Dell latitude 3510 (Mockingbird-L 19746-1) bios needed
  • CornholioGSM
    • Feb 2014
    • 264
    • CZECH
    i have here dead latitude 3510. After connect adapter turns on self, but no picture. Battery charges.
    I was unable to read correcty smaller ic (XM25QH64A) with ch341 with neoprogrammer or colibri
    Only QH128A was readed correctly.
    soo only 128 backup attached
    Btw...if will be qh64a bad...can i replace both with 25q64fv and 25q128bv ?
  • Vesko356
    VIP Moderator
    • Aug 2018
    • 4386
    • Bulgaria 🇧🇬
    Re: Dell latitude 3510 (Mockingbird-L 19746-1) bios needed
    Allowed flash chips are recorded in the VSCC table of the descriptor region.
    Descriptor region is in the smaller chip, so nobody can answer your question.
    Also nobody can repair your bios in half. The whole bios dump is divided in parts between the two bios chips, so both parts must be present for repair to happen. And the repaired dump must be recorded back at both bios chips.
    Become a Badcaps supporter
    Thanks to all supporters.
    • CornholioGSM
      • Feb 2014
      • 264
      • CZECH
      after increase voltage finally readed
      ....attached both 64+128
      • Vesko356
        VIP Moderator
        • Aug 2018
        • 4386
        • Bulgaria 🇧🇬
        Try & report back:
        • CornholioGSM
          • Feb 2014
          • 264
          • CZECH
          Originally posted by Vesko356
          Try & report back:
          hmmm bad still nothing on display
          EDIT:
          ooooh wau...after few on/off booted in manufacturing mode
          now is needed to fill service tag.
          Thank you
          • superhache
            • Nov 2018
            • 46
            • Argentina
            hello
            need to fix bios
            tested Veskko336 and no luck
            no display , caps on, charing led blinking white, blinking orange and repeat
            Latitude 3510
            Etiqueta de servicio: 64ZN563
            thanks!!
            • dhan
              • Jun 2018
              • 134
              • hp
              I have remove the password but not able to enter service tag. I enter service tag but not able to save it.
              error log shows unable to process
              • hoaca388
                Badcaps
                • Jan 2022
                • 11794
                Post more 16MB chip, what do you want us to do with an incomplete bios file ?
                Preferably 8MB file is also unedited files.
                • dhan
                  • Jun 2018
                  • 134
                  • hp
                  sorry about that.
                  please see attached 16Mb file
                  thank you
                  • hoaca388
                    Badcaps
                    • Jan 2022
                    • 11794
                    sorry about that.
                    thank you
                    Latitude 3510
                    • PARTH
                      • Dec 2022
                      • 6
                      • usa
                      can anyone help please 3510 after bios flash no display no charging its i7 10 gen
                      • CornholioGSM
                        • Feb 2014
                        • 264
                        • CZECH
                        Try & report back:
                        hello,
                        i have littlebit forgot about this laptop
                        Can you help me with manufacturing mode? I am unable to fill service tag and exit to normal state
                        • sstamenov91
                          • Mar 2016
                          • 47
                          • Bulgaria
                          Hello, what programmer do you use to read the chips, i have ch431a but i get error IC not responding
                          • Macias
                            • Nov 2019
                            • 83
                            • Ecuador
                            Try & report back:
                            Thank :alegrarse:
                            • djharold
                              • Aug 2015
                              • 241
                              • COLOMBIA
                              Try & report back:
                              thankyou work for me
                              • CornholioGSM
                                • Feb 2014
                                • 264
                                • CZECH
                                Try & report back:
                                i have still problem of two same laptops - still no service tag manufacturing mode.
                                ...tested 1st boot - bios setup, disabled absolute, stag filled , saved reboot.
                                ...2nd boot alt+f doesnt not work because because stag is again missing
                                What now?
                                Will be possible to write service tag manually in hexedit?
                                Thank You
                                • rayshine03121408
                                  • Feb 2018
                                  • 93
                                  • Phillipines
                                  Good Day Masters! Anyone can unlock my BIOS? TIA
                                  • rayshine03121408
                                    • Feb 2018
                                    • 93
                                    • Phillipines
                                    Latitude 3510
                                    this save my life
                                    • CornholioGSM
                                      • Feb 2014
                                      • 264
                                      • CZECH
                                      Originally posted by rayshine03121408
                                      this save my life
                                      ...and what about manufacturing mode?
                                        • 20977
                                        Get the bios update from dell support, extract it with PFS extract, you`ll find it on the forum if you search for it.The 16MB file is a full bios region, (1 -- 1 System BIOS with BiosGuard v1.xx.x.bin) ,flash that to the 16MB bios chip.
                                          DELL Latitude 3510 Notebook 3000 Specification for Upgrade or Repair
                                          This specification for the DELL Latitude 3510 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 3510 boardview and 3510 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for DELL Latitude 3510...
                                          09-06-2024, 08:40 PM
