Need Bios EC dump for FH52M LA-J891p
  • Lubazi
    • Apr 2024
    • 14
    Originally posted by peste
    Bios extracted from the Acer website update
    DMI B2D000 - B2F00F
    KHEYWIN 370000 - 37003F​
    Thank you
    • Lulinha
      • Oct 2021
      • 10
      • Brasil
      Re: Need EC dump for FH52M LA-J891p rev 1b
      bios extracted from Acer website update
      DMI B2D000 - B2EFFF
      KEYWIN 370000 - 37003F
      Thanks. Work my Predator ph315-53
      • Murtaza527
        • May 2018
        • 262
        • Malaysia
        HI FRIENDS
        PLS SOMEONE HELP ME TO UNLOCK THIS BIOS THANKS
        ACER NITRO 5 AN515-55-79CU
        FH52M LA-J891P REV 1.0
        S NO # NHQ7PSM001031094393400
        • peste
          • Dec 2016
          • 13924
          • ROMANIA
          Originally posted by Murtaza527
          HI FRIENDS
          try..
          • Murtaza527
            • May 2018
            • 262
            • Malaysia
            THANKS BROTHER
            IT,S WORKING FINE
            • sundeon
              • Jan 2022
              • 22
              • Hungary
              #26
              Hi!
              Can someone help me?
              Laptop turns on, but there is no picture
              Acer Nitro5
              Nitro AN515-55-518W
              serial NHQ7PEU00205009B4B3400
              SNID 05003975534
              Thanks in advance!
              • Tonzky Molina
                • Jun 2024
                • 11
                • Philippines
                #27
                >>try this bios from acer support latest bios 2.04
                >> i created this bios using Leakymosfet Bios Creator
                • hoaca388
                  Badcaps
                  • Jan 2022
                  • 12441
                  #28
                  Originally posted by sundeon
                  Hi!
                  Acer Nitro5
                  Nitro AN515-55-518W
                  SNID 05003975534
                  Thanks in advance!
                  Backup not good .
                  • vampy999
                    • Sep 2019
                    • 111
                    • malaysia
                    #29
                    Need bios for below model. I try download post #24 but invalid
                    Problem is cannot power on.
                    FH52M LA-J891P REV 1A
                    S/N: NHQ7PSM001028037543400
                    • aijazali
                      • Dec 2019
                      • 125
                      • saudi arabia
                      #30
                      hi all need Acer nitro an515-55-763H FH52M LA-J891P REV 1.0
                      Snid 02206293734
                      • Ahari
                        by Ahari
                        I...
                        08-13-2025, 06:12 AM
                      • mkdj
                        by mkdj
                        Dear all,
                        10-19-2025, 04:41 AM
                      • Habble7
                        by Habble7
                        Suspected Cause:
                        Troubleshooting Attempts:
                        05-22-2025, 07:28 AM
                      • haitham sharabati
                        [Request] Clean BIOS dump for HP 15-da2007ne (8XF55EA#ABV) - N4000 - BIOS Lock
                        by haitham sharabati
                        Hello engineers 😀,
                        I’m kindly requesting a clean and unlocked BIOS dump for the following HP laptop, as it’s bricked after flashing SP152727. The system now keeps rebooting, and the original issue was an Administrator / Power-On Password that I can no longer access.😏
                        🔧 Device Info:
                        - Model: HP 15-da2007ne
                        - Product Number: 8XF55EA#ABV
                        - Serial Number: CND0338P0D
                        - CPU: Intel Celeron N4000
                        - EC/BIOS Chip: [Add chip number from the motherboard or BIOS chip]
                        💀 Problem:😅
                        - Device shows “Administrator Password”...
                        08-07-2025, 04:54 AM
                      • Citymin
                        by Citymin
                        S/N : 5RNK9FFT70...
                        08-05-2025, 05:12 AM
