Lenovo ThinkPad e495 BIOS update interrupted
  • anaximperator
    • Jun 2022
    • 10
    • Argentina
    Hi! I have a ThinkPad e495 that doesn't turn on anymore after being shutdown accidentally during a bios update.
    When I try to turn it on, the power button flashes rapidly about 5 times, the caps lock key stays on, and cannot shut it down by pressing and holding the power button. I've tried disconnecting the battery, and it turns off, but then again when I turn it back on it does the same thing.
    I suppose I need to flash the original bios, and even got a ch341a eeprom programmer + 1.8v adapter. I have a couple of problems with this, first the bios file on lenovo's website has a fl1 extension and I'm not sure if I'll be able to flash it on the winbond 25q128fwsq chip.
    Just to make sure the ch341a is working OK, I read the chip on an Intel laptop without issues.
    Can anybody help me?
    Does anybody have the original bios for this model?
    Any clues on what the power button flashing means?
    Sorry for the wall of text, and any mistakes I may have made, English is not my first language.
    Thanks in advance!
    • 23372
    Re: Lenovo ThinkPad e495 BIOS update interrupted
    The CH341A has some better software you can use,and if you have the black PCB model theres a voltage mod that will make it a bit more stable
    https://www.badcaps.net/forum/showpo...40&postcount=2
    https://www.badcaps.net/forum/showpo...3&postcount=21
    Make 2 or 3 backups then open them with a hex editor or file compare software to make sure all backups are the same, and there is some code in them,not reading al FF`s .Post your backup here as an attachment in a zip or rar file and somebody will help you
    • anaximperator
      • Jun 2022
      • 10
      • Argentina
      Hey, thanks for replying!
      Yesterday using asprogrammer I got to make a backup of the original bios, but I'm afraid it's garbage.
      After reading a lot of forums, and searching for a suitable bios bin like crazy, I found a post on this forum about someone with the same laptop. I downloaded that bios and applied it to the laptop, because I figured that it wouldn't be worse than its current status. It turns out I made some progress, because at least now it shows the Lenovo logo, but immediatelly after that, it beeps a few times and displays "0183: Bad CRC of Security Settings in EFI variable. Press F1 to enter Setup.", and after pressing F1, it just goes to a black screen and setup never loads. So I guess it's progress, though probably not in the right direction.
      I'm attaching the original bios backup, as well as the one I applied later that's failing.
      Thanks for your time
      • hoaca388
        Badcaps
        • Jan 2022
        • 12685
        E495 (Type 20NE) Laptop (ThinkPad)
        If you have found our forum useful please consider supporting us. Subscribe for a small monthly fee and receive extra benefits including our bios, boardview & schematic archive.
        Subscribe to support us. It only takes 1 minute:
        https://www.badcaps.net/settings/subscriptions
        • anaximperator
          • Jun 2022
          • 10
          • Argentina
          Awesome! It worked! Thank you so much!
          I noticed this laptop, although it has 6gb of ram and a nvme ssd, runs super slowly, even worse than a laptop with a celeron processor. Could it be due to the new bios, or should I try to troubleshoot this as something not related to that?
          • cusspide
            • Aug 2014
            • 5
            • Argentina
            Works for me!!! Thanks a lot!!!
            • Salmus666
              • Jan 2023
              • 16
              • Eesti
              It helpet.
              • vamp
                • Nov 2023
                • korea
                wow! thanks a lot
                • bripoll
                  • Jul 2023
                  • 8
                  • España
                  !!!!!! Worked perfect
                  • rubenvidalflores
                    • Jan 2023
                    • 5
                    • Perú
                    Thx. Bios Working
                    • Ronin_Z
                      • Sep 2024
                      • Latvia
                      Hello everyone!
                      I have Lenovo E495 (Type 20NE) PF1BRM2N and during the BIOS update laptop was turned off and update was interrupted.
                      Now there is only black screen and caps lock lights up.
                      Tried flashing the bios bin file found here with the ch341a programmer but it didn't work.
                      Can someone please help me modify this bin file?
                        SMDFlea commented
                        Editing a comment
                        thread merged
                    • hoaca388
                      Badcaps
                      • Jan 2022
                      • 12685
                      Originally posted by Ronin_Z
                      Hello everyone!
                      E495 (Type 20NE) Laptop (ThinkPad) - Type 20NE
                      • NM17
                        • Aug 2025
                        • 5
                        • Deutschland
                        Unfortunately, I have the same problem as described above. My Thinkpad E495 no longer starts up. When I try to start the device, only the power button and the caps lock key light up.
                        I created a backup of the BIOS using ch341a. I have already tested the BIOS versions posted above, but without success. Can anyone help me?
                        • peste
                          • 14899
                          • ROMANIA
                          post S/N, full name and model, motherboard model, TYPE,etc.
                          If you have found our forum useful please consider supporting us. Subscribe for a small monthly fee and receive extra benefits including our boardview / schematic archive.
                          • volinakis
                            • Jan 2021
                            • 3225
                            • N/A
                            post serial no. and machine type
                            please support this forum
                            • NM17
                              • Aug 2025
                              • 5
                              • Deutschland
                              Serial number: pf1swltd
                              Model: 001GGE
                              BIOS chip: Winbond 25Q128FW SQ1948
                              • Rubuanos1
                                • Dec 2025
                                • wales
                                when i flashed the bios and booted the laptop it promted me for a password need help
                                • RMDUiFT
                                  Should I buy a Lenovo Thinkpad E495 with bios password?
                                  by RMDUiFT
                                  Good day. I apologize if I posted this in the wrong topic. I saw somebody selling a Thinkpad E495 with a Ryzen 3500U CPU near me. In the pictures the laptop is running windows 10. I contacted the seller and asked a few questions about upgradability and if it has a bios password on it. He confirmed it has a bios password. I searched through the forum, I found a guide regarding removing the bios password using the autopatcher, I also found a thread with the e495 where people requested help with unlocking the bios password.
                                  I have a few questions:
                                  • If I would buy this laptop and have
                                  08-25-2024, 09:00 AM
                                • akwky
                                  by akwky
                                  Hi!
                                  04-14-2025, 01:56 PM
                                • to5it0
                                  by to5it0
                                  10-24-2025, 01:35 AM
                                • Boardview and Schematic Bot
                                  Lenovo ThinkPad ThinkPad E495 Notebook E Specification for Upgrade or Repair
                                  This specification for the Lenovo ThinkPad ThinkPad E495 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the ThinkPad E495 boardview and ThinkPad E495 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                                  09-06-2024, 08:44 AM
