ASUS X515EA - X415EA Rev 6.0 Bios Bin
Become a Badcaps supporter
Thanks to all supporters.
----------------------------------------------------------------------------------------------------------------------------------------------------------Doctrina est fructus dulcis, radicis amarae.. -
Re: ASUS X515EA - X415EA Rev 6.0 Bios Bin
I read the post, but I can't get into the operating system from my laptop. I turn it on and it immediately asks for a password. I can't start windows and I can't get into bios. How do I get to the bios on this laptop?Comment
I managed to make a backup of the current BIOS with a password through the programmer. I uploaded it here, please help me clear my password. I don't understand this at all and I'm afraid to make things worse.
my notebook model: ASUS X515EPAttached FilesComment
Read the chip again and compare the content, use verification.
.Last edited by Vesko356; 07-23-2023, 05:24 AM.----------------------------------------------------------------------------------------------------------------------------------------------------------
----------------------------------------------------------------------------------------------------------------------------------------------------------Doctrina est fructus dulcis, radicis amarae..Comment
I followed the instructions as stated in post #13. I ran the script and got the modified Newbios file. Now you can sew with a newbios file?Attached FilesLast edited by Babywka; 07-23-2023, 06:17 AM.Comment
Read my previous post - first you need a good verified dump of the original bios.
Read the chip few times and compare the content! Upload the files here for comparison if you can't do that.
Don't worry removing the password is not a problem , just dump the bios properly!
I started using the NeoProgrammer program, it works better than the standard Chinese 341a. Read the chip 4 times. This file is valid according to what the program wrote.
1. I have identified the chip.
2. Then read the information from the BIOS chip.
3. After that I chose "compare contents"
4. At the end it was written that everything is OK.Attached FilesComment
Yes, it's much better attempt than your first one.I started using the NeoProgrammer program, it works better than the standard Chinese 341a. Read the chip 4 times. This file is valid according to what the program wrote.
Looking fine now.
Your unlocked file:Attached Files----------------------------------------------------------------------------------------------------------------------------------------------------------
Thank you very much. The password is no longer required. Everything is working. Friends told me that everything is already, you can throw away the laptop. But I did not believe it, and as a result, by common efforts, they repaired it. Now I have not much experience in this. I really don't understand how you did it. Here I have a bios backup with a password. And then what to do?Comment
x415EA R2.0 bios needed , i tried all bios here but keyboard not working and m.2 not dectectComment
Read the rules before posting:
Add:- Picture of the QR code printed on the motherboard
- Full laptop model name
- Serial number
- Original bios backup
- Initial issue description
Asus X515EA - bq2293w Anakart X415EA R7.0
sn: nbn0cv08p36546a
i3 11.gen uma
old bios dump
Hey, guys. Please help me bios plaeseAttached FilesComment
Every donation made will go towards server fees and maintenance costs.Comment
by exerion5000Asus X515EA_No Power_GD25B127D@SOIC8.rar
Hi Everyone! , i need repair the original bios corruptes of this model machine (Bios Needed For Asus X515EA Pcb X415EA R2.0) , the unit no power on , i test several bios for this model with some issues maybe related to especific version (keyboard partially work or no work , SSD no detected ,Etc ) so y let more data below if help , many thanks in advance!...-
Channel: BIOS Requests ONLY!
by razor_amdWith ASUS, not everything is quite so simple. I will show you my way. It may be longer or harder but it is the right way to do it in my humble opinion.
This is the picture of 3 similar ASUS motherboards, all of them being X555LD...-
by piratiHello everyone,
by grimacelordHello,
Anyway, I took dumps of both chips and then downloaded the latest update for this motherboard from ASUS's website...-
by jbonavitaHi, my laptop wont boot at all
Some issues
Things I tried
1- Update / clear ME: Took the non working bios, made a backup, and did this: https://www.badcaps.net/forum/troubl...theory/trouble...-
- Loading...
