Lenovo V15-IIL 82C5 Bios please
 bios extracted from Lenovo website update for S145-14IIL, S145-15IIL, V14-IIL, V15-IIL
 DMI 622000 - 623FFFAttached FilesDue to a lack of donations, server free space at a critical level, and possible closure of Bios Requests all donations are welcome, click:
 Every donation made will go towards server fees and maintenance costs.Comment
 Hi guys,
 Please help with the bios password, no way i can remember the passsword.No one could help, i came across this forum where people have been helped.
 my laptop:
 Lenovo S145-15IIL
 model 81W8
 s/n PF1SHLFR,
 LNVNB161216
 Attached FilesComment
 >>>>> click on this link to donate via PayPal. <<<<<
 ----------------------------------------------------------------------------------------------------------------------------------------------------------------------Comment
 Attached is the Lenovo V15-IIL 82C5 BIOS. Can you send it back to me corrected? Thanks.
 Help needed – Lenovo device with no video output.
 I loaded the BIOS from POS 33, version DKCN55WW, and it works without showing the serial number or other BIOS details, with only 4GB of RAM detected.
 However, when I install the external 4GB RAM module for expansion, the screen goes black.
 Thanks in advance.
 Lenovo V15-IIL
 Model: 82C5
 Serial Number: PF28Z90M
 MTM: 82C50057SP
 MO: PF9XB0508167
 Factory ID: JUHFC1
 Motherboard: GS44D/G554D NM-C 711 REV: 1.0
 Try with BIOS ver DKCN53WW, DMI added
 V15-IIL Laptop (Lenovo) - Type 82C5
 BIOS ver DKCN53WW
 S/N PF28Z90M
 MTM 82C50057SP
 DMI 622000-623FFF
 Remove additional RAM stick, let the laptop boot, power off, remove battery, install RAM, connect battery, it may take 2-3 minutes to boot after installing RAM at first
 Also check if the RAM is faultyAttached FilesComment
 It's Working Fine ... Thank You Man You saved meTry with BIOS ver DKCN53WW, DMI added
 BIOS ver DKCN53WW
 S/N PF28Z90M
 MTM 82C50057SP
 DMI 622000-623FFF
 Also check if the RAM is faultyComment
 I need some help with a motherboard swap.
 Original Laptop: Lenovo V15-IKB Original (dead) Board: GS44B/GS54B NM-C561 Rev:1.0 Original SN: PF25RNQM (Attached: BIOS dump from this old board - V15_IKB.bin)
 New (Donor) Board: GS44D/GS54D NM-C711 Rev:1.0 (This board is from a Lenovo V15-IIL with an i5-1035G1 CPU) (Attached: Current BIOS dump from this new board - V15_IIL.bin)
 The Problem: I installed the new NM-C711 board into the V15-IKB chassis. When I connect the original 65W Lenovo PSU, the power LEDs start blinking, the laptop resets, shows image for a moment, and then shuts down. It seems to be in a reset loop.
 I have tried all possible combinations of connecting tapes and connectors, but the problem remains. I do not have the original Serial Number (SN) or MTM that was assigned to the new GS44D/GS54D NM-C711 Rev:1.0 board.
 Could this be a BIOS issue? Perhaps the V15_IIL.bin needs a Clean ME, or maybe DMI information needs to be transferred from the old V15_IKB dump?
 Any advice would be greatly appreciated. Thank you.
 Checking Lenovo parts website lists with S/N PF25RNQM shows that the original AC adapter for V15-IKB is 45W 20V 2.25A, for the replacement V15-IIL (MT 82C5) motherboard it requires 65W AC adapter, 20V 3.25A; rest of the parts are compatible or listed as substitutes thereHello everyone,
 Looks like a power issue to me, test without SSD, additional RAM stick and WiFi first; also try with a charged battery, AC adapter unplugged
 The V15-IIL motherboard has the DMI from the laptop it was pulled from, leave it as is, as the Lenovo preinstalled software will try to offer wrong drivers/BIOS otherwise
 Try BIOS extracted from Lenovo website, DMI inserted from the new replacement board
 S/N from replacement motherboard PF1WM1EH
 MTM (replacement board) 82C500B3MX
 BIOS ver. DKCN47WWAttached FilesLast edited by m1ch43lzm; 10-28-2025, 06:18 PM.Comment
			by abhorsenHey guys,
 Hope you all are doing well. I come here from Win-Raid because I am having issues disabling Flash Protection Range Registers so I can flash my BIOS from within Windows using Intel's IFW tool/using flashrom within Linux, however I cannot due to the above mentioned error.
 Here is my thread on Win-Raid detailing the whole process I went through: https://winraid.level1techs.com/t/re...h-gen/95478/27
 Essentially I managed to boot into Windows while shorting PINs 1+5 of my audio chip to disable the HAP bit...-
			by Vesko356First of all thanks to all of our members who have posted previously all methods posted here.
 Operating system and OS version.If...-
							Channel: BIOS Requests ONLY!
			by HotSaladMan*##*#*#*#*#*#Cringe Warning Used Clips for Tl866ii Plus Backups#*#*#*#*#*#
 Model : Lenovo ThinkBook 14S Yoga ITL
 S/N : MP28JT19
 MFG Date : 2022/02/09
 Factory ID PRC4
 MO : MPNXB26080FX
 MTM : 20WE001US
 MODULE FCC ID : PD9AX201NG
 IC : 1000M-AX201NG
 BOARD INFO
 FLV34 LA-KO51P
 REV : 1B 2020-08-24
 Bit of Info
 Using Tl866ii Plus, it would scan the chip but wouldn't not detect the
 chip id, so i would always uncheck the id check, so it would bypass the error
 i did in fact make...-
			Hello!
 A few days ago I bricked my Lenovo x1 nano gen 1 while updating the bios/fw from linux.
 No the machine power up, but it stuck in a recovery state and I can not do much.
 Lenovo X1 Nano Gen 1
 Type: 20UN - X021US
 S/N: R9 - 10W2D9
 I would like to flash a new BIOS/FW on the chip using a CH341a programmer but ... I actually don't know which "chip" on the motherboard to target 🤦♂️
 So here I am to ask for help.
 I opened the laptop and I found a chip that may be the target, on it I've:
 Winbond 25R256...2 Photos-
			by to5it0Need Clean BIOS/EC Bin File for Lenovo ThinkPad Yoga 11e - Stuck with 0275 Error CMS
 I am attempting a repair on a Lenovo ThinkPad Yoga 11e that is currently stuck at boot with the error: "0275 error CMS" even after setup new bios battery and will not allow me to enter the BIOS/Setup.
 This is a critical issue that I believe requires flashing the BIOS chip directly using a programmer (e.g., CH341A/RT809H), as standard software updates or resets are not possible.
 I have opened the laptop and identified the main BIOS chip...2 Photos-
- Loading...
