC GT
FH51M LA J871P REV 1B 2020 06 04
AN515 55 576K
SN NHQ7MAL00J051087433400
SNID: 05103462734Attached Filesif you find these attachements useful please consider making a small donation to the site
hi tryAttached Filesif you find these attachements useful please consider making a small donation to the site
Can someone upload BIOS file for my Acer Nitro laptop..black screen, just keyboard light. Bought new BIOS IC and have programmer tool. Done that before but i cant find bios file
AN517-52-76YU
SN: NHQ8KEZ008022054043400
SNID:02202150834
MODEL:N20C2Comment
Post your bios backup.Comment
Hello friends, I have a question, whenever I change a PCH on an Acer notebook, the machine does not turn on if the PCH is used and removed from a different brand notebook, it only works with a new PCH or one removed from another Acer, any chance of a change in the bios making it work? I have this board here (la-j871p), I got the PCH from a Lenovo, but it doesn't work, as expected, I tried different bios, I have the original bios.Comment
It is because of bootguard. You can only use a PCH from an acer donor board with the same bootguard settings or use a PCH with no bootguard, then if the bios has bootguard the bios can be modified to disable bootguard. You can`t put a PCH with bootguard from a different brand and modify the bios, you would have to add the OEM key etc, not possible.Hello friends, I have a question, whenever I change a PCH on an Acer notebook, the machine does not turn on if the PCH is used and removed from a different brand notebook, it only works with a new PCH or one removed from another Acer, any chance of a change in the bios making it work? I have this board here (la-j871p), I got the PCH from a Lenovo, but it doesn't work, as expected, I tried different bios, I have the original bios.Comment
Thanks now i undestand 😅
It is because of bootguard. You can only use a PCH from an acer donor board with the same bootguard settings or use a PCH with no bootguard, then if the bios has bootguard the bios can be modified to disable bootguard. You can`t put a PCH with bootguard from a different brand and modify the bios, you would have to add the OEM key etc, not possible.Comment
Hello friends, how are you?
I need help cleaning the ME region of my Dump file.
This equipment is going through a PCH replacement, and I'm installing a new PCH today.
LA-L181P Motherboard Rev: 1B
ACER MODEL: AN515-57-79TD
S/N: NHQESAA005225086703400
SNID: 225034416Comment
The attachment did not upload, here is the bios backup
Try and Update.Attached Filesif you find these attachements useful please consider making a small donation to the site
by macabookHello everyone,
🧩 Initial Issue- Board powers on (fans spin, keyboard lights up and can be adjusted, caps lock led lights), but no display or backlight
- External display (HDMI) shows
Channel: BIOS Requests ONLY!
07-24-2025, 02:17 PM -
by martin83Hello everyone.
I'm here to ask for help troubleshooting an issue with my Acer Nitro 5 An55-515. Board number fh51m LAJ871P .
The laptop turns on without any image, and after inspection, I noticed the 1.2V voltage was reading 8V spikes. The PQM1 MOSFET's gate was shorted to the source.
I replaced PQM1, PQM2, and PUM1. After turning on the machine, the 1.2V voltage appears correctly for about 1 minute, but after that, PQM1 shorted again. The MOSFET and controller assembly has already been replaced twice and continues to blow. I can't understand what's going on. I should also add... -
by piratiHello everyone,
I decided to try flashing a new BIOS, but since I didn’t want to desolder...-
by Vesko356First of all thanks to all of our members who have posted previously all methods posted here.
Operating system and OS version.If...-
by jbonavitaHi, my laptop wont boot at all
Some issues
Things I tried
1- Update / clear ME: Took the non working bios, made a backup, and did this: https://www.badcaps.net/forum/troubl...theory/trouble...-
- Loading...
