Lenovo V15-IIL 82C5 Bios please
  • Giggle2562
    • Oct 2025
    • 3
    Thank you very much for the BIOS file.
    I have flashed the new BIOS you provided. I also ordered a new 90W power supply, which has arrived, so I am sure it's not a power adapter issue.
    Unfortunately, the problem still occurs, but I have noticed some more specific symptoms:
    • When I install the RAM: The laptop powers on (LEDs blink, fan spins), but the screen does not turn on at all. It shuts down after a few moments.
    • If I try to start it without the RAM installed: The screen does turn on for a moment (LEDs blink, fan spins), shows a "No bootable device" message, and then it shuts down.
    What I've also noticed is that after it shuts down (in either scenario), it won't turn on again. I have to disconnect both the AC adapter and the internal battery before it will attempt to power on again.
    Is this still likely a BIOS issue, or should I start looking for a hardware fault elsewhere?
    Any advice would be greatly appreciated. Thank
    • m1ch43lzm
      • Mar 2019
      • 935
      • Peru
      #82
      Maybe you received a faulty motherboard, or another part from the laptop is faulty
      Test only motherboard and screen, nothing else connected (no keyboard, no touchpad, no I/O board, no WiFi, no SSD, no RTC battery)
      With RTC battery removed it should turn on upon connecting AC adapter, otherwise find the alternate power button pads at J4501 or J4502 (or pins 1-2 at the keyboard connector) and momentarily short with tweezers to turn on the laptop
      • Giggle2562
        • Oct 2025
        • 3
        Thank you for that advice.
        I followed your suggestion and tested the motherboard with minimal components. This led me to a very important discovery:
        The laptop starts up and works without any problem as long as the internal display (LCD screen) is disconnected. It boots correctly, and I can also use it perfectly fine on an external monitor via the HDMI port.
        The original problem immediately returns as soon as I plug the internal display back in. The laptop will power on, the screen lights up for a moment and looks normal, but after a second, it all shuts down. (And again, I have to disconnect the battery and AC adapter to get it to power on again).
        The screen itself looks physically fine. I'm wondering if this is a compatibility issue? The display panel is from a V15-IKB model. Is it possible that a BIOS modification is needed to correctly support this specific screen?
        What other steps can I take to fix this? Could this be a bad display cable, the screen itself (drawing too much power), or a fault on the motherboard's display power circuit?
        • m1ch43lzm
          • Mar 2019
          • 935
          • Peru
          #84
          Screen is the same, Lenovo parts website lists 3 screens for the V15-IKB
          5D10R41288
          5D10R41285
          5D10R41287
          https://pcsupport.lenovo.com/us/en/p...lay/compatible
          And for V15-IIL
          https://pcsupport.lenovo.com/us/en/p...splay/as-built
          The same part numbers
          Maybe the display cable is faulty, or the webcam? Looks like something is making a short circuit to me, that's why laptop powers off and doesn't turn on again
          You may open a new thread in the troubleshooting laptops section, as the BIOS isn't an issue
          https://www.badcaps.net/forum/troubl...mobile-devices
          • abhorsen
            Help Disabling Flash Protection Range Registers on Lenovo P360 Tiny BIOS
            by abhorsen
            Hey guys,
            Hope you all are doing well. I come here from Win-Raid because I am having issues disabling Flash Protection Range Registers so I can flash my BIOS from within Windows using Intel's IFW tool/using flashrom within Linux, however I cannot due to the above mentioned error.
            Here is my thread on Win-Raid detailing the whole process I went through: https://winraid.level1techs.com/t/re...h-gen/95478/27
            Essentially I managed to boot into Windows while shorting PINs 1+5 of my audio chip to disable the HAP bit...
            07-06-2023, 10:22 AM
          • Vesko356
            by Vesko356
            08-11-2023, 03:27 AM
          • HotSaladMan
            Lenovo ThinkBook 14S Yoga ITL Bad Flash + Need Bios
            by HotSaladMan
            *##*#*#*#*#*#Cringe Warning Used Clips for Tl866ii Plus Backups#*#*#*#*#*#
            Model : Lenovo ThinkBook 14S Yoga ITL
            S/N : MP28JT19
            MFG Date : 2022/02/09
            Factory ID PRC4
            MO : MPNXB26080FX
            MTM : 20WE001US
            MODULE FCC ID : PD9AX201NG
            IC : 1000M-AX201NG
            BOARD INFO
            FLV34 LA-KO51P
            REV : 1B 2020-08-24
            Bit of Info
            Using Tl866ii Plus, it would scan the chip but wouldn't not detect the
            chip id, so i would always uncheck the id check, so it would bypass the error
            i did in fact make...
            11-07-2024, 07:46 AM
          • Nicola Bianchi
            Lenovo x1 nano gen 1 -- bricked -- where to flash the bios/fw
            by Nicola Bianchi
            Hello!
            A few days ago I bricked my Lenovo x1 nano gen 1 while updating the bios/fw from linux.
            No the machine power up, but it stuck in a recovery state and I can not do much.
            Lenovo X1 Nano Gen 1
            Type: 20UN - X021US
            S/N: R9 - 10W2D9
            I would like to flash a new BIOS/FW on the chip using a CH341a programmer but ... I actually don't know which "chip" on the motherboard to target 🤦‍♂️
            So here I am to ask for help.
            I opened the laptop and I found a chip that may be the target, on it I've:
            Winbond 25R256...
            01-11-2025, 09:50 AM
          • to5it0
            Need Clean BIOS/EC Bin File for Lenovo ThinkPad Yoga 11e 2H1703-27220F Rev. A Marked as U2501 on the motherboard.
            by to5it0
            Need Clean BIOS/EC Bin File for Lenovo ThinkPad Yoga 11e - Stuck with 0275 Error CMS
            I am attempting a repair on a Lenovo ThinkPad Yoga 11e that is currently stuck at boot with the error: "0275 error CMS" even after setup new bios battery and will not allow me to enter the BIOS/Setup.
            This is a critical issue that I believe requires flashing the BIOS chip directly using a programmer (e.g., CH341A/RT809H), as standard software updates or resets are not possible.
            I have opened the laptop and identified the main BIOS chip...
            10-24-2025, 01:35 AM
