Dell latitude 3510 (Mockingbird-L 19746-1) bios needed
    Originally posted by hoaca388 View Post
    Why are there 104 bytes ?
    send a empty folder there was no bios inside
    @guillelpboy Please help me clear computrace from this bios, i thought i had fixed the laptop by flashing the only files that allowed me to save service tag after set up but laptop is having some odd behavior where it semi brick itself, and i have to take the cover off disconnect the batery and the computer boots up in manufactrer mode again, this is the original bios dump dell ST:2DCVP93
    Here is your Unlocked + New file as per your serial number as per your bios version 1.25.0
      sorry for the late reply, and thanks for the help, flashed both files computer booter once to MF after that it randonly boots to a colour changing screen when it finish and takes a while to show the same screen again
        thanks for the help but folder was empty
          @ post #61
            would you or anyone else please look into it again? im having problems with this laptop
            original bios has computrace enabled,- tried flashing some other bios files that dont let me save ST just one of them allowed me to but the computer briks itself again after sometime,- flashed your files computer turns on after 3 reboots i see the Dell logo briefly then the computer restarts to a flashing changing color patterns and it just keeps rebooting and doing the same sorry for my bad english
              Send to you, try
                Originally posted by minhdigital View Post
                Send to you, try
                Thanks a lot,computer has been working properly since i flashed these files, thank you and thanks to everybody else who helped me previously much apreciated👍
                  hello need to fix bios
                  no display
                  Latitude 3510
                  Etiqueta de servicio ;8GYJ463
                  EX 18439716315
                  thanks!!
                    no display
                    Latitude 3510
                    EX 18439716315
                    thanks!!
                    good luck
                      thanks it works there is a problem with the sound .it does not work
                        Try
                          Please hrelp me to remove bios password.
                          Dell Latitude 3510
                          ST: 4YFK663
                          EX: 10789114683
                          Attached 8mb & 16mb bios parts
                            try this
                              Dell Latitude 3510
                              ST: 4YFK663
                              EX: 10789114683
                              unlocked
                              Become a Badcaps supporter
                              Thanks to all supporters.
                                unlocked
                                Thank you, password removed
                                  Hello , can you unlock bios 8fc8 lock on Dell latitude 3510 (Mockingbird-L cml uma 6l 19746-1)
                                  st: CJ6T003
                                  EX : 27281676099
                                  thanks!!
                                    st: CJ6T003
                                    EX : 27281676099
                                    thanks!!
                                    only flash this 8mb.
                                    1st boot, press F2, write service tag, disable Absolute, save (Apply changes), restart. 2nd boot press Alt+F to exit manufacturing mode.
                                      rex98 you are best, thanks again work good.
                                        Hello, can I ask you to unlock two more locked bios for me like yesterday, it's the same model bios 8fc8 lock on Dell latitude 3510 (Mockingbird-L cml uma 6l 19746-1)
                                        2 laptop st: HH6T003
                                        3 laptop st:2H6T003
                                        so my problem is this 8MB one, I don't know how to do it.
                                          SMDFlea commented
                                          Editing a comment
                                          Use a hex editor and compare locked and unlocked files
                                        #80
                                        3 laptop st:2H6T003
                                        same procedure
