bios Nitro 5 FH51/FH51M LA-J871P
  • soulsby29
    replied
    Motherboard FH51M LA-J871P Rev: 1B
    Acer Model: AN515-55-53ES
    SN: NHQ7MEK0092170A0E53400
    SNID: 21704118934
    This laptop is charging and the blue light responds to the power button but is dead and not booting. It possibly could be CPU related but thought could also be an issue with the BIOS. Thanks in advance for any help
  • RCCBUBC
    replied
    Need a bios file for Nitro 5 AN515-55-73GS FH51M LA-J871P Rev:1 B
    S/N: NHQ7JAA0040520962C3400
    SNID: 05203844434
    Powers on black screen- Keyboard lights up
  • computeros
    replied
    I have a damaged IGPU. Does anyone have a BIOS with UMA graphics disabled? I can enter the BIOS, but unfortunately, I can't change it to discrete only. Is it possible to enable the advanced menu in the BIOS on the LA-J871p?
  • vickey_vip
    replied
    Originally posted by LBTT1121
    try and feedback
    Found Processor is faulty so can't confirm this file thank you for your prompt responce.
  • LBTT1121
    replied
    Originally posted by vickey_vip
    Can anyone help this bios no display
    Motherboard FH51M LA-J871P Rev: 1A
    ACER MODEL: AN515-55-50B1
    S/N: NHQ7RSI0040300C9AE3400
    SNID: 03005163034
    try and feedback
  • vickey_vip
    replied
    SNID: 03005163034
  • hoaca388
    replied
    Originally posted by magneh
    Hello everyone!
    I needed help to clean the ME region of this original Bios Dump.
    ACER MODEL: AN515-55-73G9
    S/N: NHQ7MEF004034141583400
    SNID: 03408226434
  • magneh
    replied
    Hello everyone!
    I just replaced PCH, original one was shorted and had the die cracked.
    Ive quickly tested and it charges battery, turns on and off, but does not POST.
    Hope all is good with PCH and just needs a clean me
    Heres the info of the device and board:
    SNID: 03408226434
    Attached File bkp original dump
    Thanks in advance!
  • Zanis1121
    replied
    Originally posted by bbanana
    try..........
    Thank you
  • bbanana
    replied
    Originally posted by Zanis1121
    Dump Bios
    try..........
  • Zanis1121
    replied
    Originally posted by Bios Cracker
    Also, Upload your original dump file.
    Dump Bios
  • Bios Cracker
    replied
    AN515-55-51UV
    SN : NHQ7MEU00G1410A9033400
    SNID : 114104326734
  • Zanis1121
    replied
    Hello. Need an engineering BIOS for Acer Nitro 5 FH51M LA-J871P REV 1B. To bypass Subsystem ID check. Help please
    AN515-55-51UV
    SNID : 114104326734
  • peste
    replied
    post S/N, full name and model, motherboard model,etc.
    post the contents of the bios chip even if it is corrupted..
  • Zanis1121
    replied
  • Bios Cracker
    replied
    Originally posted by Destroyer-Br
    The attachment did not upload, here is the bios backup​
    Try and Update.
  • Destroyer-Br
    replied
    Hello friends, how are you?
    I need help cleaning the ME region of my Dump file.
    This equipment is going through a PCH replacement, and I'm installing a new PCH today.
    LA-L181P Motherboard Rev: 1B
    ACER MODEL: AN515-57-79TD
    S/N: NHQESAA005225086703400
    SNID: 225034416
  • Destroyer-Br
    replied
    SNID: 225034416​
  • dycc
    replied
    Originally posted by dthard
    Hallo Masters! Anoone can repair my old BIOS?
    SNID: 03502174934
    MODEL: AN515-55-53AG
    BOARD: FH51M LA-J871P
    This FILE is working perfectly . I used it to solve my GPU detection issue
  • mnetobr
    replied
    Originally posted by SMDFlea
    It is because of bootguard. You can only use a PCH from an acer donor board with the same bootguard settings or use a PCH with no bootguard, then if the bios has bootguard the bios can be modified to disable bootguard. You can`t put a PCH with bootguard from a different brand and modify the bios, you would have to add the OEM key etc, not possible.
    Thanks now i undestand 😅
  • macabook
    by macabook
    🧩 Initial Issue
    07-24-2025, 02:17 PM
  • martin83
    Acer nitro 5 AN55-515 fh51m LAJ871P no picture
    by martin83
    Hello everyone.
    I'm here to ask for help troubleshooting an issue with my Acer Nitro 5 An55-515. Board number fh51m LAJ871P .
    The laptop turns on without any image, and after inspection, I noticed the 1.2V voltage was reading 8V spikes. The PQM1 MOSFET's gate was shorted to the source.
    I replaced PQM1, PQM2, and PUM1. After turning on the machine, the 1.2V voltage appears correctly for about 1 minute, but after that, PQM1 shorted again. The MOSFET and controller assembly has already been replaced twice and continues to blow. I can't understand what's going on. I should also add...
    07-14-2025, 06:31 AM
  • pirati
    by pirati
    10-27-2025, 04:20 PM
  • Vesko356
    by Vesko356
    08-11-2023, 03:27 AM
  • jbonavita
    by jbonavita
    Some issues
    Things I tried
    04-29-2025, 09:38 PM
